Old Jan 14, 2013, 09:47 AM
Sarboy is offline
Find More Posts by Sarboy
Sarboy's Avatar
Joined Mar 2010
Wire cutter power supply
I'm know there are lots of threads on these bit I'm still none the wiser.
I have a variable voltage and amperage power supply for my charger. I thought it would work for a wire cutter power supply. I have used it as power source but if the wire is more than 30cm long the temp is low and causes cutting to take forever or not cut at all.
The voltage shows 15v but with the ampage turned up it shows nothing. Why is this? Is it because there is no load?
What do I need to do to achieve a longer wire at a good temp? This is really bugging me.
Sarboy is offline Find More Posts by Sarboy
Old Jan 14, 2013, 09:53 AM
Ward Hagaman is offline
Find More Posts by Ward Hagaman
Ward Hagaman's Avatar
San Diego
Joined Mar 2003
A wire with a bigger diameter will require fewer amps to get to the same temperature, so you could try a bigger wire.
Ward Hagaman is offline Find More Posts by Ward Hagaman
Old Jan 14, 2013, 10:01 AM
Sarboy is offline
Sarboy's Avatar
Joined Mar 2010
Tried the biggest I have, .20 nichrome and still not good enough. Am I right in thinking the power supply should work? It's rated to 40 amps but it shows nothing when connected.
Old Jan 14, 2013, 10:46 AM
Harry D is offline
Find More Posts by Harry D
Since 1952
Harry D's Avatar
Canada, AB, Edmonton
Originally Posted by Ward Hagaman View Post
A wire with a bigger diameter will require fewer amps to get to the same temperature.
Not so. Exactly the opposite.
Harry D is offline Find More Posts by Harry D
Old Jan 14, 2013, 10:51 AM
kenh3497 is offline
Find More Posts by kenh3497
Live long and fly high
kenh3497's Avatar
United States, IA, Rockwell
Joined Jul 2011
DO NOT QUOTE ME.... I believe the longer wire needs a little more voltage. I see a lot of guys are running a 24 volt transformer.
Ken
kenh3497 is offline Find More Posts by kenh3497
Old Jan 14, 2013, 11:01 AM
slipstick is online now
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
If the PSU will cover up to about 20V and at least 5A and is has both variable voltage AND current it should be fine for any practical size of wire cutter I can think of, unless you're using some really odd wire. I often use a 20V 3A PSU but I only use about a 80cm max wire length.
But if it's really showing 15V and no current then either you don't have a good connection or you have the current limiter turned right down.
Steve
slipstick is online now Find More Posts by slipstick
Old Jan 14, 2013, 11:26 AM
Sarboy is offline
Sarboy's Avatar
Joined Mar 2010
Hmmm, maybe it's the connection. I have is 4 crocodile clips, two to the power supply and one at either end of the wire. I'm using speaker cable which is just striped and screwed to the clips. Should I solder it?
Old Jan 14, 2013, 11:47 PM
rph1225 is online now
Find More Posts by rph1225
Rob H
rph1225's Avatar
United States, MD, Rosedale
Joined Jul 2011
Ken
Maybe this will help, but I currently run a 12V transformer for a door bell through a dimmer and with 24ga Nichrome wire and have had great results. It usually runs at about 6V for blue insulation foam and slightly less for lightweight white foam. Also, my bow is 28" long.
I first tried Mig welding wire and it was too thick and required to much voltage to heat. Maybe try running a smaller gauge wire.
rph1225 is online now Find More Posts by rph1225
Old Jan 18, 2013, 07:32 AM
Sarboy is offline
Sarboy's Avatar
Joined Mar 2010
Thaks for all the help. I have been doing a little back to school electronics and think I have found my problem. This has been proven by experiment too.
If I pretend my wire is a resistor and by moving the crocodile clips along the wire I am making a variable resistor. If my voltage is 15v and I have my amps turned up to max, as I move the crocodile clips apart I will see the voltage remain the same but the amps start to reduce. This continues till the resistance is so high that the amps drop to zero.
That's the theory. So I put it into practice and it worked as described with the amps dropping to zero at about 60-65cm. This gives me a bow length of 50cm usable for 15v. So to increase the usable bow length you need to up the volts. Simple when you know.
To that end I'm looking at high volt power sources (24v). I recon this should do for a variable source:
http://www.roadking.co.uk/laptop-acc...l#.UPku8nwgGSN
Thanks again for the help.
Old Jan 18, 2013, 02:37 PM
Rob H
rph1225's Avatar
Joined Jul 2011
In your scenario, I think that you may have the amps changing in the wrong direction. If you separate the alligator clips then you are increasing the overall resistance of the wire, which would require more amps to generate the same amount of heat. Therefore, I would try and find a 12V transformer with a higher amperage capacity.
Old Jan 18, 2013, 02:56 PM
Staffs, UK
Joined Nov 2003
Nope, Sarboy has it right. Longer wire = higher resistance. Higher resistance and a fixed voltage = lower current. Basic Ohms Law I = V / R.
To get a fixed level of current through a longer wire requires MORE voltage.
Sarboy, it would be interesting to know what the currents actually are. E.g. what current do you see at 20cm ? At 40 cm ? Obviously the current can't possibly be zero at 60-65cm, so I guess whatever you're using to measure it can't register relatively low currents.
Steve
Old Jan 19, 2013, 02:42 AM
Sarboy is offline
Sarboy's Avatar
Joined Mar 2010
I'm off to work now for a 24 hour shift but I'll do a bit of research tomorrow and post findings if I get the time. My measuring equipment is just my power source. It's ok but only goes to 0.1 amp and I would guess has an accuracy of +-0.1. Not too bad but not great either. I should really invest in a descent amp/watt meter.
Old Jan 19, 2013, 03:23 AM
Staffs, UK
Joined Nov 2003
I don't know what's happening with your setup but you can always try this calculator to see what power supply you SHOULD need.
http://www.jacobs-online.biz/nichrome/NichromeCalc.html
Steve
Old Jan 23, 2013, 12:11 AM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
I built a PS last year and used this transformer. 24V 4A Just use a regular 120V .dimmer switch to regulate the power. My biggest bow is about 50".
http://www.jameco.com/webapp/wcs/sto...0001_221365_-1
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Jan 23, 2013, 02:21 AM
bbbp is online now
Find More Posts by bbbp
a.k.a. Bob Parks
Glendale, AZ
Joined Jun 2008
Dumb question, is your power supply AC or DC output?
bbbp is online now Find More Posts by bbbp
Question Hot Wire Foam cutter power supply richie967 Foamies (Scratchbuilt) 109 Feb 19, 2015 08:14 AM
New Product Hot Wire Foam Cutter Power Supply!!! mattius7 Foamies (Scratchbuilt) 2 Mar 01, 2013 07:40 PM
Wanted looking for a power supply for hot wire foam wing cutter joe_crash Aircraft - General - Miscellaneous (FS/W) 5 Dec 20, 2012 02:29 AM
Sold Hot-wire cutter variable power supply jim breese Aircraft - Sailplanes (FS/W) 1 Apr 13, 2012 12:48 AM
Power Supply Transformer, for hot wire cutter, or flight pack charging Salin Electric Plane Talk 1 Aug 25, 2002 03:38 PM
