Old Feb 13, 2012, 08:59 PM
Innovator
danford1's Avatar
United States, MI, White Lake
Joined May 2011
Need GWS prop nut part number, direct drive props.
I have some GWS direct drive props with the prop nut impressions. They are made to slip over a nut on the prop shaft. The smaller props are fine as I have the needed 5.5mm nuts (3mm threads).
The larger prop require a 7 mm nut that fits in the prop.
I have a 3mm threaded shaft. What is the part number for a GWS nut that has 3 mm threads and requires a 7 mm wrench?
All the 3 mm nuts I found took a 5.5 mm wrench...
I need a 3mm nut that takes a 7mm wrench.
What is the part number?
Danford1
danford1 is offline Find More Posts by danford1
Old Feb 13, 2012, 09:47 PM
Taiwan, 北市
Joined Dec 2010
If the 7mm nut is not available, probably you could try using a washer in 10 or 12mm diameter in front of the old 5.5mm nut on the threaded shaft, then put the prop on to the shaft, and add another washer, then screw them tightly by another nut.
Chen
twn Chen is offline Find More Posts by twn Chen
Old Feb 14, 2012, 07:49 AM
Innovator
danford1's Avatar
Joined May 2011
The shaft isn't long enough for all of that...
The first nut is supposed to fit inside the prop. When it is spaced out with a washer, there isn't room to get the other washer and nut on.
I could cut the shaft and use a regular clinch type prop adapter but I'm not going to.
I want to find the correct nut...
Danford1
Old Feb 15, 2012, 01:35 AM
Houng-wen Lin
GWS4CEO's Avatar
Shijr, Taiwan. DungGwan, China. City of Industry, California.
Joined Sep 2001
I had passed your question to GWS RD.
Wish we can get a solution ASAP.
GWS4CEO is offline Find More Posts by GWS4CEO
Wanted GWS 1060 Direct drive AKA GWS 10x6 Direct Drive Alex Schauer Aircraft - General - Miscellaneous (FS/W) 0 Jan 16, 2012 07:29 PM
Sold Gws ips direct drive unit ArtJ Aircraft - Electric - Power Systems (FS/W) 0 Jan 11, 2012 07:34 PM
Discussion direct drive speed 700 prop size? JayJay76 Dock Talk 13 May 26, 2011 04:22 PM
Discussion GWS EDP-50xc and 3x3 GWS Direct Drive Props slipping to far on shaft TheDonski Flying Wings 12 Apr 24, 2007 05:35 PM
GWS rubber inner adpters for GWS direct drive props GWS4CEO Parkflyers 1 Nov 14, 2001 08:35 AM
