Old Aug 20, 2003, 04:29 AM
_shadow_ is offline
Find More Posts by _shadow_
RC Mad
Kuala Lumpur, Malaysia
Joined Jun 2003
IFO MK3 - Rudder Mod
Guys,
I need some help, I'd like to add rudder to my IFO MK3. I have done some research and found out the rudder has a LOT of adverse yaw effect.
My question is, to all who have done the same mod, how much throw can I set to minimize this effect and yet have good rudder authority.
Thanks to all.
Regards
Marcus
_shadow_ is offline Find More Posts by _shadow_
Old Aug 20, 2003, 08:34 AM
mbcone is offline
Find More Posts by mbcone
Albuquerque Intl, New Mexico, United States
Joined Jun 2003
Depending on how you set up your control throws, it is best just to make it adjustable. If you are using a control horn, you can always switch holes. If you are using heat shrink, start with a 1 inch cf rod at the rudder. I use around 45 degrees, and will be making a larger rudder soon. - Brian
mbcone is offline Find More Posts by mbcone
Old Aug 20, 2003, 03:22 PM
Jet Mechanic is offline
Find More Posts by Jet Mechanic
and 3D flyer
Southern NH
Joined Aug 2003
wouldn't if the entire Virtical stab moves as a rudder be easier.
I came up with modifying the front tube conector (on the frame) for the rudder to be virtical and adding a vertical rod to the vertical stab with a control horn. And then just forget about the rear tube conection, and you have a rudder.
Jet Mechanic is offline Find More Posts by Jet Mechanic
IFO MK3 Moveable Rudder Questions Bob Smith Parkflyers 0 Oct 31, 2004 08:26 AM
IFO Mk3; RUdder and brushless mods rcav8r2 Parkflyers 11 May 25, 2004 03:31 PM
Ifo Mk3 Separate Elevon and Rudder, 85% Questions dadspet Parkflyers 3 Oct 30, 2003 08:38 PM
IFO mk3 battery and rudder Qs Ade Scratchbuilt Indoor and Micro Models 7 Aug 08, 2002 02:27 PM
what motor combo is best for IFO mk3 and mini. Paul15 Parkflyers 4 May 12, 2001 12:57 AM
