Old Sep 27, 2012, 03:37 PM
henrymoro is offline
Find More Posts by henrymoro
henrymoro's Avatar
España, Cantabria, Miengo
Joined Jul 2007
Question
Setting up a F3X with Turnigy 9x
Hi dudes,
Im curious about if any of you have set up their F3X plane with a turnigy 9x.
I have a Futaba 12FG for my F3F planes and I am pretty happy with it, but I also own a 9x with er9x firmware and frsky module for my multicopters and just wonder if any of you had tried. I would not mind to try but the software looks a little bit scary to me
henrymoro is offline Find More Posts by henrymoro
Old Sep 30, 2012, 02:05 PM
Wing-span is offline
Find More Posts by Wing-span
Chuck it and see!
Wing-span's Avatar
UK, Cambridgeshire, Huntingdonshire
Joined Sep 2006
Hola,
Do you have a manual or is one available online for you to down load? You should be able to set it up to fly a 4 servo wing but it is the crow or butterfly mixing you want to check out and whether it has flight modes for the various different phases of flight you might want to have. Launch, Landing, Cruise, Speed etc...
Good luck
Wing-span is offline Find More Posts by Wing-span
Old Oct 01, 2012, 03:51 PM
hbi is offline
hbi
Find More Posts by hbi
hbi
Sverige, Skåne Län, Helsingborg
Joined Jul 2010
I use an 9X with my DLG, so in a bit a F3X plane although not a 4 servo wing
But I would not concider it an issue to add two more servos to the mix.
However, I failed miserably with er9x, so I installed open9x instead, and found it much easier.
The two main reasons is; 1 it has flight modes, and 2 it marks active mixers with bold in the display.
hbi is offline Find More Posts by hbi
Discussion rigging up a simulator with Turnigy 9x alan2 Beginner Training Area (Aircraft-Electric) 9 Aug 25, 2012 05:28 AM
Question Turnigy 9x and TV set-up for Su-34? jbrundt Electric Ducted Fan Jet Talk 0 Jun 30, 2012 06:10 PM
Help! Turnigy 9x flaparon set up... bigfoot216 Electric Plane Talk 7 Apr 26, 2012 03:00 PM
Discussion Setting up Turnigy 9x tx for simulators ferdous7466 Simulators 13 Feb 29, 2012 03:22 PM
Discussion Programmable transmitter (Turnigy 9x) Step-by-step set up danda00 Electric Heli Talk 0 Feb 08, 2011 10:57 AM
