Old Feb 25, 2015, 06:17 PM
funwithplanes is online now
Find More Posts by funwithplanes
perplexed genius
United States, PA, Fairfield
Joined Dec 2014
Help!
big slow plane
I saw that I had a whole set of champ electronics and am looking for something big 30 inches that would be light and extremely slow like 5 mph or lower also I would like it to be foam or simple balsa construction. I know this is kind of demanding but am looking for something to build!
Thanks!
funwithplanes is online now Find More Posts by funwithplanes
Old Feb 25, 2015, 07:57 PM
Sawn Craft is offline
Find More Posts by Sawn Craft
AMA 415
Sawn Craft's Avatar
United States, CT, Granby
Joined Mar 2012
With the Champ power system, I think you are going to have a tough time with an air-frame of the size you are looking for. The power plant in the Champ is great for ~1oz aircraft, but with more size and drag I think that obtaining satisfactory flight will become more challenging.
Take a look at the competition F3P planes; they are basically made of as little foam and carbon as possible, covered in super-thin mylar to keep weight to a minimum. Those models fly on brushless power systems that have huge amounts of power compared to the Champ setup while not being that much heavier.
Sawn Craft is offline Find More Posts by Sawn Craft
Old Feb 25, 2015, 08:41 PM
Gordon Johnson is offline
Find More Posts by Gordon Johnson
in persuit of low wing loading
Gordon Johnson's Avatar
Boston, Mass
Joined May 2001
My 16 inch foam triplane was built by a friend after I did mine, and used a geared 8mm motor like what is in the Champ. And, he used a standard brick like the Champ has for control. Plans are on about page 40 of this thread. There is also a video of it flying very slowly somewhere in the thread.
http://www.rcgroups.com/forums/showthread.php?t=1232909
Details on how to do skeletonized foam airframes is in this thread.
http://www.rcgroups.com/forums/showthread.php?t=1362423
Gordon Johnson is offline Find More Posts by Gordon Johnson
Old Feb 25, 2015, 08:45 PM
Ricomon is online now
Find More Posts by Ricomon
Ricomon's Avatar
USA, SC, Charleston
Joined Oct 2002
How about a 32" span TherMate? I used a FlyZone Playmate fuselage, two ParkZone Micro Citabria wings, a V911 receiver, and a HUGE scratchbuilt foam plate tail. It'll fly slower than my PZ Ember, and it turns on a dime. It's also tossed around by the slightest puff of wind, just like the Ember. The impossibly huge rudder has been cut way down since the video.
TherMate Micro Electric R/C Slowflyer Sailplane (3 min 51 sec)
Rick
Ricomon is online now Find More Posts by Ricomon
Old Feb 25, 2015, 10:21 PM
NEWBEFLYER is offline
Find More Posts by NEWBEFLYER
Crazy Canuck
NEWBEFLYER's Avatar
United States, VA, Woodbridge
Joined Apr 2007
https://www.youtube.com/watch?v=mW14UXxY-ok
Rick
You got the right idea there. Light big wings and small simple design light fuselage. good job.
NEWBEFLYER is offline Find More Posts by NEWBEFLYER
Old Feb 25, 2015, 10:24 PM
Crazy Canuck
NEWBEFLYER's Avatar
Joined Apr 2007
Here's a different approach to your thinking . Flying wing?? Not much to it and simple in idea and just might work.Scale it to your size with the equipment you have. Look at it and see if this is doable for you. You're into a build fritz and need some challenge. Be creative and come up with a design you like from these suggestions.
http://www.rcgroups.com/forums/showthread.php?t=1819579
Old Feb 25, 2015, 10:33 PM
Crazy Canuck
NEWBEFLYER's Avatar
Joined Apr 2007
Another from this site
http://www.rcgroups.com/forums/showthread.php?t=757539
Old Feb 26, 2015, 06:44 AM
perplexed genius
Joined Dec 2014
What about something like Robsters super slow flyer scaled up the original used a 4 mm direct drive with a 14 inch wing! scale it up to 25 inches and build it minimally 8th inch balsa for the wing 1/16 for the tail and 1/4 inch for the fuselage.
Do you think this would work?
Thanks!
Old Feb 26, 2015, 01:38 PM
Boston, Mass
Joined May 2001
That would work. Here's one built by Ray Harlan.
Old Feb 26, 2015, 02:12 PM
perplexed genius
Joined Dec 2014
I bet that thing floated forever!
Old Feb 26, 2015, 02:22 PM
Petefoss is offline
Find More Posts by Petefoss
Petefoss's Avatar
Oxford, Michigan, United States
Joined Aug 1999
Whew don't walk fast with that one, you will break it!
Petefoss is offline Find More Posts by Petefoss
Old Feb 26, 2015, 02:56 PM
Boston, Mass
Joined May 2001
Personally, I would built it out of foam (but balsa would work too), and I'd build it to come apart for transport. Think about the big Ikarus indoor planes from the early days of indoor/parkflyers. The wing halves plugged in, and then rigging was attached.
Old Feb 26, 2015, 03:30 PM
perplexed genius
Joined Dec 2014
Ok thanks! have to pick up some foam for it though.
Old Feb 27, 2015, 11:46 AM
derk is offline
Find More Posts by derk
TheyreComingToTakeMeAway!
derk's Avatar
USA, ID, Coeur D'Alene
Joined Dec 2003
You might like a lightweight kolibri like I built here http://www.rcgroups.com/forums/showt...hlight=kolibri
derk is offline Find More Posts by derk
Old Feb 27, 2015, 02:15 PM
Boston, Mass
Joined May 2001
If I ever get around to it I have a design in my head. It would be a very big and slow floater Dr-1 triplane. Probably about 24 inch span. However, the difficult part is I would want it to come apart and pack flat in a box. Otherwise it would be a nightmare to transport. Essentially it would be a larger version of the Tripe I posted the link to above. Whether I'll ever do it remains to be seen.
Discussion An interesting plane for slow flying: El chato Aerophoto Foamies (Scratchbuilt) 30 Feb 07, 2015 11:35 AM
Discussion Small and slow beginner plane? dragonblade Beginner Training Area (Aircraft-Electric) 26 Dec 11, 2014 08:13 AM
Question Looking for BIG, SLOW, STABLE flying wing kit MRGTX Foamies (Kits) 3 Oct 28, 2014 08:13 AM
Discussion Indoor Big Slow Delta jb753 Foamies (Scratchbuilt) 2 Apr 28, 2014 09:28 PM
Build Log Big slow stick-esque plane derk Foamies (Scratchbuilt) 15 Apr 23, 2012 11:18 PM
