Old Dec 11, 2005, 09:14 PM
deh6 is offline
Find More Posts by deh6
Joined Aug 2003
I'm a late-comer to this thread. A couple of thoughts on this thread--
Airspeed--
Calculating true airspeed from indicated airspeed is useful for navigation, e.g. time * speed = distance. How the plane flies, e.g. stall speed, depends on indicated airspeed so there is no need to make the calculation to compensate for air density.
Total energy--
The TE probe provides a static source to the variometer so that the vario doesn't follow dives and pullups. As a result the vario shows a glider pilot the true lift as he/she enters a thermal even though the stick may be pulled back (converting kinetic energy into altitude).
Some years ago I flew sailplanes (fullsized) and we used Braunswcheig tubes for the static source for the vario. It is a closed off tube bent 90 degrees with several slots cut into the trailling edge. It looked similar to the one in the following url--
http://www.tek-variometer.de/englisch/index.html
An even earlier scheme used a diaphragm/valve arrangement that connected to the pitot tube and static source and fed the vario with a compensated pressure--much more complicated and expensive than the simple Braunswcheig tube. This was all before microprocessors became powerful & cheap.
My thinking for model airplanes is to do the total energy computation in the micro, using the pitot-static pressure as the input. One should be able to add some calibration points so that the compensation is improved. The basic scheme is based on the kinetic energy being proportional to the square of the speed and the polar of the plane is parabolic. With the newer high performance airfoils the polar departs a little from parabolic so that the basic TE compensation is not perfect (but vastly better than none).
Altimeter--
Intersema Sensoric, MS5534A has an interesting part--
http://www.intersema.ch/site/technical/ms5534.php
It is 27.15 Swiss France, about $20US, and has a built in 15 bit ADC. The shipping on samples is 30 Swiss Franc which doubles the price to the door (for one unit).
Given the trouble and cost of what needs to be added to get good resolution on the Freescale parts, the cost may well be worth it.
deh6 is offline Find More Posts by deh6
Old Dec 11, 2005, 11:12 PM
mluvara is offline
Find More Posts by mluvara
Silicon Valley
Joined Sep 2003
Originally Posted by HLGNut
http://www.rcatsystems.com/index.php
that use a simple brass tube for the pitot tube and ambient air around the sensor for the static.
FYI - The rcats unit does not use a simple brass pitot tube. We have a very precise combined pitot-static probe that is designed for giving good measurements. Using ambient static inside a fuselage is not very accurate at all and in the majority of cases, will skew your data one way or the other and is dependent on aircraft speed/attitude,etc.
http://www.rcatsystems.com/accessories/pitotprobes.php
Michael
RCATS
mluvara is offline Find More Posts by mluvara
Old Dec 17, 2005, 08:09 PM
kfong is offline
Find More Posts by kfong
Sterling Heights, Michigan, United States
Joined Nov 2003
Finally got the boards and had some time to stuff it. So far it looks good. Now comes the programming part. It will be a while, anyone interested in one of these boards let me know, based on this design http://www.kapelec.com/altivie1.htm
Kin
http://www.embeddedtronics.com/
kfong is offline Find More Posts by kfong
Old Apr 24, 2006, 03:12 PM
rocky79 is offline
Find More Posts by rocky79
rocky79's Avatar
Los Angeles
Joined Aug 2004
Looking at this thread posts on the Pitot tube. I didn't see any specific measurements for length of the tube the width of the static holes and the tube bend radius.Any information on how to choose those parameter?
rocky79 is offline Find More Posts by rocky79
Old Nov 12, 2006, 01:27 PM
rsosa is offline
Find More Posts by rsosa
Joined Aug 2006
That is exactly what i am looking for... any hint much appreciated
rsosa is offline Find More Posts by rsosa
Old Nov 13, 2006, 01:08 PM
AndyKunz is offline
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
Originally Posted by Mr.RC-CAM
I definitely will be interested in how the AD7714 performs for you (looks like a nice part). It will take a serious PCB layout (faultless grounds and signal guarding) if you need all 24 bits.
We did one with it shooting for 22 bits, and grounding was a MAJOR issue. It does work as advertised, providing you get the layout right. We spent a lot of time on the phone to the chip design team trying to get it resolved. Eventually we cancelled the product.
We're using an MCP3551 now on a related product and having far less trouble all around. Not as capable, but 18+ bits of precision was easy. Getting test equipment just as accurate was fun - company politics
Andy
AndyKunz is offline Find More Posts by AndyKunz
Site Sponsor
Old Nov 15, 2006, 07:32 PM
sguty is offline
Find More Posts by sguty
Senior Member
sguty's Avatar
Redmond, WA, USA
Joined Oct 2000
There was another thread that had a link to a german site (http://home.germany.net/100-173822/d_logger.htm) which had a relative-dimensioned pitot tube, didn't talk about your specific parameters, but I think the dimensions noted are the critical ones.:
sguty is offline Find More Posts by sguty
Discussion EagleTree Systems Pitot Tube ? ashvani UAV - Unmanned Aerial Vehicles 13 May 03, 2007 11:17 PM
Has anybody built a pitot tube? ElectroLawndart UAV - Unmanned Aerial Vehicles 5 Apr 23, 2005 04:11 PM
