Old Dec 18, 2011, 03:43 PM
Flyer103 is offline
Find More Posts by Flyer103
Flyer103's Avatar
United States, GA, Maysville
Joined Oct 1999
suggestions on cleaning and restoration
Hi Folks,
I have several old Testors 049s and I thought it would be neat to crank one up and maybe even build an airframe for it. They've been sitting many years and I was wondering if anyone out there might have some suggestions as to the best way to clean this type engine and otherwise get it ready for running. The engine turns over freely and seems to have good compression.
Any thoughts are greatly appreciated. Many thanks in advance!
Gene
Flyer103 is offline Find More Posts by Flyer103
Old Dec 18, 2011, 04:27 PM
Pinecone is offline
Find More Posts by Pinecone
Will fly for food
Maryland
Joined Sep 2004
Use heat to get it moving. COvering gun or hair drier. A true heat gun can be used with caution.
Once you can move, use solvent or fuel to clean out old castor oil. If you use solvent, oil immediately after cleaning.
Pinecone is offline Find More Posts by Pinecone
Old Dec 19, 2011, 09:54 AM
Flyer103 is offline
Flyer103's Avatar
Joined Oct 1999
Pinecone,
Thanks. Should the entire engine be soaked in the fuel or solvent or perhaps just used as a cleaner with a Q-Tip?
Gene
Old Dec 26, 2011, 07:57 AM
Pinecone is offline
Will fly for food
Maryland
Joined Sep 2004
I heat to get things moving, then drip some fuel into the intake and exhaust.
Flip and repeat.
Same with the solvent, you are trying to get solvent (or the alcohol in the fuel) into the engine to dissolve the old caster oil.
Old Dec 27, 2011, 01:24 PM
xenalook is offline
Find More Posts by xenalook
www.coxinternational.ca
xenalook's Avatar
Joined Mar 2008
Here is a link to a handy guide:
http://coxengines.ca/CMG.pdf
Bernie
xenalook is offline Find More Posts by xenalook
Old Dec 27, 2011, 03:21 PM
Flyer103 is offline
Flyer103's Avatar
Joined Oct 1999
Excellent. Thanks!
Discussion Dynam A10 rolls/bank on one side in straight flight. Please Help. suggestions? tydfidelis Electric Plane Talk 10 Dec 30, 2012 09:39 PM
For Sale The fall-cleaning cheap sale. *Prices Updated on 11-14* pdiddyg40 Non R/C Items (FS/W) 19 Nov 11, 2011 08:07 AM
Discussion Need suggestions on reattaching nut to fuselage on Dynam Sky trainer older version. iquench01 Beginner Training Area (Aircraft-Electric) 2 Oct 10, 2011 02:29 PM
Discussion Any suggestions on motor/esc/prop/battery for indoor models? mikempp Scratchbuilt Indoor and Micro Models 5 Sep 15, 2011 04:31 PM
For Sale Spring cleaning on Blade mCP X RTF & BNF twoplanekid Aircraft - Electric - Helis (FS/W) 5 May 02, 2011 10:36 AM
