Old Feb 22, 2012, 07:55 PM
mkpatrick is online now
Find More Posts by mkpatrick
mkpatrick
Joined Mar 2011
M41 Walker Bulldog battery charge
Hello,
I just got a M41A3 tank from Taigen. This is my first one. I've never done R/C tanks before.
The instructions are pretty rough.
There is no indications on how long I should charge the battery. It has an AC adaptor and I could easily see how to plug the battery into the AC charger. But there is no indication on how long I should charge the battery or an indication on over charging.
So does anyone know what I'm doing here?
How long should I charge the battery from the AC adaptor and how do I keep from over charging?
M
mkpatrick is online now Find More Posts by mkpatrick
Old Feb 23, 2012, 12:20 AM
Pat Tooke is offline
Find More Posts by Pat Tooke
United States, WA, Seattle
Joined Aug 2010
you've got identify the type of batteries involved
and pictures of your track problems would help
I'm new here also but will help if I can
Pat
Pat Tooke is offline Find More Posts by Pat Tooke
Old Feb 23, 2012, 12:26 AM
mkpatrick
Joined Mar 2011
Thanks so much for the reply!!
OK I will upload the picture but I think it drove itself back onto the sprocket because it appears to be fine now.
Also the battery is a 7.2V battery.
2 more questions:
(I'm discovering this stuff as I go)
It has an airsoft gun in it but the bb's just roll out of the barrel when I fire it. I don't even know how to get to the gun to fix it. And I guess I don't know how to fix it when I am able to access it.
It said it was a 2 speed drive on the advertisement. Well, how do I switch gears?
M
Old Feb 23, 2012, 02:55 AM
A N Z A C is offline
Find More Posts by A N Z A C
RC Tank n00b
A N Z A C's Avatar
New Zealand
Joined Oct 2007
7.2V battery
Charge time depends on cell type & charger rating
If Taigen ship like Heng Long then good chance you have basic crap gear
1700 or 1800mAh Ni-CD rechargable battery with about 20-30min run time
upgrading to Ni-Mh type with higher mAh will increase your playtime
example I'm running 4600mah 7.2v Ni-Mh
Wall Charger will be 400ma or 500ma rated
approx 1.5hr -2.3hr charge time
again upgrade to a real one
The Ansman ACS 67P+ is a microprocessor controlled charger for NiCd & NiMH RC battery packs with 6 or 7 cells (7.2v - 8.4v).
Cheers for now
A N Z A C is offline Find More Posts by A N Z A C
Old Feb 23, 2012, 03:01 AM
RC Tank n00b
A N Z A C's Avatar
New Zealand
Joined Oct 2007
No Gear Shift ( No Stick Shift ) 2 speed = fast & slow in both forward & reverse direction, non 2speed was Fast & dead Stop
Old Feb 23, 2012, 10:52 PM
mkpatrick
Joined Mar 2011
BTW- its a Shida 2000 mAh battery.
I was worried about over charging. What if I leave it on the charge too long? Will it damage itself?
M
Old Feb 23, 2012, 11:24 PM
RC Tank n00b
A N Z A C's Avatar
New Zealand
Joined Oct 2007
Shida High Power Li-Polymer Battery Type ?
http://www.shida-batteries.com/engli...%B3%D8&sel=all
talk to the manufacture
Discussion Heng Long Walker Bulldog MG rmar RC Tanks 3 May 09, 2011 12:20 PM
Discussion Heng Long Walker Bulldog wheel problem rmar RC Tanks 7 May 08, 2011 05:06 AM
For Sale HengLong M41 "Bulldog" 1/16th Tank Tanks4Nuthin Cars - Trucks and Parts (FS/W) 0 Nov 21, 2009 02:23 PM
