Old Sep 08, 2012, 04:22 PM
Fly Boy3 is offline
Find More Posts by Fly Boy3
United Kingdom, Wales
Joined Jul 2009
OD ,CoG positions
Hi all, I can sort out CoG positions for models with conventional wings etc. But I have a problem with flat wing Depron Delta type shapes of my own design. I have read somewhere that a glide test can be used with these lightweight models using Blue Tack or similar to trim an empty model for a long flat glide. Any info on this will be gratefully received. Cheers
Fly Boy3 is offline Find More Posts by Fly Boy3
Old Sep 08, 2012, 04:28 PM
fh64_lucky is offline
Find More Posts by fh64_lucky
Ginger or MaryAnn ??
fh64_lucky's Avatar
United States, TX, Garland
Joined May 2005
Yes,I tape quarters to mine on nose and toss in some tall grass.It will get you pretty close, Joe
fh64_lucky is offline Find More Posts by fh64_lucky
Old Sep 10, 2012, 12:27 AM
djacob7 is offline
Find More Posts by djacob7
Knife cuts foam like its steel
United States, CA, Fremont
Joined Jan 2009
You can even make a cardboard (or plywood) cutout the same shape of your model to do a glide test. You'd have to add a vertical stabilizer too. This way you won't have to worry about breaking your model.
djacob7 is offline Find More Posts by djacob7
Old Sep 10, 2012, 08:09 AM
Fly Boy3 is offline
Joined Jul 2009
Hi Lucky (great user name) thanks for the info, will do over some long grass. Cheers
For djacob7, great idea as well. thanks both. Still a lot to learn. LoL
Old Sep 10, 2012, 09:07 AM
fh64_lucky's Avatar
Joined May 2005
It hekps to know , Deltas CG are a little farther forwards then you might think,depends on sweep of wing design but test it out starting off what you may think it looks like being nose heavy.
Old Sep 11, 2012, 12:38 PM
Fly Boy3 is offline
Joined Jul 2009
I think that,s good advice Lucky. Built a foamy from a plan once, 12 inch cord. CoG on plan was 1 1/2 inches out. Dead lucky to save it. Should have known better. LoL.
Discussion OD "Capriccio" - opinion? MCarlton Slope 5 Aug 02, 2012 07:59 AM
For Sale New Star 45 OD class yacht seefest Boats (FS/W) 2 Jul 05, 2012 02:30 PM
Sold LPO Santa Barbara OD Yacht rjd Boats (FS/W) 4 Apr 29, 2012 10:05 PM
Sold 2200KV inrunner 28m OD 37mm long 1/8" shaft The Don Aircraft - Electric - Power Systems (FS/W) 1 Mar 29, 2012 02:36 AM
2x 3mm, 3.5mm and 5mm Prop Adapters 9.6mm OD Dave8888 Non R/C Items (FS/W) 1 Mar 16, 2012 12:31 AM
