Old Dec 13, 2009, 06:23 PM
MinMN is offline
Find More Posts by MinMN
Joined Aug 2008
Haoye Fan Issue
Looking for suggestions on a strange noise coming from my Haoye fan.
It a 51mm 7 blade model and is set up with a 2900 kv inrunner, a 20 A esc, and a 3s 2200 battery.
On running up the motor, the fan produces a consistent hum until about 50% throttle, when it suddenly becomes dramatically louder and the sound takes on a completely different and harsher character.
I do not think that anything is loose- all connections have lock tite and are properly torqued. Any ideas about what is happening?
MinMN is offline Find More Posts by MinMN
Old Dec 13, 2009, 06:44 PM
bruff is offline
Find More Posts by bruff
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
Is the fan balanced and the motor supported in the rear of the motor tube?
Bob
bruff is offline Find More Posts by bruff
Old Dec 13, 2009, 06:50 PM
MinMN is offline
Joined Aug 2008
I have not balanced the fan- I wouldn't know how. It's so small! However, there are a series of small holes drilled in the hub in an offset pattern, suggesting that the manufacturer made an attempt to balance the fan.
As for rear support, the system doesn't seem designed for that. I suppose that I could rig something up, but it would probably be as likely to harm as help.
Old Dec 13, 2009, 07:21 PM
kelberts is offline
Find More Posts by kelberts
Effumall
kelberts's Avatar
Joined Nov 2005
As it spins up, the blades might be flexing/stretching, and rubbing on the shroud. Are there rub marks?
kelberts is offline Find More Posts by kelberts
Old Dec 13, 2009, 07:26 PM
bruff is offline
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
You wrap the motor with tape to support the motor in the tube. Hoaye fans motor mounts allow some flex. Do a search for how to balance the rotor. It need to be balanced to perform properly.
Bob
Old Dec 13, 2009, 08:11 PM
moparren is offline
Find More Posts by moparren
I am what I teach
Tucson AZ
Joined Mar 2007
I agree with Bob, balance that bad boy. Makes a world of difference!
moparren is offline Find More Posts by moparren
Discussion Haoye F-18 EDF conversion 4" Haoye fan Ed Waldrep Foamy EDFs 17 Aug 22, 2014 01:52 AM
Mini-HowTo Haoye fan & BigExtreme motor bruff Electric Ducted Fan Jet Talk 171 Feb 05, 2010 04:25 PM
For Sale Used HAOYE 51mm 7 Blade Fan $7 Shipped typhoonmaster Aircraft - Electric - Jets (FS/W) 1 Nov 26, 2009 07:25 PM
Found Haoye 90mm fan (nib) steve morris Aircraft - Electric - Jets (FS/W) 0 Nov 26, 2009 11:03 AM
Discussion Sapac 70mm fan/motor issue... Racebelly Electric Ducted Fan Jet Talk 16 Sep 05, 2009 01:16 PM
