Old Jun 09, 2012, 08:58 PM
jirvin_4505 is offline
Find More Posts by jirvin_4505
working to the closest cm
jirvin_4505's Avatar
brisbane australia
Joined Nov 2002
Magnetic rx switch
Can anybody point me to a DIY magnetic Rx switch similar to something like this?
http://zepsus.com/magnetic-switch/
Maybe hall effect sensor, a pic chip and a MOSFET switch?
Cheers Jeff
jirvin_4505 is offline Find More Posts by jirvin_4505
Old Jun 10, 2012, 10:47 AM
jglenn is offline
Find More Posts by jglenn
Ohio
Joined Nov 2003
Here is one used for rocket electronics:
http://shop.featherweightaltimeters....3&categoryId=2
jglenn is offline Find More Posts by jglenn
Old Jun 10, 2012, 02:01 PM
srnet is online now
Find More Posts by srnet
Stuart
srnet's Avatar
UK, Cardiff
Joined Dec 2008
Interesting, but a small NiMh lasting several years ?
Several months maybe.
srnet is online now Find More Posts by srnet
Old Jun 10, 2012, 11:43 PM
Larrikin is online now
Find More Posts by Larrikin
Everything's A Compromise
Larrikin's Avatar
Australia, QLD, Elimbah
Joined Jan 2005
As a newby to DIY electronics, I don't suppose there's a sympathetic, experienced DIYer that would could put together a shopping list to make one of those magnetic switches like the Zepsus or Featherweight units ..... please?
David
Larrikin is online now Find More Posts by Larrikin
Latest blog entry: The Rubicon
Old Jun 11, 2012, 01:44 PM
orraman is online now
Find More Posts by orraman
Scottish Borders
Joined Mar 2006
Looking at the Zepsus switch, if one was starting from scratch I doubt if one could be made for much less than the asking price.
However if it was to be an introduction to the hobby of microcontrollers it may be a good way to start.
If you have access to a PC with a serial port I believe that a surface mount 8 pin Picaxe would be the cheapest micro to program, the programmer is a serial plug and 3 wires. The Programming Editor is free and help is available.
The printed circuit board could be hand cut but that Will take time, practice, a measure of skill. I use a Swan Morton brass knife with the tip stoned square.
Otherwise etchant and resist pen or the toner transfer method. I use software and UV box.
In addition to the parts above, at least one capacitor and three resistors Plus a quality servo extension lead. In the UK the postage to 2 suppliers could cost more than the item.
Busy finishing the world's cheapest hot wire Zaggie foam wing cutter. CNC without PC, uses one 8 pin and one 18 pin Picaxe.
But if you want to go ahead???
Dave
orraman is online now Find More Posts by orraman
Old Jun 11, 2012, 03:00 PM
jeffs555 is offline
Find More Posts by jeffs555
"Simplify, then add lightness"
Raleigh,NC
Joined Nov 2000
The big problem would be getting the current drain extremely low. You have to use the sleep mode and/or very low clock frequencies to get a PIC or most other processors into the low microAmp range. Don't know if the PicAxe will do that.
Shouldn't need a microcontroller. You could just use a CD4000 series FF or counter and run the hall output into the clock so it toggled the FF or counter when you passed the magnet over the hall sensor.
Here is a hall sensor with built in amp that is spec'd for up to 6v and only draws 3uA.
http://www.mouser.com/ProductDetail/...Fi5wsPThlQ8%3d
Should be able to just add a CD4xxx FF, a mosfet, a pull up resistor and some filter caps.
jeffs555 is offline Find More Posts by jeffs555
Old Jun 11, 2012, 03:27 PM
ltc is offline
ltc
Find More Posts by ltc
ltc
AMA 97737
ltc's Avatar
United States, MA, Mendon
Joined Mar 2010
^ + 1
No need for any software ... a hardware based design is more appropriate here.
