Old Aug 14, 2013, 04:28 PM
AES256 is offline
Find More Posts by AES256
Joined Jul 2013
What do you guys think about adding a repo for the GUI to the github?
AES256 is offline Find More Posts by AES256
Old Aug 14, 2013, 04:33 PM
Tom Frisch is offline
Find More Posts by Tom Frisch
Portland, OR, USA
Joined Mar 2010
Hey Alan, you should add the warning about lipo while flashing to your signature, save you having to type it over and over.
Tom Frisch is offline Find More Posts by Tom Frisch
Old Aug 14, 2013, 04:35 PM
aadamson is offline
Find More Posts by aadamson
United States, GA, Atlanta
Joined Dec 2010
Sure we can, but I'm not a GUI expert if some one wants to create an initial environment and send it to me, I'll create the repo for it.
Alan
aadamson is offline Find More Posts by aadamson
Old Aug 14, 2013, 04:37 PM
aadamson is offline
Joined Dec 2010
I noticed the AeroQuad is using a 168 mhz F4, much like Alan has spec'd for a future Evvgc iteration. I suppose if the routine is too heavy for the current MCU, going up to the F4 should make it viable?
I'm not knowledgeable about those types of algorithms, but I have a couple thoughts on the issue of lateral accelerations skewing the attitude solution. On other closed-source gimbal solutions, I've seen two features that can be helpful: 1) the ability to adjust accelerometer influence on the overall algorithm on a sliding scale 2) the ability to temporarily disable the accelerometers' influence on the computation while a yaw command is being issued by the operator. Since lateral accelerations are often accompanied by a yaw input, this can be helpful, at the cost of a bit of gyro drift.
I think there is plenty of headroom in the F1 for this, i2c is a killer, but all of this runs on an 8mhz(maybe 16mhz) 32k AVR.... ... I mostly want an F3/F4 for the hardware floating point, but its not required...
Alan
aadamson is offline
Joined Dec 2010
Yeah, really!
Old Aug 14, 2013, 05:42 PM
georgskt is offline
Find More Posts by georgskt
Joined Aug 2013
hello, is there a step by step guide how to install and configure EvvGC 3 axis? and what parts should I buy to run ... can someone help??
georgskt is offline Find More Posts by georgskt
Old Aug 14, 2013, 05:58 PM
jy0933 is offline
Find More Posts by jy0933
James not bond
jy0933's Avatar
Joined May 2012
just heard from AirBot. they are putting down the site for maintenance for 24h...
jy0933 is offline Find More Posts by jy0933
Old Aug 14, 2013, 06:19 PM
jihlein is online now
Find More Posts by jihlein
Albuquerque, NM
Joined Aug 2002
On the F4, I can run the MARG algorithm and flight controls at 500Hz, with a mix of I2C and SPI sensors. I have an F3 board that also runs the same code at 500 Hz, but it uses all SPI sensors. And finally, the same code runs at 200 Hz on an F1, with I2C sensors.
So as Alan said, the I2C sensors extract quite a penalty. I don't have a good feel for how fast the brushless gimbal needs to execute. I can probably push MARG on the F1 to 250 Hz since I'm getting rid of the pressure sensor in the gimbal configuration. I'd still like to keep the mag, I need it for some things I want to do with a gimbal
And for DT accuracy, I use a spare timer to compute frame to frame DT. I don't know if the evvGC hardware has a spare timer to do this or not.
jihlein is online now Find More Posts by jihlein
Old Aug 14, 2013, 06:37 PM
aadamson is offline
Joined Dec 2010
It does
Old Aug 14, 2013, 07:26 PM
Portland, OR, USA
Joined Mar 2010
What is the price difference between F103 F3 and F4 chips?
Seems like getting away from i2c and moving to SPI is something we might want to do in v2?
-Tom
Old Aug 14, 2013, 07:43 PM
aadamson is offline
Joined Dec 2010
-Tom
F405 or 415 is $11.80
F3 is in the middle, but it's only a 256k part and still 72mhz, but on the cortex m4 core and with hardware floating point, plus a few other things *fixed* against the f1 and some against the f4.
F103 is $8.20
so you see in the grand scheme of things the F4 isn't that expensive and it has 1M flash in those parts and the cortex m4 core with hardware floating point (albiet single precision). Plus with either F3 or F4 we get usb bootloader built in and wouldn't have to worry about this stupid serial port thing that I keep harping on ...
BTW the F1 has SPI too, it just wasn't brought out on pins for usage. And to use SPI you'd use the MPU 6000 instead of 6050 (it's i2c only, the 6000 is either or both spi or i2c).
Alan
Old Aug 14, 2013, 07:51 PM
Portland, OR, USA
Joined Mar 2010
That's what I suspected, I don't see a good reason to stick with the F103 for v2.
As usual, I'm getting way ahead of myself. I haven't even assembled v1.3 yet!
-Tom
Old Aug 14, 2013, 07:54 PM
aadamson is offline
Joined Dec 2010
-Tom
I broke down and ordered my stencil today... normally I just do it with dobs of solderpaste, but I hate having to fix the processor doing it that way.... this time I'll do it with stencil...
Hmm, now I need solder paste and a squeegy (sp)...
Alan
Old Aug 14, 2013, 08:02 PM
Portland, OR, USA
Joined Mar 2010
If you find that solder stencil tutorial I posted a while back, they mention some alternatives to the expensive solder paste squeegee, but I can't remember what it was.
Old Aug 14, 2013, 09:58 PM
DionPaz is offline
Find More Posts by DionPaz
Joined Aug 2013
Hi everybody,
I just jumped on this wagon, so I am new to everything. Could anybody advise me about which battery I should buy for this controller? I would highly appreciate the help.
DionPaz is offline Find More Posts by DionPaz
Discussion Open Source Brushless Gimbal edge0xc Multirotor Electronics 3072 Feb 28, 2015 04:00 AM
Idea Open Source Gopro Brushless Gimbal icais Multirotor Talk 16 Mar 28, 2014 12:07 PM
Discussion SkyLight SBG - GoPro 2 Version Released (+ GP3 Beta + 3 axis Alpha) !! ed_jza80 Multirotor Talk 494 Jan 03, 2014 10:09 AM
Sold open source brushless gimbal controller jy0933 Aircraft - Electric - Multirotor (FS/W) 57 Mar 26, 2013 07:02 PM
Sold [closed] open source brushless gimbal controller jy0933 Aircraft - Electric - Multirotor (FS/W) 16 Feb 26, 2013 09:19 AM
