Old Jul 06, 2010, 01:54 PM
Adrian B. is offline
Find More Posts by Adrian B.
Adrian B.'s Avatar
Cape Town, South Africa
Joined Sep 2006
Build Log
Scratch Build a J - Endeavour II
Hi Guys,
So I've decided to do a scratch build of a J, Endeavour II.
Confessions up front, I have little or no experience with RC yatchs, so this is partly for the fun of tracking the build process but also provides an opertunity to ask questions. I dont think I will have too much trouble with the hull, I probably need some assistance when it comes to rigging and trimming.
I'm in Cape Town South Africa and there are very few RC model clubs in the area so this is largely for my own enjoyment of building and sailing
All comments are most welcome.
I managed to get a set of plans from John Hanks from AMYA, I have decided to scale down the drawings and do a model that is 1700mm LOA.
The start of the project was to take the drawings and re-capture them in CAD so I could scale them to the desired size.
Adrian B. is offline Find More Posts by Adrian B.
Old Jul 06, 2010, 02:00 PM
Adrian B.'s Avatar
Joined Sep 2006
Build options
So this is going to be a plank on frame with some slight differences. I have basically decided that once the hull is planked, it will be glassed with fibreglass and epoxy and then taken off the frame. This will leave an empty hull that is not cluttered with the frames. The approach has some challanges but also some benefits such as weight saving.
Once I had the drawing scaled I had the forms printed out and glued to some MDF which will be used to create the frames.
Old Jul 06, 2010, 02:04 PM
Adrian B.'s Avatar
Joined Sep 2006
Setting up the forms on the strong back
The strongback has been build and the frames / forms attached
Old Jul 06, 2010, 02:07 PM
Adrian B.'s Avatar
Joined Sep 2006
Scale
As mentioned earlier, this J is going to have an LOA of 1700mm, about 2/3 the size of the full scale model. Pic of my son below adding some perspective
Old Jul 06, 2010, 02:15 PM
Adrian B.'s Avatar
Joined Sep 2006
Planking
The majority of the planking will be done with teak, just because I have a good stock of timber lying arround.
Planks are 3mm think and about 8mm wide.
Planking has started on the sheerline.
From here on, things are likely to slow down a bit. I can only put on a couple of planks each evening since they need to dry before the next ones go on.
Old Jul 06, 2010, 02:22 PM
DT56 is offline
Find More Posts by DT56
Joined Aug 2005
Thanks for the build thread!
DT56 is offline Find More Posts by DT56
Old Jul 06, 2010, 10:55 PM
MILLERTIME is offline
Find More Posts by MILLERTIME
Taking care of the pond.
MILLERTIME's Avatar
United States, CA, Sanger
Joined Apr 2004
I'm watching.
MILLERTIME is offline Find More Posts by MILLERTIME
Old Jul 07, 2010, 01:21 AM
KoneWone is offline
Find More Posts by KoneWone
KoneWone's Avatar
Germany
Joined Mar 2009
Hey Adrian ...great start, I will be tagging along with you too as I have a J-Class next on my list of "boats to build".
Finished scratch building two IACC 120's earlier this year & enjoying sailing in the sun at the moment.
I noticed that you are planking all way to the bow which is fiddly tight area, one idea is to make this area out of solid block of balsa (easy to shape) which will save you lots time and make your planking easier, same goes for the stern also, as I understand you planning on glassing over the planking.
Take my hat off to you using teak ....sounds like a hell of a lot of sanding (hard wood) further you talked about saving weight, have you considered saving further weight by using the firbeglass only & using the framework, planking as a plug only ?
Cheers Alan
KoneWone is offline Find More Posts by KoneWone
Old Jul 07, 2010, 01:54 AM
Adrian B.'s Avatar
Joined Sep 2006
Hi Alan,
I will do the stern from a solid block, the bow is largly done, I will post some pics this evening. Some of the twists in the planks are quite tricky and I'm also trying to avoid steaming anything.
As for the teak, I love the look of it and dont mind some extra effort. At the end of the day this will also be a show piece so the glassing will be a clear coat so the timber can show through. The attached pic is a kayak I did a few years ago. this will basically be done in the same manner
Old Jul 07, 2010, 04:19 AM
KoneWone is offline
KoneWone's Avatar
Germany
Joined Mar 2009
Ok now I understand clear coat (expoxy without fibreglass) looking at your prevoius kayak build this will be great looking display model also ... watching with interest
Cheers alan
Old Jul 07, 2010, 05:02 AM
Adrian B.'s Avatar
Joined Sep 2006
Hi Alan,
Just a note, the epoxy coat also uses fibreglass. The kayak was done with a 200gram twill glass / cloth. If done correctly, the glass becomes transparrent and once it has been wet sanded with a coat of good urethane, you cant see the cloth.
Old Jul 07, 2010, 10:32 AM
Dick L. is online now
Find More Posts by Dick L.
Dick L.'s Avatar
Minnesota, USA
Joined Aug 2002
Adrian -
nice job on the kayak. Just about to start on my own "Wee Lassie" (design) which is a solo, double paddle stripper. About 11 feet long, and final weight expected to be in the 23-28 lb. range, although I am also considering extending the foredeck a bit.
Regards, Dick
Dick L. is online now Find More Posts by Dick L.
Old Jul 07, 2010, 02:31 PM
Adrian B.'s Avatar
Joined Sep 2006
4 planks
4 Planks on. There is quite a twist at the stern but I think the worst is over for now.
Old Jul 07, 2010, 08:12 PM
blckgnx is offline
Find More Posts by blckgnx
Tehachapi, CA
Joined Jul 2007
Some of the "Craftsmen" on here absoulutely floor me. GREAT job!! Will be watching this build with Mucho Gusto!! Ron
blckgnx is offline Find More Posts by blckgnx
Old Jul 07, 2010, 11:25 PM
MILLERTIME's Avatar
Joined Apr 2004
Ron,
When are you going to start a build thread on your J boat?
Discussion Electric-J 48 inch Stick Scratch Build Chophop Parkflyers 15 Aug 15, 2010 09:28 AM
Build Log J-Class, Endeavour ooby Sailboats 51 Jun 29, 2009 08:34 AM
Rave J-3 scratch build recommendations JLKonn Giant Scale Airplanes 4 Nov 02, 2004 11:40 AM
TACO II Scratch Build Acer Parkflyers 43 Jun 04, 2003 08:01 AM
Firebird II Speed Wing for 1st Semi-Scratch Build? Dave Hederich Power Systems 16 May 21, 2002 09:50 AM
