Old Mar 04, 2003, 07:47 AM
Takao Shimizu is offline
Find More Posts by Takao Shimizu
Tokyo, Japan
Joined Nov 2002
Re: Shimizu-san
I hope you could get it.
Takao Shimizu is offline Find More Posts by Takao Shimizu
Old Mar 04, 2003, 10:21 AM
epkoncept is offline
Find More Posts by epkoncept
San Diego Lindberg, California, United States
Joined Jan 2002
arigatou
takao-san:
Thanks for the end view picture, it was very helpful.
The close up picture is also appreciated. On your motor, what sort of wire size did you use ? 0.7mm phi ? This is just a wild guess but if the motor is spinning at 30k rpm, the field windings are also switching at 30,000/60 x 3 x 2 = 3 kHz. Which seems low enough that skin effect(hifu kouka) might not be significant, but some how I think that due to the sharp edges of the drive waveform, less the inductive effect of the field windings, there might be an advantage to using a smaller gauge wire ? It might be easier to wind with the stranded wire. Have you experimented with the type of wire you used ?
EP
epkoncept is offline Find More Posts by epkoncept
Old Mar 04, 2003, 03:00 PM
Christian Lucas is online now
Find More Posts by Christian Lucas
Germany, BY, Gräfelfing
Joined Jan 2003
Hi EP,
may be i can help you also.
First,to make the wire with lize wire is ok but you get not so much copper inside,the isolation takes some room.Better to take not a single but 4,5-6 strands is ok.Itīs not skin effekt it is edy current wath is better in moore strands.The amps make edy current inside the wire,spezialy in single big copper,at high amps and these is less in smaler strands.
Also the rotating magnet makes edy curent in the wire.
An other method of wireing a air gap coil is to make tree coils with no overlapping each other.
Take the dia X Pi of the magnet to get the outer(do not know the word).Then /3 to get the aera for the every of the tree coils.Glue a wood stick2,5 x 2,5 mm in the middle of each coil aera and wire now the copper around these sticks.The stikes are so long as the magnet is.So you get coils with short overhang at the each end of the magnet.
To get moore magnetic flux i am wireing iron wire around the ready made copper coils.You can use green painted iron wire from floristshop of thinner from hobby shop.take these wire so thinn as you can get.
How much ironwire you make around is to your expirements,much iron lowers the rpm but iron loss get higher,less iron rised the rpmīs but torque is less,so you need a higher gearing.
I hoppe you anderstand my answere.
Christian Lucas is online now Find More Posts by Christian Lucas
Old Mar 05, 2003, 06:57 AM
Tokyo, Japan
Joined Nov 2002
Re: Skin effect
epkoncept,
>0.7mm phi ?
I have bulk 0.7mm phi copper wire. This is the only reason to make this motor with 0.7mm phi wire.
>there might be an advantage to using a smaller gauge wire?
No, I don't think so. My ESC has resisters on each gate of driver FET to reduce the RF noise and inductive kick. This is quite important for high power drive to get safety margin of device operation. This is more important of switching power dissipation loss of FET.
No, I have not. I have no experience of skin effect problem on my designed motors as explained above with my driver design. I would like to test the feeding maximum current of this motor(before burn out?). My motor may eats over 50A, I feel. You can feel cool at the coil after fly with 8.4V 2.4Ah Ni-Cd battery.
Old Mar 29, 2003, 02:19 PM
Joined Jan 2002
takao-san ? What about iron ?
takao-san:
Now I understand how you have the field windings located via the plastic end plates. However, I can not tell whether or not you have any iron ? Does your brushless motor havee any iron in the field windings or between the rotor and field windings ? Do you know if other brushless two pole motors like Hacker or Lehner use iron to increase the flux of the field windings ? If you are using some iron in the field windings, can you show a picture of what you used for the iron stators ?
EP
Old Mar 30, 2003, 06:25 PM
Tokyo, Japan
Joined Nov 2002
Re: takao-san ? What about iron ?
epkoncept,
I could say that the end plate is not useful.
There is no iron magnetic shield. The leackge magnet fileds kiss screws, bolts like any irons near the motor. This is problem.
No, there is no iron plate.
The small space gap between coils and magnet is important. Most of anothers are for magnetic shield effect, I think.
There is no difference of magnet and slot-less coils between others and mine, except magnetic shield ring with the expensive machine made outer case.
http://www.rcgroups.com/forums/showt...5&pagenumber=3
Old Jun 08, 2003, 06:46 PM
KreAture is offline
Find More Posts by KreAture
Impossible? Hah!
