Old Apr 25, 2005, 02:44 AM
CactusJackSlade is offline
Find More Posts by CactusJackSlade
Whadda YOU lookin' at?
CactusJackSlade's Avatar
United States, CA, Folsom
Joined May 2002
In flight spar failure w/onboard video - DOH!
If you have followed my "Depron Dragon" threads you might remember I had the original goal to use all depron in the wings - even for the main spar... well after my in-flight wing failure (many months ago) I ended up installing a bit of CF the full length of the center panel to prevent this from occuring again.
I've had dozens of fully laiden flights since, even in horrendously bumpy conditions (Moab - Arches Nat'l) and I've had no worries about the wing now...
Anyway, I'm just getting around to posting the "spiral of death" that occured when the all depron spar failed in a medium-g turn... probably my 3rd flight with the "Dragon" fully loaded...
Fortunately and surprisingly no damage was done to any of the electronics or camera eqt... I think the spinning slowed the descent way down!
Check it out: http://www.foaminfusion.com/VideoClips/SparFailure.mpg
CJS
CactusJackSlade is offline Find More Posts by CactusJackSlade
Old Apr 25, 2005, 03:13 AM
RCFEVER is offline
Find More Posts by RCFEVER
Team HeliProz
RCFEVER's Avatar
Saint Clair, MI
Joined Jan 2004
What was your AUW at that time?
RCFEVER is offline Find More Posts by RCFEVER
Old Apr 25, 2005, 03:15 AM
Joined May 2002
about 45 ounces... now with a little CF in the spar I can carry MUCH more than that! :-)
Old Apr 25, 2005, 11:50 AM
Myron is offline
Find More Posts by Myron
RCAPA #14
Myron's Avatar
United States, TX, Wimberley
Joined Mar 2004
DUDE!!!... Man that was ugly!.. Sorry to see that... I had one of those but I didnt have the video system running at the time... How much $$ did you loose?
Myron
Myron is offline Find More Posts by Myron
Old Apr 25, 2005, 12:07 PM
Daniel G is offline
Find More Posts by Daniel G
It's been a while.
Daniel G's Avatar
Irvine, CA
Joined Jan 2005
Myron
He lost nothing at all.
Daniel G is offline Find More Posts by Daniel G
Old Apr 25, 2005, 12:35 PM
Joined May 2002
A little wing repair time was all... :-)
Old Apr 25, 2005, 12:47 PM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
Back when I was flying Wakefield rubber powered models..
"How many turns do I put in the motor?"
"Wind it 'til it breaks, then back off a turn."
Sparky Paul is offline Find More Posts by Sparky Paul
Old Apr 25, 2005, 01:12 PM
Randy Due is offline
Find More Posts by Randy Due
Am I registered?
Randy Due's Avatar
Chandler, Tx. USA
Joined May 2003
I'm dizzy now. It's good that nothing was lost...... and you did get that really cool video out of it!
Randy
Randy Due is offline Find More Posts by Randy Due
Old May 01, 2005, 12:30 PM
evermax is offline
Find More Posts by evermax
MasterBlaster
evermax's Avatar
New Jersey Exit 7A
Joined Jan 2005
Jack,
Sorry to hear about the crash but Im glad you are back and running.
I have hung up the pinkfoam and order a bunch of depron and carbon.
I build a small section and can't believe how strong it gets when builtup as opposed to how week it feels in sheet form. But anyway when you get a chance I have a couple question since we seem to have about the same Video and Photo payload. Probable will help others as well since many seem to be following your lead and we are all carring some payload.(Thank You)
Did your original spar have any carbon?
What size carbon did you add, and I assume you added to just the center panel?
Did you cap the spar top and bottom or just one side?
I have tryed several glues CA/bakingsoda,Gorilla,Epoxy, all seem stonger than the depron, What did you use on yours?
Did you use 2mill for everything in the wing except 6mill grey spar?
Last one. Wing rods I got are 1/8 solid carbon and 3/16 carbon tubes with 1/8 ID for the joiners. Is that about the right size. Believe you had used metal tubes, do you think that would work better than carbon tube? Not sure about the split strength of the cabon tubes.
Thanks Again
Evermax
evermax is offline Find More Posts by evermax
Old May 01, 2005, 12:51 PM
JettPilot is offline
Find More Posts by JettPilot
JettPilot's Avatar
Miami
Joined Apr 2005
Really cool video Cactus Jack !!! That was video was well worth the repair time it took .
I have always liked the picture you use of the little dog about to rip someone to shreads, there has to be a story behind that too
JettPilot is offline Find More Posts by JettPilot
Site Sponsor
In-flight structural failure of a "Cermark Breeze"!! spitfirem9 Electric Plane Talk 3 Jul 20, 2004 02:32 PM
HL Tiger Diablotin In Flight Elevator Failure rharazin Foamies (Kits) 54 Nov 17, 2003 05:02 PM
In flight motor failure barry r killick Power Systems 2 Jul 24, 2003 04:45 PM
Tiger Moth In Flight Power Failure cubsflyer Foamies (Kits) 2 Jan 31, 2003 03:56 PM
Tiger Moth In Flight Power Failure cubsflyer Parkflyers 2 Jan 31, 2003 03:38 PM
