Old Sep 09, 2013, 09:22 PM
waytooslow is offline
Find More Posts by waytooslow
Crash 'em if you got 'em
waytooslow's Avatar
United States, TX, Euless
Joined May 2013
2s batteries not getting fully charged PL6
I am sure this has been covered, but not finding using search function. So here goes.
Have a PL6 with feathermerchant 24v 47 amp PS. all my 2s batteries only get to 70 percent full (measure after charge by volt meter) using small balanced setting.
Very disappointing. the charger used to get me to 85% on 300mh 30c but no more.. stops at 70% ish . yes I am parallel charging sometimes up to 6 at a time.
I just picked up three new thundercat G8 2s 70c all 63% after a 1c charge in parallel. am I doing something wrong? do I need to multiple the rate by batteries and set in charger? if I plug in one battery and do a 1c it seems to charge up
All my 3s/4s batts seem to hit 98%+ when charge is done on the PL6 up to 3c in parallel - 4 at a time.
Thanks in advance
waytooslow is offline Find More Posts by waytooslow
Old Sep 09, 2013, 11:20 PM
Gregor99 is offline
Find More Posts by Gregor99
Seattle
Joined Sep 2007
Can you post the cell voltages of the 2s packs after they have been charged (as reported by your voltmeter)? Is it a voltmeter or cell checker?
Gregor99 is offline Find More Posts by Gregor99
Old Sep 10, 2013, 11:02 AM
waytooslow's Avatar
Joined May 2013
I ended up staying up late in to evening and charging one pack at a time. which brought them up to 97+ but will do a parallel charge and send results after I am done flying today. I can send both "checker" and VOM info.
when setting charge rates do you need to add all the amp rating together in Small balanced lipo preset? for instance 5 - 300mah 2s packs - all same brand, all same C charge rating. when I set charge rate do I select 300 mah? or do I need to multiple and set at 1500 (1.5)?
Thanks for the help
Latest blog entry: Sad Day -- P38 Formation Crash
Old Sep 10, 2013, 01:24 PM
Gregor99 is offline
Seattle
Joined Sep 2007
Thanks for the help
Please do not use a percentage to describe a cell or pack's state of charge. Its good for general descriptions, but not for being precise.
For setting the charge rate you can either set the charge rate for all packs in parallel and tell the charger there is only one pack. What I prefer to do is set the charge for a single pack at the desired C rate. Then tell the charger how many packs are in parallel. The charger multiples charge rate for a single pack by the number of packs in parallel. This gives you averaged Mah and IR per pack on the display and is much easier when varying the numbers of packs in parallel from charge to charge.
Discussion PL6 w/MPA Charging 6S Batteries - Power Needed dusty14 FMA Direct 4 Jun 05, 2013 04:22 PM
Discussion PL8 not fully charging 1S lipos. 4.1v resting voltage? (10440) touser FMA Direct 5 Apr 20, 2013 10:39 PM
Help! How to tell if batteries are fully charged Challe923 Batteries and Chargers 2 Feb 07, 2013 01:55 PM
Discussion EOS 0606I parallel charging 1s batteries, will not charge fully have to restart over mescalinedream Batteries and Chargers 5 Apr 25, 2012 02:12 PM
Discussion NiMH battery not charging fully ormandj Batteries and Chargers 10 Jun 14, 2006 11:44 PM
