Old Jul 15, 2014, 02:47 PM
rcflyinff is online now
Find More Posts by rcflyinff
rcflyinff's Avatar
United States, FL
Joined Mar 2012
Thunder Tiger 40
So I picked up this Tiger Trainer 40 with a GP or Pro 40 on it. It is 20yrs old and has never seen a drop of fuel. Finally got it started, but the weird thing is it only runs with the needle valve all the way in and the throttle wide open I noticed raw fuel coming from the exhaust, so when the engine stalled, I picked up the plane and drained a crazy amount of fuel from the exhaust This happened multiple times. The fuel lines are connected correctly. Anyone have any clues on what might be happening? Thank you in advance for your help.
rcflyinff is online now Find More Posts by rcflyinff
Old Jul 15, 2014, 04:27 PM
Brutus1967 is online now
Find More Posts by Brutus1967
I convince things to work
The Netherlands
Joined Nov 2009
Did you check if the needle valve seats when it is turned all the way in?
Most likely something preventing the needle from seating, so even if the needle won't turn any further, the valve is still too far open...
Brgds, Bert
Brutus1967 is online now Find More Posts by Brutus1967
Old Jul 15, 2014, 08:48 PM
rcflyinff's Avatar
United States, FL
Joined Mar 2012
Not yet Brutus. My buddy mentioned the same thing. Sounds like a very likely cause. I assumed it being a brand new engine, it would come ready to run from the factory. Won't be able to check till tomorrow evening at the earliest. I will post my findings. Thank you for your suggestion.
Old Jul 15, 2014, 09:27 PM
JC Johnson is offline
Find More Posts by JC Johnson
Joined Sep 2011
These engines (GP40) are as good as the FP 40s ... parts are interchangeable... the 40D and 3A carb will work perfectly on this engine.
You have something simple going on here... the carb can be taken apart and put back together in a 1/2 hour...
JC Johnson is offline Find More Posts by JC Johnson
Old Jul 16, 2014, 04:57 AM
Lifer is offline
Find More Posts by Lifer
Kansas City
Joined Apr 2010
Do you have the fuel and pressure line reversed?
Lifer is offline Find More Posts by Lifer
Old Jul 16, 2014, 09:27 AM
ahrma_581 is offline
Find More Posts by ahrma_581
Ricinus communis
ahrma_581's Avatar
United States, AZ, Ajo
Joined Jun 2012
Depending on whether it is a GP or Pro, it will have an airbleed or a two needle carb. If it is a Pro, mebbe the lo-speed needle is backed way too far out?
Edit: altho that wouldn't have anything to do with high speed being run in all the way. Possibly a couple of things are off/clogged, not just one.
ahrma_581 is offline Find More Posts by ahrma_581
Old Jul 16, 2014, 04:31 PM
Joined Sep 2011
The more I read your post, Lifer may be right... it could be a gas tank issue.. also check to see if the clunk in the tank is free and at the back bottom . The first time this happened to me was on a hard landing.. the clunk was sent forward from the impact... the fuel lines were not changed so it baffled me at first. Start from scratch... start the engine with just a prime... after checking the tank... fill it half full... flip a few times to "prime" the carb... disconnect the pressure line from the carb... start it... there should be no reason raw fuel is getting in the carb now...
Old Jul 16, 2014, 05:29 PM
rcflyinff's Avatar
United States, FL
Joined Mar 2012
Got her fired up and running good For some reason, the needle valve was extremely hard to thread all the way in, but I got it and she's running good. Thank you all for your replies.
Sold Thunder Tiger PRO .40 and Thunder Tiger GP .42 Tetex79 Aircraft - Fuel - Engines and Accessories (FS/W) 3 Jun 20, 2014 09:07 AM
Sold TT .40 Great planes Thunder tiger 40. Oldie but goodie TexasMark Aircraft - Fuel - Engines and Accessories (FS/W) 5 Jun 02, 2014 02:57 PM
For Sale Nib Como/Thunder Tiger .40 FlyerMan4Life Aircraft - Fuel - Engines and Accessories (FS/W) 3 Apr 21, 2014 05:18 PM
Discussion Thunder Tiger 40 pro question two-stroke Pylon Racing 49 Nov 23, 2013 09:50 PM
Sold OS-LA 40's,thunder tiger 40 and thunder tiger 25 motorhead540 Aircraft - Fuel - Engines and Accessories (FS/W) 3 Jun 03, 2010 09:27 AM
