Old Jul 25, 2010, 01:54 PM
shimsham's Avatar
Joined Nov 2009
Graupner Folding Prop With Aero-Naut Blades
Never fitted one of these before got most of it right but not quite sure about the blades,do you have the writing on the blades facing forward and will one of the blades have the writing upside down,also how tight do spanner the nuts on the yoke,do you have the blades floppy so they will fold back or reasonably tight.
Cheers
shimsham is offline Find More Posts by shimsham
Old Jul 26, 2010, 02:49 AM
Joensuu, Finland
Joined Mar 2002
Yes, writing forward (same as convex side forward) and blunt edge into direction of rotation on both blades. When unfolded it will look exactly like any other propeller. Bolts should just tight enough to prevent exessive slop in the plane of rotation, but allow the blades to fold back without any resistance.
jkettu is offline Find More Posts by jkettu
Old Jul 26, 2010, 03:25 AM
Crafter of flying plugs
Owen Hedger's Avatar
Armidale, NSW
Joined Feb 2007
For what its worth:
"Remember, when working out prop sizes, that Aeronaut assume a 42mm centrepiece, whereas Graupner assume a 32mm centrepiece. You can vary prop size by varying the size of the centrepiece."
Lifted from http://www.flyelectric.com/centrepieces.html
So prop diameter will be 10mm less than the spec size of the Aeronaut blades when using a Grapuner hub.
Owen Hedger is offline Find More Posts by Owen Hedger
Old Jul 26, 2010, 04:24 AM
shimsham's Avatar
Joined Nov 2009
Thanks both for your input.
Cheers
Sold Aero-naut Folding Prop TDisaster Aircraft - Sailplanes (FS/W) 3 Jun 16, 2010 03:43 PM
Question best folding prop.. graupner or aero naut grfcon Electric Sailplanes 9 Feb 05, 2010 05:45 PM
For Sale Aero-Naut folding prop blades rev.iain Aircraft - Electric - Airplanes (FS/W) 0 Aug 01, 2009 06:26 PM
Sold Aero-Naut CAM Carbon 16x13 folding prop blades - brand new SPasierb Aircraft - Electric - Power Systems (FS/W) 2 Aug 08, 2007 10:10 AM
robbe, aero-naut, graupner folding prop combination oded mazor Electric Sailplanes 2 Sep 19, 2001 01:47 PM
