Old Oct 26, 2014, 07:37 PM
hogflyer is offline
Find More Posts by hogflyer
Master of the Figure "9"
hogflyer's Avatar
Wichita, Kansas
Joined Dec 2005
Originally Posted by tmulligan View Post
Thank you. I'm now using a new Spektrum DX6. I changed the deployment time to 2 sec (after flying again I may change to 4 sec). I'll add 10% down elevator.
Do you know the angle of deflection for the flaps? With my DX6, I can set two levels of flap deflection.
Tom
Put in all you can get - either contacting the structure or running out of servo throw. I have mine set up so they stop when touch the wing structure.
I also have 10% elevator mixed in to prevent the ballooning and it seems to do fine. Just let the plane slow down before deploying flaps and you'll very little if any ballooning. Deploy at high speed and you probably will see some.
Hogflyer
hogflyer is offline Find More Posts by hogflyer
Old Oct 26, 2014, 08:18 PM
tmulligan is offline
Find More Posts by tmulligan
Tommy Toy the Crazy Boy
United States, AR, Jonesboro
Joined Mar 2013
Thank you. I made the suggested changes and will fly again Mon or Tues.
I'm surprised at how well this thing flies given its weight.
tmulligan is offline Find More Posts by tmulligan
Old Jan 06, 2015, 09:27 AM
Bichorendon is offline
Find More Posts by Bichorendon
Joined Jan 2015
Guys do you have any video that shows how to install the flaps in the Avistar elite? I am a beginner pilot
Bichorendon is offline Find More Posts by Bichorendon
Old Jan 06, 2015, 11:32 AM
rammon3 is online now
Find More Posts by rammon3
Andover, NH
rammon3's Avatar
United States, NH, Andover
Joined Jan 2013
I don't know of any videos showing the flap install, but it isn't difficult. Just remember that both servo arms will be pointed in the same direction (unlike the ailerons which are opposite each other) and make sure the servos move in the right direction when you actuate the flap switch. As was stated above, you want as much deflection as you can get without binding the servo. Use a razor saw to cut the plastic pins that lock the flaps up.
You stated that you are a beginner. Unless you are already comfortable flying the plane, you might want to wait on the flap install as this might be an unwelcome distraction when you are trying to land. What radio are you using?
rammon3 is online now Find More Posts by rammon3
Discussion Great Planes Reactor GP/EP 3D ARF .46-.70 BoneDoc Sport Planes 48 Aug 09, 2013 05:10 PM
Sold Great Planes U-Can-Do 3D ARF - 46 ARF, mint cond. Turqui Aircraft - Fuel - Airplanes (FS/W) 2 Aug 05, 2012 11:20 AM
Sold Extra 300 sp - Great Planes 55" EP-GP .46-.81 Firedawg Aircraft - Fuel - Airplanes (FS/W) 5 Jun 20, 2012 05:14 PM
Article Great Planes Shoestring .46-.81 GP/EP Sport ARF Review EYEinSKY Sport Planes 181 Apr 23, 2012 11:22 AM
Discussion Great Planes Reactor GP/EP 3D ARF .46-51,58 slagger Fuel Plane Talk 7 Feb 26, 2009 07:18 AM
