Old Jun 14, 2014, 03:50 PM
redfox74 is offline
Find More Posts by redfox74
Redfox74
Joined Apr 2009
New Product
VR uBrain 5.1 32 bit from Virtualrobotix next gen autonomous and follow me drone.
Micro drone AV250 based on VR micro Brain : Fly test doing by Marco Robustini .
APM Copter V3.2 RC3 - "μBrain" flight board by "Virtualrobotix" (4 min 58 sec)
This is the presentation of the board follow specification :
Apm Copter on VR micro brain 5.1 All Check are OK !!! (5 min 29 sec)
In this video is possible to learn the firmware update procedure by Mission Planner :
VR Brain Micro 5 Firmware upload using Mission Planner (8 min 52 sec)
This is an example of fully autonomous follow me flight :
VRX300 Personal Fly Robot SDK advanced follow car test (6 min 9 sec)
New plug and play telemetry module for VR micro brain video presentation
VR Micro Brain telemetry with VR Pad Station (2 min 16 sec)
First Taulabs - flight test by Stefan . Thanks to TL Team and Stefan for this great porting .
VR micro Barain (2 min 19 sec)
VR Micro Brain 5.1 is a good choose for your opensource autopilot board where the weight and dimension are very important factor only 3.7 x 3.7 and 10 gr . Firmware is available for Plane , Copter and Rover
Our revision of hardware support last revision of APM firmware . The Board support NuttX operating system most advanced unix like OS available for STM32F4 processor.
Our team is part of Diydrones Dev Team and officially supported in the github repository AP_HAL_VRBRAIN.
https://github.com/diydrones/ardupil...ster/libraries
The VR Micro Brain 5.1 specification are :
Hardware:
- 168Mhz ARM CortexM4F microcontroller with DSP and hardware fpu.
- 1024KiB flash , 192KiB of RAM.
- accelerometer and MEMS gyroscope and barometro.
- 8 RC standard input PPM , PPMSUM , SBUS
- 8 RC output at 490 hz
- 1 SD Card Slot until 64 gigabyte
- 1 i2c Bus
- 3 serial porti:1 for option GPS 1 for SBUS 1 telemetry.
- 3 digital switch (ULN2003) 2 LED 1 BUZZER.
- Jtag port for realtime debug .
- 1 Input analog lipo voltage control.
- Dimension 3.7x3.7 cm 10 gr hole distance 3.2 x 3.2 cm
- GPS and Magnetomer as option.
- Standard software will be a 32bit revision of Arducopter and TauLab project.
VR Copter
functionality available on standard VR Copter configuration:
stanndard functionality available without use of gps.
- acro fly.
- stable fly.
- altitude hold.
advanced functionality available with use of gps and magnetometer (NOT AVAILABLE IN LITE VERSION WITHOUT GPS).
- loiter.
- hybrid loiter.
- return to home.
- waypoint navigation.
- guided mode.
- circle mode
- simple mode.
mavlink 1.0 protocol for interconnection with Ground Station or DroneAPI for automatic functionality.
News !!! Now the VR uBRain 5 support Taulabs enviroment - Open Pilot fork - thanks to the TL Team for this great opportunity .
http://vrbrain.wordpress.com/quick-s...r-vr-ubrain-5/
This is the original blog post presentation of Vr u Brain 5 on our community :
http://www.virtualrobotix.com/profil...erfect-fly-pla
More info about the components of the test are available here:
http://www.virtualrobotix.it/index.p...micro51-detail
http://www.virtualrobotix.it/index.p...6-30-37-detail
New Vr uBrain radio module is available : 16-11-2014
this is the video that explain how use it .
this is direct link to module :
VRX uBrain Telemetry module lite option 433 : http://www.virtualrobotix.it/index.p...e-38-61-detail
VR uBrain Telemetry module lite option 868 : http://www.virtualrobotix.it/index.p...8-61-62-detail...
