Old Jul 15, 2009, 10:52 AM
Edwong's Avatar
Joined Apr 2009
Tamiya paint on EPO,EPS,ELAPOR,EPP,DEPRON?
I have loads of Tamiya polycarbonates and "for plastics" which I've used for modelling and doing car shells. I was wondering if the "for plastics" one which I think is acrylic would work on all the different foams? I'd imagine the polycarbonates would probably eat through it.
Edward
Edwong is offline Find More Posts by Edwong
Old Sep 23, 2009, 07:34 PM
UH-1 Gunship, AH-1G jock 69-71
makeitworst's Avatar
So Cal ... Kingdom of Taxes
Joined Nov 2008
Hope you haven't been waitng long for an answer ;^)
Edward
Here's a answer I gave on another forum site, hope you haven't been holding your breath for an answer to your question.
Almost ANY paint will work on Elapor, the trick is using one that remains FLEXIBLE, since Elapor bends and twists easily. It is NOT a matter of priming, but of picking a paint that doesn't become rigid and chip or flake off when (and it will) the Elapor flexes, and cleaning the mold process chemicals off the fresh Elapor.
Clean the Elapor with 98% Alcohol, even VERY LIGHTLY sanding the surface could improve stickiness, although I have never found a use for this and paint doens't come off any of my MPX planes (6 of them).
Paint I like - Tamiya Color TS (small spray can) for Plastic, by nature is meant to remain flexible since it's for plastic. Rust-Oleum Paint for Plastic (big spray can), for the same reason. Krylon Fluorescent spray stays reasonably flexible for the same reasons previously mentioned.
Paint I can't stand - Krylon H2O is crap, it's sprays lumpy, clumpy and sloppy; and it runs like sissy at a gang fight. Painters tape is useless with Krylon H2O, it even runs underneath! (I have 7 new cans, sell them cheap!). Besides, there is no need to use Water Based paint on Elapor, even Enamel and Lacquer is OK to use!
Now in general, which is better - Enamel or Lacquer?? Theoretically Lacquer should be remain more flexible than Enamel, since Vintage guitars were and are finished in Nitrocellulose Lacquer and guitar wood MUST breath and expand / contract for decades. However any good custom car painter / body shop guy will tell you "nuts on that, Enamel is more flexible, ever see a deep fender dent and no cracking of the paint??" I have no idea who or what is more correct, do you?
As for "primer" .... forget about it!" You don't need it. You're just adding more weight to the plane and another layer that WILL crack and fall off.
makeitworst is offline Find More Posts by makeitworst
Help! What kind of Paint on Depron Coop Foamies (Kits) 23 Jan 10, 2006 09:58 AM
Anyone using Testors Spray Enamel paint on depron? TGK Foamies (Kits) 3 Apr 28, 2005 11:44 PM
Paint on epp? raptor22 Slope 5 Apr 16, 2005 09:15 PM
ok to use tamiya spray paint on gws corsair? jeff262 Parkflyers 1 Jun 02, 2004 08:00 PM
Lexan paint on EPP iggy Foamies (Kits) 0 Nov 04, 2003 05:50 AM
