Old Feb 27, 2012, 12:23 PM
1lasportsman's Avatar
United States, LA, Kenner
Joined Mar 2011
Parkzone Trojan
I purchased a used plane 4mo. old and it is stange on power up.
Put the stick all the way up and it slowly powers up to full power.after that it responds normal. Ckecked with parkzone and they said they have never heard of this. They want me to borrow the ESC and motor from another trojan and see what is wrong,then would I please call them back and let them know the problem.
Has anyone else had this problem?
I checked with the original owner and he said it has always done this.(new to sport). I have 3 other Parkzone warbirds and none do this.
I checked the start up rate and it is at 0.25 seconds.
1lasportsman is offline Find More Posts by 1lasportsman
Old Feb 27, 2012, 02:09 PM
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Just a guess, but don't some of the heli ESC's and/or Tx's have a slow spool up facility.
Can the ESC be re-programmed ?
eflightray is offline Find More Posts by eflightray
Old Feb 27, 2012, 02:47 PM
Joined Mar 2011
Yes
I was thinking the start up rate would be that.
It is set at 0.25
Two choices 0.25 or 1 second
The tx works fine with other Parkzone planes
Old Feb 27, 2012, 04:11 PM
Joined Mar 2011
It is definitely the ESC
Tried another one and motor worked fine
It seams like this ESC is set for Heli start up.
Does anyone know how to change it?
Old Feb 27, 2012, 06:24 PM
Beaumont, TX
Joined Feb 2007
Would help to know what brand "this" ESC is.
Pete Miller is offline Find More Posts by Pete Miller
Old Feb 27, 2012, 08:53 PM
Joined Mar 2011
Eflight in parkzone plane
The problem was the ESC.
It was set for Heli with slow start up.
I set it for airplane and all works fine.
thanks for the help
Old Feb 29, 2012, 08:20 PM
absolutely maybe
pistnbroke's Avatar
Australia, WA, Currambine
Joined Apr 2011
Hi 1Lasportsman,
Have you looked in the PZ setup manual. look at program 7 in the ESC setup, it may be in the heli mode.
http://www.parkzone.com/ProdInfo/Fil...080-Manual.pdf
I hope that this helps you.
Regards
Ian
Sorry, I did not see the post that you had already fixed your problem, at least there is a manual for others to look at if help is required.
pistnbroke is offline Find More Posts by pistnbroke
Discussion Parkzone Trojan Vs. Parkzone Corsair Supercubflyer Electric Plane Talk 26 Oct 18, 2011 08:36 PM
Wanted Rtf Parkzone Trojan or RTF Parkzone Corsair hbsurfer Aircraft - Electric - Airplanes (FS/W) 2 Sep 28, 2009 09:15 PM
Found Parkzone P-51 Brushless BNF or Parkzone T-28 Trojan CGReload Aircraft - Electric - Airplanes (FS/W) 3 Aug 10, 2009 09:55 PM
Discussion Parkzone Corsair versus Parkzone Trojan direct comparison.. Smokescreen38 Electric Warbirds 14 Jun 30, 2009 06:56 PM
Sold Parkzone T-28 Trojan Parts. E-flite 25AMP ESC/Parkzone 480 Motor/2 Props/DC Carger CGReload Aircraft - Electric - Power Systems (FS/W) 7 Sep 03, 2008 04:35 PM
