Old Apr 11, 2013, 07:54 AM
scruffy1 is offline
Find More Posts by scruffy1
looking up down under
scruffy1's Avatar
Australia, NSW, Fairlight
Joined Feb 2008
nice work - the pt19 is my favourite
next job is to clone the wing and make a curtis jenny
scruffy1 is offline Find More Posts by scruffy1
Old Apr 12, 2013, 01:44 PM
bayou_city_boy is offline
Find More Posts by bayou_city_boy
United States, TX, Houston
Joined Oct 2012
Maiden Micro PT 19 E Stick April 12 2013
Flying weight 6 oz.
Control surface throws
(+ up / - down)
Aileron +/- 3/16 inch
Elevator +/- 3/16 inch
Rudder +/- 1/4 inch
Balanced at 1 3/4 inch from leading edge.
WOW!
ROG off of short grass field.
Quick climb out.
Very sensitive responsive on ailerons and elevator.
Nice coordinated turns using rudder.
While trimming aircraft prop saver came off with prop and I lost all thrust. Airplane slowed and I lowered the nose to keep the airspeed up to land for landing. Hard landing cracked fuselage at front and rear bulkheads. Also horizontal stab came loose. Spent 15 minutes to repair.
Second flight
Reduced control surface throws.
(+ up / - down)
Aileron +/- 1/8 inch
Elevator +/- 1/8 inch
Rudder +/- 1/4 inch (no change on rudder)
Again ROG off of short grass field.
Quick climb out.
Still very quick responsive on ailerons and elevator
Much smoother flight.
BEC voltage cut off began to slow motor as designed. Nice glide slope. Floats just a bit. Smooth touch down. Did not flip on the short grass!
Over all flight opinion.
I am an average Sunday flyer. No great aerobatic or 3D skills tho I can do some very sloppy ones!
This airplane is FUN! Kept me on my toes first 2 flights. It performs well! Next flight I think I will move the CG forward 1/8 inch and see how much stability this will add for Sunday flying.
bayou_city_boy is offline Find More Posts by bayou_city_boy
Help! hobbyking new mini osd w/gps abletowinginc FPV Equipment 15 Jan 08, 2015 07:56 AM
Discussion Multiwii Mini Flight Controller HK Hobbyking alll Mini Multirotors 40 Apr 15, 2013 09:12 AM
Sold Hobbyking Mini Swift Mini Hotliner BNF Johnnymeg Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Jan 23, 2013 11:24 PM
Question Hobbyking Mini Stick daywead Parkflyers 23 Dec 15, 2012 03:49 AM
Discussion servos, esc, motor for mini ultra stick from hobbyking mxaexm Electric Plane Talk 11 Jun 01, 2010 10:13 PM
