Old Jan 07, 2012, 12:07 PM
jptonks is offline
Find More Posts by jptonks
Joined Apr 2008
Slowing Down Electric Retracts
Hello All:
I am having trouble thinking this one through.
I am considering buying a plane that comes with flaps, servos, 2.4 receiver, and electric retracts already installed. Can I adjust the speed of the flaps and retracts with my Aurora 9 TX's delay feature?
Or would I have to change the installed RX to a Hitec Optima RX in order for the RX to comminicate correctly with my Aurora 9 TX?
OR will the delay feature not work at all with electric retracts?
I realize there are aftermarket sequencers available that would probably have a delay feature, but I was hoping to avoid any additional electronic pieces or weight.
Thanks for your help.
John T.
jptonks is offline Find More Posts by jptonks
Old Jan 07, 2012, 04:11 PM
pilotpete2 is offline
Find More Posts by pilotpete2
pilotpete2's Avatar
The Northeast Kingdom, Vermont
Joined Jun 2004
If these are electric retracts with the motors built in, then they cannot be slowed down, except by running on lower voltage. The ones I've seen run at a very scale speed.
Mechanical retracts operated by a servo are also normally not able to have the speed controlled from the radio. Spektrum does make a very high torque proportional retract servo that can be slowed from the radio.
Pete
pilotpete2 is offline Find More Posts by pilotpete2
Discussion Problem with P40- Engine slowing down at full throttle thercguru Power Systems 21 Sep 18, 2011 04:21 PM
Discussion Slowing down retracts victor hull Flight Accessories 21 Sep 18, 2007 08:08 AM
Slowing down retract speed JayParke Electric Plane Talk 8 Apr 19, 2002 08:18 PM
