Old Sep 11, 2013, 03:54 PM
microairman1 is offline
Find More Posts by microairman1
plane crasher extrordinaire
microairman1's Avatar
United States, IL, Waukegan
Joined Sep 2012
Question
flaps and dual servo elevator on a dx6i?
hey there, I know this is not the radio forum but I am getting ready to post a build log and the scratchbuilt people seem very helpful with everything. so that being said, I have a dx6i with a 6ch rx, I have a plnae I am building that has ailerons,flaps,rudder, and dual servo elevator. so is there a way I can do this on the dx6i with out a y-lead? the problem I have is when I set it up in a mix to the gear channel it listens to the gear switch too and and when I switch the gear switch it goes to the side but still listens to elevator. how can I dsable the gear switch? or is there a better way to do this? any help would be gretlly appreciated. thanks
microairman1 is offline Find More Posts by microairman1
Old Sep 11, 2013, 04:05 PM
JimStanmore is offline
Find More Posts by JimStanmore
Changing one life at a time...
JimStanmore's Avatar
United States, NJ, Pemberton Township
Joined Aug 2010
Won't you run out of channels, or are you running only one aileron servo?
Throttle
Aileron 1
Aileron 2
Elevator 1
Elevator 2
Rudder
Flaps
Here are some solutions:
http://www.rcgroups.com/forums/showthread.php?t=819912
http://www.rcgroups.com/forums/showthread.php?t=1814826
http://www.rcgroups.com/forums/showthread.php?t=1150101
http://www.wattflyer.com/forums/showthread.php?t=48583
JimStanmore is offline Find More Posts by JimStanmore
Latest blog entry: Plans On My Build List
Old Sep 11, 2013, 04:11 PM
Joined Sep 2012
i am using a y-lead for the ailerons,a y-lead for the flaps but am out of y-leads long enough for the elevator. So that is what i am figuring out.
Old Sep 11, 2013, 04:17 PM
Joined Sep 2012
oh,thanks jim. That works ok. It should be fine. Thanks
Old Sep 11, 2013, 06:11 PM
rajazo is online now
Find More Posts by rajazo
rajazo's Avatar
Chile
Joined Jul 2010
is easy to disable the gear switch with a little program mix:
master GEAR
slave GEAR
mix -100% in both ways
switch ON (always on)
that's all
rajazo is online now Find More Posts by rajazo
Old Sep 11, 2013, 06:25 PM
Joined Sep 2012
thanks everybody i got it figured out. I will post a build thread when i get the pics together. Thanks
Discussion Can't figure out dual aileron and dual elevator servos MUDDOBBER Foamy EDFs 14 Sep 03, 2013 09:28 PM
Discussion F22 Setup up For Dual Ailerons and Dual Elevators on a Specktrum DX8 chitwood Radios 17 Jul 13, 2013 05:14 PM
Question Need tips on flap elevator mix on P-47 duker733 Electric Plane Talk 14 Feb 07, 2013 12:32 PM
Discussion DX6I Dual Ele And Dual AILE servo setup ? metalwizard Radios 18 Jan 24, 2013 09:04 AM
Discussion DX6i and dual elevator servos for 3DHS 55" SHP finchkid24 3D Flying 5 Oct 26, 2010 12:42 PM
