Old Sep 11, 2013, 01:55 PM
TopViewShots is offline
Find More Posts by TopViewShots
United States, NY, New York
Joined Jun 2012
Help!
SunnySky 600kv + 4s + 30A + 13" Prop Flight Time
Hello all,
I am a little disappointed with my setup which based on other postings in this forum I should be getting a much longer hover time.
The setup below is my latest:
All up weight 2,800gr with the following included:
Naza M + GPS
Tarot 650 Carbon Fiber Frame
Sunnysky 600kv (From Bambucopter)
Afro ESC 30a (HK)
13"x4 Carbon Fiber Prop (From Bambucopter)
Venom 20c 4s Lipo 5000 mah (one only, lifting two was challenging)
Brushless Gimbal + Sony Nex (included on the AU weight)
I am getting 6 min. End each cell ending at 3.75v
Other postings mentioned same setup (but with go Pro) hovering between 12-18 minutes! I am lucky to get 8 minutes with mine. What is wrong? Using e-calc I shows 9.8 minutes but I am not getting that either.
Any light? Thanks for your help in advance.
TopViewShots is offline Find More Posts by TopViewShots
Old Sep 11, 2013, 09:45 PM
WendoNZ is offline
Find More Posts by WendoNZ
New Zealand, Canterbury, Christchurch
Joined Dec 2012
3.75v is quite high under load. You could probably quite happily go down to 3.5v which would buy you a decent amount more time. You want to aim to be putting 80% back in your battery when charging, so in your case you want to put 4000mAh back in.
What does your charger report is being put back in?
You also don't have a lot of pitch on your props. You don't mention exactly which motors but seemingly you'd be better off with 13x6 props to get your throttle down a bit for hover (at least according to ecalc)
WendoNZ is offline Find More Posts by WendoNZ
Old Sep 14, 2013, 08:06 PM
RDTague is offline
Find More Posts by RDTague
RDTague's Avatar
United States, IL, Cowden
Joined Mar 2013
Originally Posted by TopViewShots View Post
Hello all,
Naza M + GPS
Afro ESC 30a (HK)
You can go down to 3.5v / cell under load. Thus will recover to 3.75v / cell. This will help...but still not double your air time.
Probably any steeper pitch prop, with a 600KV motor on 4S, it may stall.
Have you thought of trying a 5S? One more volt will allow another 600rpm's, which may give you more lift to throttle ratio. Check on the esc rating, first though.
Assuming you're flying in gps and/or atti modes. Try this:
In manual mode: when you go full throttle, does it shoot straight up? Anything other than straight up, soemthing isn't quite right. This translates to the FC making more corrections in flight...all using more juice.
RDTague is offline Find More Posts by RDTague
Old Sep 17, 2013, 07:30 PM
snipeworm is online now
Find More Posts by snipeworm
Snipe the Skies!
snipeworm's Avatar
United States, CA, Roseville
Joined Feb 2012
Going up to 5s will add 4.2 volts on a full pack givong another 2400+ rpm. You would likely need smaller props to do that and keep your amps under limits. Not to mention your esc's might not like 5s. Just check first.
snipeworm is online now Find More Posts by snipeworm
Latest blog entry: Caliber FPV Wing
Old Sep 19, 2013, 04:22 AM
Widelec is online now
Find More Posts by Widelec
Simple is the best
Widelec's Avatar
Joined May 2011
6 min is good result for 2800gr AUW and 3.75v per cell end.
Try under the 2500gr AUW if possible and 3.5V per cell end.
Get rid of unnecessary weight. then it will be above 10 min
My same Quad build 1200gr and 20 min hower fly time with 4500mAh zippy compact lipo (470gr)
Widelec is online now Find More Posts by Widelec
Latest blog entry: Asterix Brushless Gimbal v2r
Old Sep 22, 2013, 08:35 PM
Joined Jun 2012
Based on your input I set a LIPO alarm to buzz at 3.50v per cell and now I am getting 8 minutes with AUW of 2,800g and 11-12 minutes with no load. Thanks!
Old Sep 22, 2013, 08:39 PM
Joined Jun 2012
I am using HK Afro's and SunnySky 4108 motor so 5S is not allowed as per specs.
Thanks for the idea!
Old Sep 22, 2013, 08:42 PM
Joined Jun 2012
I've checked and Afros and SS 4108 only take 2-4S batteries. Thanks!
Old Sep 23, 2013, 01:58 PM
RDTague is offline
RDTague's Avatar
Joined Mar 2013
Well. Give me a week for UPS to arrive and I'll have a comparison for you.
I just ordered a Tarot 690S that I'll be using SunnySky X2216-11 880KV II motors, 30A Opto ESC's, Naza V1 w/gps, swinging 1238 props off of 4S/5300/30C GensAce power. With all the other "stuff"(osd, vTx, tarot BLG, etc.), I'm shooting for an AUW of 3000 grams...3500 if I run 2x 4S LiPo's.
Old Sep 23, 2013, 09:50 PM
jparchib is offline
Find More Posts by jparchib
Canada, QC, Saguenay
Joined May 2013
Quad vs Hexa, not sure if you can really compare.
jparchib is offline Find More Posts by jparchib
Old Sep 23, 2013, 10:52 PM
RDTague is offline
RDTague's Avatar
Joined Mar 2013
You are correct. I was thinking the 650 was a hex, too. No, not to compare, at all.
Old Sep 23, 2013, 10:56 PM
Snipe the Skies!
snipeworm's Avatar
Joined Feb 2012
I'm using the 4108 sunnies with a rc timer brushless gimbal with gopro one on 3300 4s. I hover at about 17 amps. I can do roughly 9 minutes. I plan to go to a 4500 mah Lipo for 10+ minute flights. I'm using 12x4.5 APC multirotor props but plan on going for some 13x4 carbon fiber props.
Sold X650 v4 With Gimbal, SunnySky X4108S-11 600KV, 30A Simonk ESC dasrustler Aircraft - Electric - Multirotor (FS/W) 2 Apr 01, 2013 11:07 AM
Wanted SunnySky XS4108 600kv Brushless Motor xhover Aircraft - Electric - Multirotor (FS/W) 1 Feb 05, 2013 01:40 PM
Sold HT-FPV frame, SunnySky motors, DYS 30A SimonK, GemFan props MikeyBeeGood Aircraft - Electric - Multirotor (FS/W) 8 Oct 18, 2012 11:08 PM
Discussion 4S 8" props vs 3S 10" props Performance & Flight Times GuerillaFilm Multirotor Talk 12 Sep 16, 2012 06:50 PM
Discussion Go to motor for AP, about 600kv and 13-14" prop bladeaudio Multirotor Talk 8 Aug 11, 2012 05:08 AM
