Old Jan 24, 2013, 04:02 PM
addictedtoplanes is offline
Find More Posts by addictedtoplanes
Molon Labe
addictedtoplanes's Avatar
Canada, ON, Guelph
Joined Jun 2012
What mount for this motor?
I would like to put this motor in an e-flite mini ultra stick. It is the parkzone 480 960kv bl outrunner. Is there anywhere that I could get an x-type mount for it?
addictedtoplanes is offline Find More Posts by addictedtoplanes
Old Jan 24, 2013, 04:46 PM
tupeloflyer is offline
Find More Posts by tupeloflyer
Dixie Sky Devils AMA# 1015548
tupeloflyer's Avatar
United States, MS, Tupelo
Joined Oct 2012
Horizon Hobby should have some kind of a universal mount? if anything get the one for the eflite 480 motor and use a sharpie to transfer hole pattern and drill new holes. I've done it many times.... I probably have a mount that will fit it in my parts box.
tupeloflyer is offline Find More Posts by tupeloflyer
Old Jan 24, 2013, 06:44 PM
jstern429 is offline
Find More Posts by jstern429
United States, CA, Livermore
Joined Dec 2009
Just saw one of the Mini Ultra Sticks at our flying field last week and the front fire wall is set up to bolt the Eflite 480 motor on without the "X" mount. Now the motor you have is different, but you may get two of the holes to line up. I couldn't find any of my old PZ mounts from my T28 to see if it matches the Eflite 480, but you should come close with two of the holes and the other two will be closer together. The motor you have mounts with the 4 screws and they are all the same distance apart, the Eflite 480 also can mount with 4 screws, but two are farther apart and two are closer together.
jstern429 is offline Find More Posts by jstern429
Old Jan 25, 2013, 06:59 AM
Molon Labe
Canada, ON, Guelph
Joined Jun 2012
ok, thanks, than I should just be able to re-drill the holes.
Old Jan 25, 2013, 09:40 AM
Joined Dec 2009
Yep, just make a pattern of the mounting holes that are on the motor and see what needs to change on the fire wall. Should be very easy to mount. You may need to open up the hole that the collar fits into as it may be larger than the one on the Eflite 480.
Old Jan 25, 2013, 12:29 PM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
I use 9-ply 1/8" plywood for mounts when the x-mount isn't ready to hand.
Sparky Paul is offline Find More Posts by Sparky Paul
Old Jan 25, 2013, 12:56 PM
Ascended Master
Palmdale, CA
Joined Oct 2000
Motor mounts... commercial and home-made..
For Sale KDE direct m4/25 motor mount for 700E heli jenna Aircraft - Electric - Helis (FS/W) 0 Jan 17, 2013 08:22 PM
Sold motor mount for 35mm outrunners 18.00 shipped conus bendix1 Aircraft - Electric - Power Systems (FS/W) 0 Jan 16, 2013 04:12 PM
Discussion Need Advise on what C rating for this system set up! chopper52 Electric Ducted Fan Jet Talk 1 Jan 12, 2013 01:09 PM
Question DLE 30 what for this fuel Tank for on DLE 30 Johnsmith122 Engines 5 Jan 09, 2013 02:18 PM
Discussion I've got this plane, and this motor, what motor mount do I need? polar8 Glow to Electric Conversions 9 Feb 20, 2012 06:13 PM
