Old Apr 16, 2007, 02:50 PM
nut is offline
nut
Find More Posts by nut
nut
Pots and Kettels
Among the Masses
Joined Sep 2005
Wemotec Mini 480 "What Motor"
Well this will be my first EDF and I'm trying to do it right. I have a Wemotec Mini 480 fan unit, I see one set up that is affordable and seems to produce good performance is the HET 2-W motor. It is specs. show a 4580 RPM per volt. I would appreciate any input on what other choices I may have.
I will be installing it in a RT Models Mig 15 AUW should be around 36 to 40 oz.
I will be sticking with 3 cell lipos to try and keep the AUW down. I have a few 3200's and a couple of 3c2p4200's
Regards,
Nut
nut is offline Find More Posts by nut
Old Apr 16, 2007, 03:56 PM
dusmmdb34 is offline
Find More Posts by dusmmdb34
dusmmdb34's Avatar
Alexandria LA
If you are planning on using the 3s batteries, the 2w or the mega 16/15/2 are both great choices. I really like the 16/15/2 on 3s for a good light setup.
dusmmdb34 is offline Find More Posts by dusmmdb34
Old Apr 24, 2007, 12:48 AM
dno264 is offline
Find More Posts by dno264
David
dno264's Avatar
San Francisco, CA
Joined Sep 2004
Het 2w and 480 fan
I have tried the HET 2W motor with the 505 fan (same as the 480 fan but without the shroud) in a kamodel sabre and got about 400 watts at 40 or so amps but with a weight penalty of higher capacity 3 cell batteries. The alternative set up was the 3W motor with 4 cell, which used lighter batteries and lower amperage (1500mah) but gave up 100 watts of power. The 3W motor and 4 cells produced close to 300 watts but at a lower amperage of about 30.
Markos at Warbirds-rc has posted HET motor/fan test results at http://www.warbirds-rc.com/ResearchC...sts/index2.htm
-David
dno264 is offline Find More Posts by dno264
Old Apr 24, 2007, 01:01 AM
dno264 is offline
David
dno264's Avatar
San Francisco, CA
Joined Sep 2004
I also have the RTModels Mig in my building queue so I am very curious as to the outcome of your choice of motor/fan/battery combination. From my experience with the sabre (my first edf), I found it difficult to keep the AUW down given the added inherent weight of an edf system and the need to provide enough power to sustain flight.
Old Apr 24, 2007, 07:17 AM
nut is offline
nut
nut
Pots and Kettels
Among the Masses
Joined Sep 2005
Thanks Guy's
I will start the build this weekend. It sounds like I can use what I have with the 2-W motor. I also have a CC60 ESC that should give me some wiggle room.
Once I get the Fan mounted and the ducting installed I'll do some bench testing with the batteries I have and post the results.
Thanks Again,
Nut
Old Mar 02, 2008, 04:25 PM
dno264 is offline
David
dno264's Avatar
San Francisco, CA
Joined Sep 2004
Hi--
Did your Mig fly? How did the 480 fan and the HET motor work for you? Thanks.
Discussion What motor are you using in a Wemotec Mini-480? Nobert Electric Ducted Fan Jet Talk 27 Apr 24, 2007 12:25 AM
F-18 with mini 480...what motor??? noahb Electric Ducted Fan Jet Talk 1 Feb 27, 2004 07:48 PM
Best price on WeMoTec mini 480? RobZ Electric Ducted Fan Jet Talk 4 Sep 20, 2003 12:34 PM
Wtb Wemotec Mini 480 Edf new2flight Aircraft - Electric - Airplanes (FS/W) 0 Aug 13, 2003 08:10 PM
WTB WeMoTec Mini 480 Fan Units Chad Sullivan Aircraft - Electric - Airplanes (FS/W) 1 Nov 19, 2001 11:53 PM