VR radio module lite option 433: http://www.virtualrobotix.it/index.p...rope-38-detail
VR radio module lite option 868: http://www.virtualrobotix.it/index.p...e-38-61-detail...
VR micro Gimbal Board : will be available at december
VR Leash : available for OEM and Pro project.
Best
Roberto
redfox74 is offline Find More Posts by redfox74
Last edited by redfox74; Nov 16, 2014 at 12:23 PM. Reason: forget revision of board
Old Jun 15, 2014, 04:01 AM
redfox74 is offline
Redfox74
Joined Apr 2009
VRX 250 Personal Fly Robot SDK By Virtualrobotix (15 min 9 sec)
In this video you can see the first fly review of VRBrain micro 5.0
VR Brain Micro 5 Auto Take off , Waypoint Navigation and Auto landing (1 min 22 sec)
In this test you can see the great quality of new magnetometer and gps . Emile doing an automatic fly . Set by VR Pad Station 3 waypoint , the last is an RTL . The drone take off from Emile's hand then land exactly in same position Emile don't move from his position during all the automatic fly test
Dear Friends,
I worked hard in recent weeks to test the new micro VRBrain 5.0
To test the card I used the frame I called our "Personal Robot SDK Fly" The configuration I used for testing and 'the following:
Frame VRX AV250 with Prop Guard
- Micro VRBrain 5
- VR GPS Ublox LEA 6
- 4 10 Amp ESC with Firmware SimonK
- 4 2400 KV Brushless Motors
- 4 Carbon Fiber Propeller dda 5 inches.
- 1 Battery 2200 Mah
- Receiver Futaba SBUS R7008 SB.
- Transmitter T14SG.
During the tests I carried out flight tests and reliability in a stable manner. I flew in different boundary conditions without having any kind of reliability problem. I made flights in both indoor and outdoor.
End the tests with flight manual I started the automated flight test . The GPS took our new GPS VR GPS uBlox LEA6, the main feature of this GPS and 'to have on board the new sensor HMC 5983 with automatic temperature compensation and more accuracy and immunity to electromagnetic interference.
In the tests we performed automated test of loiter mode, hybrid loiter, return to home and waypoint navigation.
Given the excellent results of the tests we have decided to close this firmware revision of the first software will be installed on the cards that will come over the next week.
Old Jun 15, 2014, 04:37 AM
mlebret is online now
Find More Posts by mlebret
mlebret's Avatar
France, Bretagne, Combrit
Joined Mar 2005
Nice work,
Do you have a schedule for the VR GPS /Compass unit? I will fly the VRBrain mini as soon as I have it, but I want to upgrade the configuration with GPS next.
Marc
mlebret is online now Find More Posts by mlebret
Old Jun 15, 2014, 10:06 AM
redfox74 is offline
Redfox74
Joined Apr 2009
Originally Posted by mlebret View Post
Nice work,
Marc
Hi Marc,
sure the VR GPS based on Ublox LEA 6H and with magnetometer HMC5983 is yet available on virtualrobotix shop .
We are working also on a new module that can use other constallation as Glonass , Galileo and Beidu for improve quality of position .
Best
Roberto
Old Jun 16, 2014, 12:32 PM
Drill is offline
Find More Posts by Drill
Ghent Belgium
Drill's Avatar
Joined Jul 2006
Mine has bin shipped as of today. As soon as i got it i will install it on a light acro Quad. Seems like a good alternative to the more typical acro boards.
Drill is offline Find More Posts by Drill
Old Jun 16, 2014, 06:23 PM
redfox74 is offline
Redfox74
Joined Apr 2009
Hi Drill,
sure you are one of first user that recive our board in the next days . I hope that you like it and enjoy it . We wait your acro video for our user gallery
best
Roberto
Old Jun 17, 2014, 07:06 AM
Drill is offline
Ghent Belgium
Drill's Avatar
Joined Jul 2006
Hi Roberto, it just came in. Now that was fast shipping. I will need a link to the manual. I could not find it on the website. And a link to the correct device driver for windows 8 64bit.
