Old Nov 03, 2004, 12:02 AM
GalantVR4 is offline
Find More Posts by GalantVR4
Electric Relaxation
GalantVR4's Avatar
Chicago, IL
Joined Jan 2004
Himax 5.33 gear box, what prop?
After a recent crash and damage to my Himax 6.60 gear box, I have been forced to switch to the 5.33. At this time I am using an APC 10x7 prop. It seems to power my GWS MUstang ok, but doeas anyone know if this is the best prop for this gear ratio? The setup I have is a 14oz GWS Mustang, 5.33 gear ratio on a Himax 2015-4100, and a 3 cell 1320mah Thunder Power lipo. I would use Motocalc, but my subscription has run out.
GalantVR4 is offline Find More Posts by GalantVR4
Old Nov 03, 2004, 10:38 AM
Electric Relaxation
GalantVR4's Avatar
Chicago, IL
Joined Jan 2004
Would a 10x5 prop be best for this setup?
Old Nov 03, 2004, 10:46 AM
pda4you is online now
Find More Posts by pda4you
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
I would start with the GWS 10x6 HD prop - not the slow-flier! That should keep your amp draw in the 9-10amp range.
pda4you is online now Find More Posts by pda4you
Old Nov 03, 2004, 10:49 AM
Electric Relaxation
GalantVR4's Avatar
Chicago, IL
Joined Jan 2004
Are the GWS HD props better than the APC props I am using? The thing I did not like about the GWS props is how they bend and flex.
Old Nov 03, 2004, 11:13 AM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
GWS RS props are very flimsy, but the GWS HD series are about as robust as the APC SF's (perhaps even better because they are a bit less brittle).
Dr Kiwi is offline Find More Posts by Dr Kiwi
variable pitch prop on Himax with GWS gear box curtqn 3D Flying 3 May 07, 2005 10:06 PM
Hacker b20 22s with 4:1 gear box what prop? RickC2009 Power Systems 0 Sep 10, 2004 12:19 PM
hacker c40 12s with a 5.0 gear ratio what prop should i use please help falcon41176 3D Flying 7 Apr 02, 2004 03:56 PM
should a fella use a 4:4 or a 5:1 gear box ? earnest High Performance 0 Mar 05, 2003 12:56 PM
Speed 400 gear box / APC prop tests & help? hardlock Power Systems 2 Dec 11, 2001 11:58 AM
