Old May 23, 2011, 10:15 AM
RAPPTORS is offline
Find More Posts by RAPPTORS
United States, FL, West Palm Beach
Joined Jun 2004
Scorpion motor for 123 dynamax
THERE ARE MANY 4035 MOTORS.. BEST ONE IS FOR 12S SET UP??
RAPPTORS is offline Find More Posts by RAPPTORS
Old May 23, 2011, 10:24 AM
Ron101 is offline
Find More Posts by Ron101
Pursuit of Happiness
Ron101's Avatar
Brentwood, California
Joined Jul 2007
4035-630 KV
12s 30c 5000 mah gave me 4200 to 4400 watts. The motor is fine up to 5000 watts and stays cool
Ron101 is offline Find More Posts by Ron101
Old May 23, 2011, 10:46 AM
racer1 is offline
Find More Posts by racer1
5kW Club
racer1's Avatar
United States, AZ, Tucson
Joined Feb 2007
I have used both the
4035-630 KV on 12s
4035-800 KV on 10s this works well. I have tried this setup on 12s but the amps are way too high for me.
I have also used the new HET motors the 700 series with good results.
Clay
racer1 is offline Find More Posts by racer1
Old May 23, 2011, 06:44 PM
RAPPTORS is offline
Joined Jun 2004
Motor
Thanks for reply and info.:d
Originally Posted by ron101 View Post
4035-630 kv
Old May 23, 2011, 06:46 PM
strictlyscale is offline
Find More Posts by strictlyscale
Dream Build Fly Scale
strictlyscale's Avatar
Philadelphia, PA
Anyone know where you can get the 5035-650kV motor for this fan? Just motor.
strictlyscale is offline Find More Posts by strictlyscale
Old May 23, 2011, 06:47 PM
AIR SALLY is offline
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
try inov8tive rc . Lucien sells the scorpian motors
AIR SALLY is offline Find More Posts by AIR SALLY
Old May 23, 2011, 06:55 PM
Philadelphia, PA
Thanks, I'll take a closer look tomorrow, didn't see them listed there today but granted I didn't spend long hunting.
Old May 23, 2011, 08:18 PM
Ron101 is offline
Ron101's Avatar
Joined Jul 2007
Sean,
pretty sure that is a speacial order motor that Sapac is useing.
I'm also pretty sure they get it with a longer shaft. The 4035 is a smaller Dia and fits in the motor tube. The 5035 is bigger and sits right behind the motor tube with an adaptor.
That's my take on it looking at pictures of both
Old May 23, 2011, 08:29 PM
Philadelphia, PA
That's good feedback, thx Ron. I may be better off then getting the complete fan from sapac and selling my NIB dm fan. Thinking it may be the ticket for the F104.
Old May 24, 2011, 08:46 AM
TurboFanElectric is offline
Find More Posts by TurboFanElectric
www.turbofanelectrics.com
TurboFanElectric's Avatar
Tampa, FL
Joined Apr 2002
Strictlyscale we sell the Scorpion 5035-650kv motor. http://www.shop.turbofanelectrics.co...&categoryId=13
best regards,
William
TurboFanElectric is offline Find More Posts by TurboFanElectric
Old May 25, 2011, 02:42 AM
Extreme_RC is offline
Find More Posts by Extreme_RC
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
Yeah the 5035 is a custom order job with long shaft, also the shaft standard is 10mm so it has to be specified ground down to 8mm or different bearings used to run an 8mm shaft all the way. I am waiting on custom shafts so I can mount the 5035 into my CNC Alloy housing, then I will have both Dynamax and Ramtec rotor options for the 5035, all in the one assembly.
Extreme_RC is offline Find More Posts by Extreme_RC
Old Dec 06, 2012, 05:43 AM
ApexAero is offline
Find More Posts by ApexAero
Aka: Tom Jenkins
ApexAero's Avatar
Joined Aug 2008
Ralph, I have a box of burned motors Lucian sent me. I'm in the process of winding a 4035 to 4.5kw continuous now. I'll keep you posted. Planning on a 6kw continuous croco style winding eventually. "Practice practice"
Tom
ApexAero is offline Find More Posts by ApexAero
Old Dec 06, 2012, 03:10 PM
Chuchuf is offline
Find More Posts by Chuchuf
Carboweave, Ask For It By Name
United States, GA, Atlanta
Joined Aug 2009
Tom
Tom,
How did you get the stator off the bearing tube on those Scorpions. The one I tried doing there was no way the stator was coming off.
Terry
Chuchuf is offline Find More Posts by Chuchuf
Old May 07, 2013, 05:06 AM
ApexAero is offline
Aka: Tom Jenkins
ApexAero's Avatar
Joined Aug 2008
Terry, I just found this, what I did was to unwrap the stator on the bearing tube, used long 3mm screws to push the stator off using a stack of nickles under the screw ends as it moved. The best way was to stick the whole thing in the counter top oven (minus the bell) at 250 for an hour first using gloves to unwrap, hold and turn the screws, patients is the key to not warping the stator plates or bearing tube mount. The heat breaks down their epoxy fixing. Don't mushroom the screw tips!
Ralph, yours is in the works, just have other obstacles in the way presently.
Tom
Old May 07, 2013, 06:38 AM
Chuchuf is offline
Joined Aug 2009
Tom
Ingenous Tom.
I have wound a bunch of motors in my time, but stopped trying to do scorpions when I ruined a few stators.
Terry
Wanted Scorpion 2206 motor with Pinion for TREX 250 mmalik4 Aircraft - Electric - Power Systems (FS/W) 1 Mar 26, 2011 06:52 AM
Discussion Dynamax scorpion lrb75 Electric Ducted Fan Jet Talk 1 Mar 20, 2011 10:39 PM
Video Falcon 120 Scorpion-Dynamax 12S PlumberJohn Electric Plane Talk 2 May 16, 2010 07:18 PM
Discussion Scorpion 4035- Dynamax Conversion PlumberJohn Electric Ducted Fan Jet Talk 35 Oct 04, 2009 04:44 PM
Discussion Dynamax Scorpion 630kv Bench Test DForbes Electric Ducted Fan Jet Talk 12 Aug 24, 2009 09:49 PM