KreAture's Avatar
Oslo Fornebu, Norway
Joined Jun 2003
Could you try and run a rewound CD-rom motor with your controller? I'd be very interested in the results
KreAture is offline Find More Posts by KreAture
Old Sep 01, 2003, 10:26 AM
Ron van Sommeren is offline
Find More Posts by Ron van Sommeren
homo ludens modellisticus
Ron van Sommeren's Avatar
Netherlands, GE, Nijmegen
Joined Feb 2001
A slightly different approach, no need for a lathe at all:
http://www.rclineforum.de/forum/thre...did=36382&sid=
http://www.ppi.se/cjo/Slotless1.htm
http://www.rc-network.de/cgi-bin/ubb...2;t=000455;p=2
http://www.rc-network.de/cgi-bin/ubb...2;t=000455;p=3
Met vriendelijke groet Ron van Sommeren
• diy outrunner brushless e-motor discussion.
• Electric fly-in & lrk meet, June 27th, 2004, Nijmegen, the Netherlands.
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old Nov 25, 2003, 05:33 AM
Tokyo, Japan
Joined Nov 2002
Better source program
My home page is closed.
I hope this program works better.
(I am making all new software)
Old Nov 25, 2003, 01:59 PM
whanderson is offline
Find More Posts by whanderson
Baltimore Bwi Rr Stn, Maryland, United States
Joined Oct 2003
Takao,
Just wanted to jump in with comments on PICs versus Atmel. You can get an in circuit debugger for their flash parts for $150 US. This has proven to me to be more effective than an ICE. Also CCS has a PIC C compliler for $100. I have tried the Atmel parts and keep going back to PICs.
whanderson is offline Find More Posts by whanderson
Old Nov 27, 2003, 08:24 AM
Tokyo, Japan
Joined Nov 2002
I edit the post to change the schematic.
Sorry, the old one was the BL servo schematic, not BL ESC.
Old Nov 30, 2003, 07:28 AM
alx is offline
alx
Find More Posts by alx
alx
Russia
Joined Nov 2003
brushless controller
Dear Takao,
Thank you for the brushless controller schematic and for the program source!
And I have some questions:
I want to repeat your controller without making any changes. Will it work with a brushless cd-rom motor? Or I need to adjust the program according to the motor I'm going to use? Or may be your controller is universal for all 3 phase brushless motors?
Thank you.
alx is offline Find More Posts by alx
Old Nov 30, 2003, 08:12 AM
Tokyo, Japan
Joined Nov 2002
Re: brushless controller
alx,
This ESC is too big for CD-ROM plane.
I have never tested this for CD-ROM drive.
I am making all new simple BL ESC circuit and drive software.
It is under construction as the photo shows.
I use a comparator on the ATMEL chip in stead of OP amps.
You may find the detail explanation on TB6537P/F Toshiba brushless driver chip data sheet.
Old Nov 30, 2003, 12:11 PM
alx is offline
alx
alx
Russia
Joined Nov 2003
Dear Takao,
Thank you for the fast reply.
Now everything is clear. As I understand your new simple BL ESC will be suitable for light plane based on cd-rom motor, right? If yes, I'll be waiting for that! By the way, are you going to share your new BL ESC schematic/program with anybody?
I'm doing my first steps in electro planes modelling, and your ideas will be really very helpful for me. One more thing, sorry, if it's offtopic: could you, please, help me to get some information (links, plans...) about cd-rom motor based rc planes? I know, you can build such planes very well (I've seen some photos)!
Best wishes,
alx.
Old Dec 01, 2003, 08:24 PM
zagisrule! is offline
Find More Posts by zagisrule!
Senior Member
zagisrule!'s Avatar
Edgewood, NM
Joined Jan 2002
I have tried Takao's design, but I had trouble arming the last controller with my Airtronics and JR radios. Hopefully this version will do better
Thanks alot Takao!
zagisrule! is offline Find More Posts by zagisrule!
Pics of My Own Design Yak 55 Flat Foamie Boss248 3D Flying 22 Jan 13, 2005 04:54 PM
My own design...comments? zed Parkflyers 29 Dec 31, 2004 02:01 PM
A delta wing sloper of my own design Web Slope 165 Aug 02, 2004 11:58 PM
My own design... 7homuz Free Flight 6 Oct 03, 2003 11:27 PM
My own design scratchbuilt Sopwith 'strutter for IPS power Looooeeee! Scale Kit/Scratch Built 22 Jan 29, 2003 05:02 PM