I would skip the clock and go with a simple comparator/latch based design ... can probably be done in the digital domain with flip flop and a schmidt trigger logic gate.
Quick and easy.
ltc is offline Find More Posts by ltc
Old Jun 11, 2012, 04:38 PM
jeffs555 is offline
Raleigh,NC
Joined Nov 2000
Most hall effect devices are only on in the presence of a magnetic field so without driving a clock input, how are you going get an output that changes just by passing a magnet by it? You could use a T FF, or a D FF with the -Q connected to the D, or else just the first Q output of a counter, but either way would need to feed the hall output into the clock so the output would toggle every time the magnet is passed by.
Could do it with just an SR latch, but would need two unipolar hall sensors and then the North pole could turn it on and the south pole could turn it off. There are actually some hall devices with all this integrated into one package, but the only ones I could find draw 5 or more milliamps of current.
PS Not up enough on packaged hall switches to know if there would be any bounce as the magnet is passed by the sensor. If there is, may need to put an RC filter on the output of the hall device to prevent one pass of the magnet from creating multiple toggles.
Old Jun 11, 2012, 07:30 PM
jglenn is offline
Ohio
Joined Nov 2003
Reed switch + SCR.
Maybe add a FET for low on R.
LED indicator.
Old Jun 11, 2012, 09:15 PM
jeffs555 is offline
Raleigh,NC
Joined Nov 2000
Reed switch would work, but still need a flip flop of some sort to get on/off action without having to leave the magnet attached. SCR with a DC supply could trigger, but would never turn off.
Old Jun 12, 2012, 06:53 AM
jglenn is offline
Ohio
Joined Nov 2003
Oops, forgot about shutoff. How about unplug the battery?
Why do people want mag switches on planes? On rockets it helps to avoid
switches sticking in the airstream. For planes a tiny slide switch works fine.
Old Jun 13, 2012, 10:25 AM
ltc is offline
ltc
ltc
AMA 97737
ltc's Avatar
Joined Mar 2010
They seem to have other applications as well
http://www.espritmodel.com/jeti-elec...ey-sps-20.aspx
Old Jun 13, 2012, 01:26 PM
jglenn is offline
Ohio
Joined Nov 2003
Nice, but costly. I think the Featherweight unit can do the same thing, smaller.
Old Jun 13, 2012, 04:10 PM
jeffs555 is offline
Raleigh,NC
Joined Nov 2000
One thing that Jeti unit advertises is that it remembers the state it was in, even if the battery is disconnected. I don't see that as an advantage, and could be a safety problem. With a mechanical switch, you have a visual indication of whether the switch is on or off before you connect the battery. With an electronic switch, the visual indication is an led, and that doesn't work until you plug in the battery. If the electronic switch remembers that it was on, and you don't remember, you would have no way of knowing if the switch was off or on until you plug in the battery and the switch sends power to the output(and possibly the propeller). Think it would be much safer to have it always power up in the off position when you plug in the battery.
Old Jun 13, 2012, 04:32 PM
jglenn is offline
Ohio
Joined Nov 2003
Very true, what were they thinking, why did they do it that way?
Probably the software guys were designing the hardware again...
For Sale 2- NIP JetZone RX Switches GeetarJoe Aircraft - Fuel - Jets (FS/W) 0 May 10, 2012 04:32 PM
Wanted Zepsus Magnetic Switch riley71198 Aircraft - Sailplanes (FS/W) 0 May 06, 2012 07:25 PM
Discussion Magnets harmful on the video rx? jesse78 FPV Talk 3 May 03, 2012 04:08 AM
Sold 3 Zepsus Magnetic Switches David Cortina Aircraft - Sailplanes (FS/W) 1 Apr 22, 2012 04:14 PM
Sold Spektrum DX7 w/ AR7000 rx, switching v-reg and case $200 xavenged Aircraft - General - Radio Equipment (FS/W) 0 Apr 04, 2012 05:58 PM
