Old Jul 14, 2001, 01:14 PM
Ryan13005 is offline
Find More Posts by Ryan13005
louisville,ky,us
Joined Jul 2001
micro receiver
Can you use a hitech 4 channel feather receiver with a:jeti 35 esc /w bec, 2 edf 400, and 2 8 cell 600 AE?
Ryan13005 is offline Find More Posts by Ryan13005
Old Jul 14, 2001, 04:17 PM
Kevin Murray is offline
Find More Posts by Kevin Murray
Kevin Murray's Avatar
USA, NC, Greenville
Joined Dec 1999
Yes it can be done.
But I wouldn't use a Feather Rx in any aircraft that I ready like. Too much bad press on the Feather.
IMHO
Kevin Murray is offline Find More Posts by Kevin Murray
Old Jul 14, 2001, 06:06 PM
Thomas B is offline
Find More Posts by Thomas B
Electric Coolhunter
Thomas B's Avatar
United States, TX, Fort Worth
Joined Jun 2000
Yes, there is no reason it will not work with what you have. BUT, at best, the Feather has a 500 foot range or so. Unless you are building a really slow flying park flyer type of EDF that will always stay in close, the Feather RX is just not a good idea.
Many folks have good luck with the smaller GWS RX at ranges of about 1000 feet or so.
You would be much better off with a Hitec 555 on a twin EDF model.
Thomas B is offline Find More Posts by Thomas B
Latest blog entry: 2014 events and travel
Old Jul 14, 2001, 09:20 PM
ScottS is offline
Find More Posts by ScottS
ScottS's Avatar
Houston,TX
Joined Mar 2000
I would use the hitec 555 or JR610M.
I all the hitec 555 I haved used worked great, even when all the electronics are basically pile on top of each other. I have been testing a JR610M(full length ant.) for a couple of weeks now and it seems fine too.
ScottS is offline Find More Posts by ScottS
Old Jul 15, 2001, 09:42 AM
USA, NC, Greenville
Joined Dec 1999
I have had good luck with Berg 6 Ch Rx, a lot better range than the Feather. I have two of them. It's only a single conversion Rx though.
A better Rx than the Feather, 555 and Berg is the FMA Extreme 5. It's a dual conversion and it's only 0.5 oz with a crystal. IMHO.
Kevin
Old Jul 15, 2001, 01:44 PM
Matthew Allen is offline
Find More Posts by Matthew Allen
Formerly of mcba fame
Matthew Allen's Avatar
Luxembourg
Joined Apr 2001
What is the range of the GWS Naro receiver? Would it be enough for a 42" 600 sized model?
Matthew Allen is offline Find More Posts by Matthew Allen
Old Jul 15, 2001, 02:03 PM
Thomas B is offline
Electric Coolhunter
Thomas B's Avatar
Joined Jun 2000
As mentioned above, the nominal range of the GWS micro RX is about 1000 feet. Some have had good luck using it outdoors. I would be a bit hesitant to use it at long range at a crowded flying field.
Old Jul 15, 2001, 02:21 PM
California Condor is online now
Find More Posts by California Condor
Old Timer
California Condor's Avatar
CARMICHAEL, CALIFORNIA USA
Joined Apr 2001
Range is not a problem with the GWS (long antenna), crowed field is.
California Condor is online now Find More Posts by California Condor
Old Jul 15, 2001, 02:22 PM
Old Timer
Joined Apr 2001
Range is not a problem with the GWS (long antenna), crowed field is. Range is MUCH better than the 610M.QUOTE]Originally posted by Thomas B:
As mentioned above, the nominal range of the GWS micro RX is about 1000 feet. Some have had good luck using it outdoors. I would be a bit hesitant to use it at long range at a crowded flying field.[/QUOTE]
Old Jul 15, 2001, 06:16 PM
Thomas B is offline
Electric Coolhunter
Thomas B's Avatar
Joined Jun 2000
What I said is what I meant. Long range AND crowded field together, not as separate conditions. Mine works happily at near OOS range flying alone, as do many other folks on Ezone.
Also, short range and crowded flying field can be an issue as well. The little GWS RX, flying by another TX, while a long way from your TX, can create a swamping condition.
The GWS is great little RX, but is not, IMHO, the best choice for an EDF application where a fraction of an oz does not matter.
What micro receiver will work with a Sanwa radio? poobs Electric Plane Talk 9 Jun 29, 2001 12:01 AM
Micro receiver in Zagi?? sgil2001 Beginner Training Area (Aircraft-Electric) 4 Jun 25, 2001 11:23 AM
Micro Receiver Comparison Chart? J Cubed Electric Plane Talk 1 Jun 04, 2001 10:18 AM
Cirrus MRX-4 Micro Receiver Gerry Markgraf Electric Plane Talk 1 May 25, 2001 11:48 AM
GWS R4P Micro receiver Feodosia Flyer Beginner Training Area (Aircraft-Electric) 3 May 04, 2001 09:59 PM