The board is found as a teensy on com 20 in mission planner but i suspect that this is not the correct driver as it fails firmware upload in mission planner.
Upon connecting to USB it blinks for about 6 seconds then the led goes out.
Btw, i also wrote an email about this to the shop.
Btw, i will do my best for the video as soon as the weather gods are more favorable.
Old Jun 17, 2014, 03:13 PM
redfox74 is offline
Redfox74
Joined Apr 2009
Hi Drill,
great , on the board there is yet the same firmware that i use on my AV250 used for testing the platform .
Here will be in the next hours more info about the quickstart guide
http://vrbrain.wordpress.com/vr-%CE%BCbrain/
best
Roberto
Old Jun 17, 2014, 03:34 PM
titeuf007 is offline
Find More Posts by titeuf007
Joined Jun 2006
do you inclued all wires with you board?
titeuf007 is offline Find More Posts by titeuf007
Old Jun 17, 2014, 05:29 PM
redfox74 is offline
Redfox74
Joined Apr 2009
Yes sure all the cable is included .
Check the blog post on www.virtualrobotix.com so you can see a picture where see what there is inside the package.
best
Roberto
Old Jun 18, 2014, 04:12 AM
Drill is offline
Ghent Belgium
Drill's Avatar
Joined Jul 2006
Tnx redfox, that takes care of the wiring. I will need the link to the USB device driver anyway for tuning the pids and radio calibration. Do you use mission planner build 1.3.5 33055 or a beta?
As for arming the board, do i need a button?
Btw, this pc connects to Pixhawk and Apm without problems.
Old Jun 18, 2014, 11:54 AM
redfox74 is offline
Redfox74
Joined Apr 2009
Hi Drill,
so for connect by usb to mission planner you need to power up the board by BEC on +5volt near the SD Card then after the board finish the booting flashing ... the blue led flashing connect the usb ... at that moment you install the proper driver that you found in this repository :
After this sequence you can found the board as vrbrain micro with a serial port assigned and you can connect to mission planner ... tomorrow will be ready a video tutorial that explain this procedure and cable connection.
We are waiting that the pull request is accepted by Michael so the vrx driver will be available in APM directory .
best
Roberto
Old Jun 19, 2014, 10:12 AM
redfox74 is offline
Redfox74
Joined Apr 2009
After a lot of request and shipment of first stock we reopen the preorder :
Here we add a lot of usefull info for first power on of board :
best
Roberto
Old Jun 22, 2014, 02:06 AM
arnonel is offline
Find More Posts by arnonel
Jedi Master
arnonel's Avatar
United Kingdom, London
Joined Apr 2014
How does this compare to pixhawk?
arnonel is offline Find More Posts by arnonel
Old Jun 22, 2014, 05:16 AM
Yana547 is offline
Find More Posts by Yana547
Yana547's Avatar
Joined Jun 2013
I have ardupilot mega mini, op revo with apm fw, working perfect and cheap.
this one worth to try
Yana547 is offline Find More Posts by Yana547
Cool STorM32 BGC: 32-bit 3-axis brushless gimbal controller OlliW Multirotor Electronics 4636 Today 12:19 PM
Off Site 32-bit Simple BGC 3 axis brushless controller (new Alex Mos board) GotHeliRC Aircraft - Electric - Multirotor (FS/W) 5 May 22, 2014 05:40 PM
New Product VR BRAIN: Put a Brain in your Drone (Indiegogo campaign) redfox74 Multirotor Electronics 9 Nov 21, 2012 03:23 PM
X-32 and X-35 competition on NOVA-PBS Tuesday night Feb 3 Ed Waldrep Life, The Universe, and Politics 32 Feb 12, 2003 02:14 PM
