Old Apr 27, 2013, 12:38 PM
azdiane is offline
Find More Posts by azdiane
Addicted to lazy-flying models
azdiane's Avatar
United States, AZ, Chino Valley
Joined Apr 2013
Originally Posted by Curtis Suter View Post
Were their any accompanying elevator trim changes after installing the shims?
Curtis
Curtis, I flew it this morning and deliberately landed with the glide trim unchanged so I could look at the elevator position. The elevator is almost exactly level with the fixed stabilizer. If I recall, I had been using a bit of down elevator previously.
azdiane is offline Find More Posts by azdiane
Old Apr 27, 2013, 12:47 PM
Curtis Suter is offline
Find More Posts by Curtis Suter
Red Merle ALES
Curtis Suter's Avatar
United States, Mt, Helena
Joined Apr 2002
Makes sense, if the CG does not change and you change the angle if the main wing; leading edge down as you did, you will need an up elevator change. So effectively you have changed the angle the fuselage is flying.
Think relative wind and AoA.
Curtis
Curtis Suter is offline Find More Posts by Curtis Suter
Old Apr 27, 2013, 04:39 PM
azdiane is offline
azdiane's Avatar
Joined Apr 2013
By changing the angle of the fuselage I have also somewhat reduced the motor's effective downthrust, so the beast is a little harder to control in climb, but it's worth it for the nice smooth hands-off glide.
Old Apr 27, 2013, 05:21 PM
Red Merle ALES
Joined Apr 2002
If you have a computer radio you could assign an elevator mix to the throttle channel.
I am glad it is soaring better, that is what it is all about.
Curtis
Old Apr 27, 2013, 10:26 PM
target is offline
Find More Posts by target
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Or just shim the motor for a little more down thrust.
Glad its flying better; I suspected it would and could.
A success story!
R,
Target
target is offline Find More Posts by target
Discussion Dynamic pitch stability vs dynamic pitch instability aeronaut999 Modeling Science 16 Jul 29, 2013 01:25 PM
Discussion outdoor four channel fixed pitch heli hereathome Electric Heli Talk 24 Jan 05, 2013 11:15 PM
Help! 42 pitch spur m111kca Electric Power Cars 2 Jan 04, 2013 11:02 PM
Discussion Mixing arm level with blade pitch at 50% to be zero? feerof Beginner Training Area (Heli-Electric) 4 Jan 04, 2013 09:08 PM
Sold E-flite Pitch Gauge signal7 Aircraft - Electric - Helis (FS/W) 0 Jan 04, 2013 09:02 AM
