Old Nov 01, 2014, 09:51 AM
stgilmer1 is offline
Find More Posts by stgilmer1
United States, GA, Brooks
Joined Oct 2013
Help!
Will this head work on Blade 450 3d to fbl??
I am wanting to convert my 450 3d over to fbl, but blades conversion is still $92. I am looking for a setup that will be a direct bolt up without having to do mods. Came across this one from CNC, will it work is my question?
http://www.cnchelicopter.com/trex-t-...s-head-system/
If not then are there any that will? I just don't see spending high$$ on a discontinued bird. Thanks
stgilmer1 is offline Find More Posts by stgilmer1
Old Nov 01, 2014, 05:12 PM
Reid Williams is offline
Find More Posts by Reid Williams
United States, LA, Shreveport
Joined Jan 2009
I put this head on my 450 and it is great. Perfect fit.
http://www.ebay.com/itm/F001-Freeshi...item232e0bcb42
I spot checked 2 ball link bolts for thread locker and assumed the entire head was thread locked. It was not. Be sure to check every part. This head and a KBar gyro completely changed how this heli flies.
Reid Williams is offline Find More Posts by Reid Williams
Site Sponsor
Old Nov 01, 2014, 05:42 PM
Joined Oct 2013
Good looking setup, so will any 450 brand head fit all? Thats what i am trying to understand also for future reference. I was always under the thinking that only blade parts fit blade. By the time i add up all parts from a 450x i am over $100 kinda ridiculous for a 450 head. IMHO, which makes no sense because all parts from 500x to convert my 500 3d is about $60.
So you put that head from ebay on a Blade 450 3d, just making sure before i decide to buy. You prefer kbar over zyx? I have had good flying with the zyx and had planned on going that route again.
Old Nov 01, 2014, 05:59 PM
Joined Jan 2009
Wait. I cannot say about Blade.
I can tell you that the Ebay head fits my CopterX/TRex 450. The main shaft is the exact diameter and length. The links are the proper length.
My question would be "does align main shaft specs match blade's?"
Best, RW.
Site Sponsor
Old Nov 01, 2014, 06:01 PM
Joined Jan 2009
About the gyro. Can't compare. My only experience is with this and an authentic AR7200BX. I really like the KBar.
Site Sponsor
Old Nov 01, 2014, 07:44 PM
Joined Oct 2013
Thanks anyways on the gyro recommendation. Hopefully someone else will know about the Blade 450 3d conversion.
Old Nov 01, 2014, 08:43 PM
Joined Jan 2009
Ok, found something maybe helpful.
In the blade 400 forum on the HF site, 6/13/09 you will see "trex 450 head and tail on blade 400"
I know you have the 450, but I would bet the compatability is there.
Site Sponsor
Old Nov 01, 2014, 08:58 PM
Joined Oct 2013
Somewhere on this forum i read that a head had to be modded, jesus bolt hole didnt line up. For the life of me i cant find it to get the brand..that was why i started this thread to begin with. That wouldn't be much of a mod but i hoped to do no modding if possible.
Old Nov 01, 2014, 09:22 PM
Joined Jan 2009
I'll measure my spare main shaft tomorrow and give the measurements.
On ebay there is a seller that is offering new align trex 450 plus dfc airframes for 99.
Site Sponsor
Old Nov 01, 2014, 10:09 PM
Joined Oct 2013
Not the time to start a new bird, hobby room is filled already.
And i appreciate the help.
Old Nov 01, 2014, 10:17 PM
Roto Rob is online now
Find More Posts by Roto Rob
Denver, CO
Joined Dec 2005
You just grind, or sand a few mm off the end of the shaft, until the Jesus bolt hole lines up. How much depends on how deep they drilled the hole.
Roto Rob is online now Find More Posts by Roto Rob
Old Nov 02, 2014, 11:18 AM
Joined Jan 2009
Align shaft.
Site Sponsor
Old Nov 02, 2014, 10:17 PM
Joined Oct 2013
Align shaft.
Cant really see the numbers on your ruler but this is what i know of the Blade450 3d and Blade 450x mainshaft
450X main shaft. 130.12mm. (5.123") Pn. BLH4347. ( flybarless)
Bottom of shaft to machined step/ring/ridge/shoulder 72.83mm (2.8675")
B450 3D main shaft 133.77mm (5.2665") Pn. BLH1647 (fly barred)
Bottom of shaft to machined step/ring/ridge/shoulder 72.75mm (2.8645")
Old Nov 04, 2014, 05:55 PM
Joined Jan 2009
Total shaft is 11.5mm. Pin hole on right is 3.5mm. Pin hole on left is 2.5mm. Collar shoulder is 5.9mm from left end.
Site Sponsor
Old Nov 04, 2014, 07:02 PM
Joined Oct 2013
Idea I Wonder if this will work... RCWorks Life, The Universe, and Politics 20 Sep 30, 2014 04:00 AM
Discussion Will a AR6100e receiver work in the Blade 450 3D? rwek 3D Electric Heli Flying 1 Jul 02, 2014 11:04 PM
Discussion WIll this power set-up work for this airplane for 3D? SubaruMike 3D Flying 8 Jul 01, 2013 05:23 AM
Discussion Will an EXI 450 belt tail work on a Tarot 450 FBL? kbohip Beginner Training Area (Heli-Electric) 1 Jul 25, 2012 06:33 PM
Found WTT 450 Sport FB Head for 450 Pro FBL Head SYMAWD Aircraft - Electric - Helis (FS/W) 0 Apr 11, 2012 07:27 PM
