Old Nov 20, 2012, 09:47 AM
Chewbacca888 is offline
Find More Posts by Chewbacca888
Joined Nov 2012
Imax b6ac
I would like some help configuring my new charger.
I dont know anything about A, mah etc.
I have 2 lots x 5 batteries each hooked up together, in series I have been told, and on the pack it says 10 x SC2500mah 12v
My question is what is the max power I set my charger at to rapid charge my batteries?
The original charger that came with the RC Car says the charger has 800mah on it.
If I set the new charger to 0.8A, will it take the same amount of time to charge? If I then double the A figure, will that then halve the charging time?
Please help thanks
Chewbacca888 is offline Find More Posts by Chewbacca888
Old Nov 20, 2012, 10:54 AM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Is it a NiMH pack? Any pictures of the pack, it sounds weird from the description.
Doubling the current will roughly cut the charge time in half, but you have to be careful that you can charge the pack at that current rate. Generally you don't want to exceed 1C. C is the capacity of the pack, in amps. For you, this would mean charging at 2.5a max (2500mah = 2.5a).
wparsons is offline Find More Posts by wparsons
Old Nov 20, 2012, 11:13 AM
Joined Nov 2012
Here you go
Description:
Description:
Old Nov 20, 2012, 11:19 AM
Joined Nov 2012
SO i can set it up to deliver 2.5 amps and charge it?
Does it (the charger) switch off automatically when it is done?
Yes it is Ni-Mh
Old Nov 20, 2012, 09:20 PM
Joined Nov 2012
How about discharge rates? What figures should I put in for the range of the current charge and range of the final voltage?
WOuld final voltage be 12V as my battery is a 12V?
Old Nov 20, 2012, 09:21 PM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Yes, and yes to charging.
The charger should automatically handle charging and discharging as long as you give it the rates.
Old Nov 20, 2012, 10:02 PM
Joined Nov 2012
Any tips on discharge rates?
Old Nov 21, 2012, 06:22 AM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Go as high as the charger will let you, it won't be very high on that charger.
Old Nov 21, 2012, 08:40 PM
Joined Nov 2012
OK so Ive charged my battery with the new charger. After 50mins it says Battery full and the final reading was that the battery had 1152Mah.
I thought my batt was 2500mah? The batt is only like 4 weeks old.
What is happening??
Old Nov 22, 2012, 10:37 AM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Was it fully discharged before you started? If it was only half discharged, you'll only get half the capacity back in.
It might've been a false peak, I typically run a second charge cycle on nicad or nimh packs to make sure they're fully charged.
Old Nov 22, 2012, 08:38 PM
Joined Nov 2012
I went to discharge the battery and it shut down after 4hrs and the display read 1300mah. why did it shut down before it reached 2500mah?
Old Nov 23, 2012, 05:31 AM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Was it fully charged before discharging?
Old Nov 25, 2012, 05:06 AM
Joined Nov 2012
I believe so.
I had set the battery to discharge and when it finished, it had a figure of 1300mah
Help! EC POWER EC6 CHARGER VS iMAX B6-AC B6AC and iMAX B6 CHARGER foot8sativa Batteries and Chargers 4 Jul 07, 2014 01:48 AM
Discussion Imax B6AC gets HOT! Scootatrash Batteries and Chargers 16 Jan 26, 2014 03:50 AM
Discussion IMAX B6AC Calculating mah usage AscotRC Batteries and Chargers 8 Nov 03, 2012 10:57 PM
Discussion How to use LiPo sotrage on iMax B6AC charger sinni Batteries and Chargers 1 Aug 13, 2012 01:52 AM
For Sale imax b6ac dual power lipo charger spoonf20c Aircraft - Electric - Batteries & Chargers (FS/W) 1 Mar 12, 2012 04:12 PM
