Old Jul 26, 2013, 02:17 PM
JebSmith is offline
Find More Posts by JebSmith
Joined Apr 2013
Naza light return to home when signal lost
Is there any way to get the naza light to return to home when the TX signal is lost? I am using a DX7s and an AR6000
I would love to stop going out of range and crashing.
JebSmith is offline Find More Posts by JebSmith
Old Jul 26, 2013, 02:22 PM
flboy286 is offline
Find More Posts by flboy286
Up, Up & hopefully away!!
flboy286's Avatar
United States, FL, Volusia County
Joined May 2013
Failsafe mode
If your transmitter supports failsafe, then you can set failsafe through port-U. Naza controller has built-in auto level failsafe function, which means when the communication between MC and the transmitter is disconnected, the outputs of all command sticks from controller will go to center position. If the GPS module is used, you can also set RTH on failsafe. If your transmitter has only 4 channels, then MC will work in Atti. Mode by default without the failsafe function.
flboy286 is offline Find More Posts by flboy286
Old Jul 26, 2013, 02:23 PM
Jodde73 is offline
Find More Posts by Jodde73
Jodde73's Avatar
Stockholm
Joined Sep 2009
Off course, google rc failsafe and check the AR6000 manual how to program it. Normally you just push a button on the rx to "teach" it what to do when loosing signal. Put the 3-pos switch in rth position and set the failsafe. Been saving me many times on multis and fixed wing aircraft.
Jodde73 is offline Find More Posts by Jodde73
Old Jul 26, 2013, 02:33 PM
Empire Support 3 is offline
Find More Posts by Empire Support 3
Empire Hobbies Support
Joined May 2013
Ar6000 does not support true failsafe. It only allows programmable throttle position.
Empire Support 3 is offline Find More Posts by Empire Support 3
Old Jul 28, 2013, 11:44 AM
JebSmith is offline
Joined Apr 2013
programmable throttle position? Can you explain this a bit on how to do it? Still new here...
Or maybe could I purchase a different spektrum receiver?
Old Jul 28, 2013, 12:11 PM
JebSmith is offline
Joined Apr 2013
looks like after everything is bound properly and running correctly I start the bind process again. However this time, I insert the bind plug, power on the RX then remove the bind plug. Then position my throttle where ever I want the failsafe loss of signal to be. Then power on the transmitter like normal for binding.
This sound correct?
Old Jul 28, 2013, 01:09 PM
JebSmith is offline
Joined Apr 2013
Well that worked. I have it set to hover with signal loss.
I want to get a spektrum receiver that has the better failsafe, maybe the ar7010. Thoughts?
Help! NAZA + GPS Failsafe RTH when signal loss (FrSKY) Peter1987 Multirotor Electronics 2 Jun 11, 2014 03:48 PM
Discussion esc goes full throttle when signal lost Brother Bob Power Systems 0 May 18, 2013 12:06 AM
Discussion NAZA return home OK - how to regain manual control? CactusJackSlade Multirotor Electronics 4 Mar 13, 2013 02:55 PM
Help! Naza appears to have lost motor output signal Mrloudly Multirotor Electronics 2 Mar 09, 2013 01:14 PM
