Old Feb 21, 2013, 03:51 PM
Joined Feb 2010
Angle of incidence question
Hey all...long time lurker, infrequent poster here.
Quick question (I didn't see a FAQ sticky anywhere): Building these airliners, is there a rule of thumb regarding angle of incidence for the wings and stab? I want to give the wings a few degrees positive...I know that, but not sure about the tail. I want to give it a little aircraft nose up trim (which would be a negative angle of incidence for the stab). Before I glue this is this the right thing to do?
Model is the KLM DC-9-15. Thanks for the help!
gjferg is offline Find More Posts by gjferg
Old Feb 21, 2013, 05:09 PM
Up-Out-&-Gone
demondriver's Avatar
United States, SC, Charleston
Joined Mar 2007
Hi GjFerg, I don't want to speak for other Builders here on RCG but I try and closely match the Main wing & stab Incidence angle of the plane I'm building as closely as possible.
I would say the DC-9 series has a Zero angle of Inc on the stab and a positive Up angle on the leading angle of edge of its wings between 2-4 degrees of incidence.
I hope this helps Sir!
demondriver is online now Find More Posts by demondriver
Old Feb 21, 2013, 05:19 PM
ich bauen groß modell flugzeug
Keenan smith's Avatar
United Kingdom, London
Joined Dec 2010
i agree with DD
Keenan smith is offline Find More Posts by Keenan smith
Old Feb 21, 2013, 06:45 PM
Joined Feb 2010
Cool...thanks!
Old Feb 22, 2013, 07:24 AM
A Day @ a Time - Matt. 6:25-34
ruff1's Avatar
North AL, USA
Joined Nov 2009
The 2 degree angle of incidence is what I'm using on the Martin 4-0-4. The 4-0-4 was rather unusual; it had 3 degrees positive on the wing and a bit under 1 degrees positive on the horizontal stabilizer. The seasoned builders here recommended setting the stab to 0 and making the wing 2.
Going with that, hope it works!
Good luck.
ruff1 is offline Find More Posts by ruff1
Old Feb 22, 2013, 02:43 PM
The Depronizer
Andre Kochanski's Avatar
Germany, NRW, Dortmund
Joined Aug 2012
....wings between 2-4 degrees of incidence.....
i second that. with these numbers you´ll almost always be fine.
Andre Kochanski is offline Find More Posts by Andre Kochanski
Discussion Byron BD-5 thrust angles/incidence angles Speedfreak Fuel Jet Talk 0 Jul 22, 2007 09:34 PM
Question re: Angle of Incidences dmackie Modeling Science 13 May 20, 2006 01:56 PM
Discussion Angle of incidence question? - Long EZ Build Ralph_D Parkflyers 7 Jan 01, 2006 07:40 PM
Question re: Angle of Incidences dmackie Electric Plane Talk 10 Oct 17, 2005 07:27 PM
Angle of incidence question dshly Power Systems 6 Apr 06, 2002 07:14 PM
