Old Mar 04, 2012, 07:43 PM
jshelton is offline
Find More Posts by jshelton
Jim in Santee
jshelton's Avatar
United States, CA, Santee
Joined Oct 2001
Aurora 9 Butterfly problem
I've read through previous threads and still don't have an answer. I'm setting up an Omega 1.8 electric glider which has full-span ailerons, no flaps. I want to use the ailerons as a spoiler controlled by the throttle stick.
I have butterfly activated and on the B switch. With 'divisional' set it deploys fully but with linear I get nothing. I was able to this working on another glider so that the throttle stick works the amount of butterfly and the only difference I see is that in the area where you set the on/off for the selected switch the working glider is set to 100% and the non-working glider is 0%.
I can't get that 0% changed to 100%. I can select it stays at 0%. I'm sure that will fix it but I have no idea how to change it.
jshelton is offline Find More Posts by jshelton
Old Mar 04, 2012, 11:03 PM
Dan.Cummins is offline
Find More Posts by Dan.Cummins
Launching!
Dan.Cummins's Avatar
Chula Vista, CA
Joined Jul 2006
Throttle Stick SET Position for Butterfly v 1.08 (1)
USING FIRMWARE VERSION 1.08 (1)
From the butterfly screen:
1.) Press switch to get the the switch setup screen
2.) Press the triangle icon to the right of T.Stick Linear
3.) Press/highlight the XX% number between the off/on. The SET icon will appear in the lower righthand corner of the screen.
4.) Position throttle stick to the position that you would like butterfly to start deployment.
5.) Press SET to establish the Throttle Stick starting position for Butterfly deployment.
Hope this helps.
DC
Dan.Cummins is offline Find More Posts by Dan.Cummins
Old Mar 05, 2012, 01:42 AM
jshelton is offline
Jim in Santee
jshelton's Avatar
Joined Oct 2001
Thanks DC - That's the process I went through and it stays stuck at 0%. Finally, decided to make a copy of my other glider where the butterfly DOES work on the throttle stick and redid the other settings so that I now have a complete setup for my Omega. It works great now but I still have no idea what the problem was!
Discussion Aurora 9 Crow/Butterfly setup Highfly! Hitec/Multiplex USA 24 Nov 04, 2013 07:23 PM
Discussion I have a problem to collaborate open pilot through AURORA 9 oren_ben_nun Multirotor Talk 10 Oct 30, 2011 03:46 AM
Discussion Aurora 9 Butterfly andreikoc Radios 5 Aug 28, 2011 11:36 AM
Question Aurora 9 Butterfly andreikoc Hitec/Multiplex USA 1 Aug 27, 2011 09:26 PM
Help! Aurora 9 Butterfly superk Radios 1 Apr 17, 2011 04:20 PM
