Old Dec 06, 2005, 09:05 AM
simingx is offline
Find More Posts by simingx
now that's a wattmeter...
simingx's Avatar
Singapore
Joined May 2002
Bending wires on Hacker B20 (or any other motor in general)?
Hi all,
To make a Hacker B20-L fit into the nose of my glider, I had to bend the wires 180deg as they exit to the front of the motor so as not to block anything else (I'm sure it was more painful for me than it was for the motor). The bending point is some distance away from the front of the can, and the bend radius isn't too tight though.
Question here is, how many times can I do this? I'm sure at some point I'll remove the motor for use somewhere else, so I'd like to make sure of this.
The wires feel supple enough, I hope that means they haven't wicked solder all the way down there.
simingx is offline Find More Posts by simingx
Old Dec 07, 2005, 02:17 AM
Larry3215 is offline
Find More Posts by Larry3215
Permanently Banned
Larry3215's Avatar
Gig Harbor, Washington, United States
Joined Sep 2003
My B20's (older ones) have single strand wire comming out of the can. They cant take as many bending episodes as multy strand wire.
I already lost one B20 because a lead broke off rite where it exits the can. The other has needed repair where it solders to the conector.
Fewer times bending is better.
Larry
Larry3215 is offline Find More Posts by Larry3215
Discussion HB-CP2,BladeCP or ANY other geared DD tail motor SAVER Bonzer Micro Helis 171 May 28, 2006 11:35 AM
Heat sink for Hacker b20 or Razor in edf Wheazel Electric Ducted Fan Jet Talk 6 Jun 03, 2004 11:15 PM
Question Bending stiff ESC wires on Hacker B50? gregw Power Systems 3 Nov 26, 2003 08:46 PM
HELP: Soldering ESC to motor wires on a Hacker B40 Drivie Power Systems 11 Sep 20, 2003 09:55 AM
How much play in your prop shaft on Hacker B20 14L Geared blfinche Power Systems 0 Apr 01, 2003 07:19 PM
