Old Sep 07, 2008, 01:29 AM
curtqn is offline
Find More Posts by curtqn
Joined Jan 2003
Depron foam question
I'd like to buy some 2mm and 3mm depron foams to build a foamie. I have some questions about depron foam.
1) Are all depron foams the same? Do they have different grades? Do they have the same weight if the thickness are the same?
2) Are white and black depron foams the same? weight and strengh?
3) Any other kind of foam is stronger and lighter than depron?
4) Where is the best source to buy depron foam?
Thanks.
curtqn is offline Find More Posts by curtqn
Old Sep 07, 2008, 02:30 AM
thewz is offline
Find More Posts by thewz
"It's a Quad" :O
thewz's Avatar
Temecula
Joined Jul 2004
Go to RCFoam.com and have a good read.
thewz is offline Find More Posts by thewz
Old Sep 07, 2008, 07:54 AM
JelleB is offline
Find More Posts by JelleB
Time for another motto!
Utrecht, The Netherlands
Joined Jul 2006
1) no. Depron is a brandname, their factory make lots of different grades/types of foam. Usually the thinner foams have a higher density than thicker ones. So using 6mm instead of 3mm only means 1.5 times more weight.
2) I've read somewhere that black depron contains recycled foam (styrene), so it cannot be white. No it is not the same as the white stuff, but very similar.
3) could be. The point of foam is not that it is strong or light alone. The best argument for it is that it is cheap and readily available.
4) the best source for depron is in europe/the netherlands, as that is where their factory is. However, you would be much better served with a local foam if depron is expensive in your area. Buying from a specialised web store is a guarantee that you will pay much more than local foam. It is up to you to decide if the differences are worth it.
Thanks.
JelleB is offline Find More Posts by JelleB
another depron )meat tray foam ) question mhmitchell333 Foamies (Kits) 1 Jan 19, 2003 06:26 PM
another blue foam question if u will mhmitchell333 Foamies (Kits) 1 Jan 17, 2003 05:31 PM
Alternative to Depron Foam, this item .... y22biker Scratchbuilt Indoor and Micro Models 17 Mar 24, 2002 08:27 AM
Source for Depron foam . . . Jar'sbuddy Electric Plane Talk 11 Jan 21, 2002 11:37 AM
Where can I get depron foam Skysailor Parkflyers 19 Sep 29, 2001 04:53 AM
