Old Dec 06, 2013, 09:29 PM
lectroglide is offline
Find More Posts by lectroglide
lectroglide's Avatar
United States, WA, Puyallup
Joined Aug 2006
Question
Het 4w sagging
just picked up a used HET 4w and ran it for the 1st time , hooked up a 3S 2200 @ around 11.4 V and a 55A esc 6X4 APC .....throttled up and the motor wound up then started sagging around max throttle, could that be the timing or is their something else goin on? I don't know where the timing is right now
lectroglide is offline Find More Posts by lectroglide
Old Dec 07, 2013, 07:33 AM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
What is the Kv on that motor? If the Kv is high enough it may be that the permutation rate needed to run the motor is too high for the ESC to handle.
If you put the ESC on it's highest timing setting it may change things and too.
Jack
jackerbes is offline Find More Posts by jackerbes
Old Dec 07, 2013, 03:52 PM
Joined Aug 2006
haven't hada chance to check the KV but b4 going to all that work hooked up a hot 4S and that took care of the problem so think were good
Old Dec 08, 2013, 08:48 PM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
Unglued??
Best check it over .. with care.
Regarded by some as a Perf motor... It nonetheless is 'Fabrique en Chine' with IMO sketchy QC issues .
Bare is offline Find More Posts by Bare
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
Until we know exactly which HET 4W you have we are guessing!!!!
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Dec 09, 2013, 12:51 PM
Joined Aug 2006
Originally Posted by Bare View Post
Unglued??
unglued.........as in "it came to life
Old Dec 09, 2013, 02:56 PM
Joined Aug 2006
For Sport aerobatics up to 1300 grams. The 4W is suitable for HET EDF unit 6904 or WeMoTec 480 mini fan.
◾Diameter: 28 mm
◾Length: 38 mm
◾Shaft Dia.: 3.17 mm
◾Li-Po:3-4S
◾Weight: 78 grams
◾No load current(lo): 1.94
◾Internal resistance: 0.013
◾KV: 2250
◾No. of poles: 6
◾Max Current: 30 A
◾Max efficiency: 88%
◾Power Nominal: 450 Watts
◾Recommended Props: APC E 6.5 X 4 or 7 X 4 (3s Lipo Only
it sez 3S for above props but think if I prop down it might be ok on a 4S on a zagi type wing
Old Dec 09, 2013, 03:33 PM
Jack
USA, ME, Ellsworth
Joined May 2008
With 6 poles (magnets) it must be a 9 arm stator and wound ABCABCABC, you can't have 6 poles on a 12N motor. And at the 450W nominal they say it is good for it would be at 7.6W per gram. I wonder if it is that good or not?
Jack
Old Dec 09, 2013, 07:39 PM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
If you are going to adhere to the 30A max, then even 6x4 on 3s might take you close to that.. (78g @ 3W/g is only 234W max.).........for 4s you will definitely need to run a tiny prop
Old Dec 10, 2013, 09:54 AM
FormulaZR is offline
Find More Posts by FormulaZR
United States, TX, Lubbock
Joined May 2008
Is it possible the 3S battery you are using doesn't have enough discharge capability for this motor?
I had a similar problem with a completely different motor/esc combo. A change to a lipo with a higher C rating cured it.
What is the C rating your 3S, and how many amps was the motor pulling?
FormulaZR is offline Find More Posts by FormulaZR
Old Dec 10, 2013, 03:20 PM
Joined Aug 2006
it was just a cheapo low C rating lipo so was prolly most of the problem.I have not had time to get any readings. what I need to do is charge up a decent high C 3S bat then do some testing, the 4S will be a bit scary to get any readings
Old Dec 10, 2013, 03:47 PM
Joined May 2008
I would try that. It certainly cleared up my problem, anyway.
Did it make full rpm for a second, and then back off...or did it never hit full rpm? If it hit full, then backed off - that does sound like a battery problem.
Did it surge at full throttle?
Old Dec 10, 2013, 04:40 PM
Joined Aug 2006
haven't got to it yet
Old Dec 10, 2013, 06:29 PM
Joined May 2008
I meant with the 3s you tried first...
Old Dec 10, 2013, 09:44 PM
Joined Aug 2006
yes
Wanted Want to trade HET 4w for HET 3w Piledriver Aircraft - Electric - Power Systems (FS/W) 0 May 28, 2008 06:20 AM
Discussion MiniFan 480 with HET-RC EDF-4W bgijsber Electric Ducted Fan Jet Talk 7 Feb 21, 2007 09:57 AM
Sold HET Typhoon 4W Brushless Motor jkravitz7695 Aircraft - Electric - Power Systems (FS/W) 2 Aug 17, 2006 10:18 PM
Discussion Het 2w/4w Source? pulquijet Foamy EDFs 3 Aug 01, 2006 06:55 PM
Discussion het-rc typhoon 4w toyotatruckin Power Systems 0 Jan 24, 2006 08:04 PM
