Old Jul 06, 2012, 02:35 AM
Shuffle is offline
Find More Posts by Shuffle
Retired foamfanatic
Shuffle's Avatar
Helsinki, Finland
Joined Feb 2010
Powerful retract servos?
I got good giant-scale retract systems. I am running them with these:
http://www.hobbyking.com/hobbyking/s...ACT_Servo.html
Problem is, i need just a bit more torque to get my all systems work 100% well.
What kind of servos would you suggest? I need around 10-12kg torque.
Yes, normal servos are fast but their advantage is that you adjust the end points with them, which is a big plus.
Shuffle is offline Find More Posts by Shuffle
Old Jul 06, 2012, 01:28 PM
eflightray is online now
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Up the servo voltage ?, unless you are already running 6v.
Add some spring biasing to the legs to reduce the load ?.
One nice thing about using standard servos, (as against retract servos), you can add a servo slow to slow the undercarriage down. looks more scale.
Ouch!, did you read the reviews on that HK link ?. (Scroll down the link).
eflightray is online now Find More Posts by eflightray
Old Jul 06, 2012, 11:37 PM
Shuffle is offline
Retired foamfanatic
Shuffle's Avatar
Helsinki, Finland
Joined Feb 2010
Allready using springs and 6V No, i don"t read reviews of HK, i just use them They are fine for their price.
Old Jul 15, 2012, 07:42 AM
Cougar429 is offline
Find More Posts by Cougar429
Cougar429's Avatar
Canada, ON, Windsor
Joined Apr 2008
Some of the newer HV servos have some serious torque, well above the 200oz/in rating. 4.5-6V rated swash servos for larger helis or control servos for jet gear can be quite strong.
The problem is these become expensive. However, along with paying for performance you are also investing in reliability. I have seen MANY of those less expensive HK metal gear servos fail or become very sloppy with little use. Many also make the mistake of having the entire gear train from motor to output shaft made from metal. This provides a direct path for RF and interference created in the motor right to the output. Add a metal servo arm and things get even worse. If you look at a lot of the higher end gear the first gear from the motor, (and the one under the lowest loads) will frequently be fabbed from an insulating form of composite.
It sounds like you will be pushing them near the top end of their output torque and that means high current demands. If you go digitals the current demand is even higher. Slow the sweep speed down and it will spend a LOT more time with with those high currents through the board, motor and servo leads/connectors, so you do the math on reliability.
Cougar429 is offline Find More Posts by Cougar429
Old Jul 15, 2012, 11:03 AM
43851E is offline
Find More Posts by 43851E
43851E's Avatar
College Station, TX
Joined Jul 2009
Shuffle,
You said that you were running the servo network on 6Vdc, Try to measure the voltage while your servos are in acuation. And or possibly hook the system up to a bench supply (lots of available current) and seen if having more current available improves things. Then if there seems to be an improvment, you will need to consider a new or improved voltage/current source onboard. This may include larger wires in the circuit maybe?
Doug
43851E is offline Find More Posts by 43851E
Off Site honda jet power and servos and retracts jsteil1098 Aircraft - Electric - Jets (FS/W) 6 Dec 04, 2012 03:32 PM
Sold JR 513 Sport Retract Servo New hobbyfun100 Aircraft - General - Radio Equipment (FS/W) 0 Jun 27, 2012 09:37 AM
Discussion Modd'ed servo powered retracts; need reversing control circuit 43851E DIY Electronics 13 Aug 30, 2010 10:11 AM
Discussion Retract Servo Powered By Separate Battery SteveR International Scale Soaring Association (ISSA) 6 Dec 26, 2008 02:32 PM
Sold Alfa Spitfire thunder power 1320 LiPo 5 servos retractable landing gear done for you! shschon Aircraft - Electric - Airplanes (FS/W) 2 Sep 29, 2008 10:54 PM
