Old Feb 10, 2015, 05:41 PM
RC_planefan is offline
Find More Posts by RC_planefan
United States, NC, Winston-Salem
Joined Jul 2014
Excellent and thank you.
RC_planefan is offline Find More Posts by RC_planefan
Old Feb 14, 2015, 11:11 AM
calde043 is offline
Find More Posts by calde043
Joined Dec 2012
Picked up a first gen UMX Habu (White and yellow) but didn't have a battery. Looking for some recommendations from those who have logged quite a few flights on yours. Was wanting to get the newer 180, because I like the decal scheme better, but this one will work for now!
calde043 is offline Find More Posts by calde043
Old Feb 14, 2015, 02:33 PM
kalmon is offline
Find More Posts by kalmon
Parkzone junkie
kalmon's Avatar
United States, MI, Grand Traverse
Joined Oct 2008
I responded on the other thread but here it is again:
Recommended packs are:
on 2S:
Absolute most Power:weight Thunderpower 325 70C
-many user's tests confirm this pack has the best power to weight of all common 2S packs. However it is also the heaviest. So expect faster landings. best of all expect 600 or so charges at 12C before they start to fade!!
Best featherweight: RCBabbel's BB240
-about 3min flight times, but it is extremely light. You'll definitely have the best handling and slow flight. This is my go-to pack in my confined yard flying.
These are about 14g complete w/ wires and connector
Best mix of both: Dinogy 300 65C
-Great longevity and cycle life here as well. weight with cables and connector is about the dead middle between the TP and BB.
The gamblers choice: HobbyKing 300
-sometimes you win sometimes you get a dud... If you get a good one they have good power, weight on HK is an outright lie... the "16g" they state must be before putting the plastic wrapper on and soldering up the wires and connector... note the shipping weight of 28g
-Brian
kalmon is offline Find More Posts by kalmon
Old Feb 14, 2015, 08:55 PM
RCBABBEL is online now
Find More Posts by RCBABBEL
**I'm Battman**
RCBABBEL's Avatar
Twin Falls, Idaho
Joined Jan 2005
calde043,
One more for ya.
My:
BB Hyp (2S) 330mAh RTF w/UMX connector. (short lead)
$16.95
L x W x H
43x17x12 mm
Approx: 16.7g (FYI: stock TP (2S) 325 70C weight: 23.3g)
All the wires tuck in clean.
Batt does not hang below the fuse.
It doesn't produce as high of RPM as the TP but that is off-set by it's light weight & clean aerodynamics.
Performance in the air is almost identical vs the TP.
Slow speed performance is better with the Hyp.
Roger
RCBABBEL is online now Find More Posts by RCBABBEL
Old Apr 07, 2015, 09:24 PM
rccraze is online now
Find More Posts by rccraze
rccraze's Avatar
United States, VA, Herndon
Joined Jul 2012
Originally Posted by RCBABBEL View Post
calde043,
One more for ya.
My:
$16.95
L x W x H
43x17x12 mm
Roger
Hi Roger, were you successful launching the Habu with stock TP 325 mAh 70C? I see they are significantly heavier than BB Hyp 2S 330 mAh. But were you able to launch it successfully with TP? Did you do any counter balancing to get the CG closer to the recommended point? My two launches with TP were unsuccessful. Thanks.
rccraze is online now Find More Posts by rccraze
Old Apr 07, 2015, 11:54 PM
**I'm Battman**
RCBABBEL's Avatar
Twin Falls, Idaho
Joined Jan 2005
Yes.
No problem.
My TP (2S) 325 70C batts are approx 21g
I removed approx 4mm of foam from the back of the battery cavity area.
Also added cf rods on the bottom of my vert stabs.
Covered with clear tape and glued with Foam-tac.
Really stiffened up the tail and added much needed tail weight.
Those mods got my cg spot on.
Roger
Old Apr 08, 2015, 09:48 AM
bhoov128 is offline
Find More Posts by bhoov128
John 20:1-18
bhoov128's Avatar
United States, FL, Davenport
Joined May 2012
Yes.
No problem.
Roger
Was the glue for tail weight / strengthening a glue fillet at the stab/fuse interface?
bhoov128 is offline Find More Posts by bhoov128
Latest blog entry: Snice Slick
Old Apr 08, 2015, 10:30 AM
**I'm Battman**
RCBABBEL's Avatar
Twin Falls, Idaho
Joined Jan 2005
Yes.
A win/win mod for me.
The tail flex is gone.
Nice control response at high speed.
Added tail weight was a plus for cg.
Foam-tac fillet on the bottom of the stab/fuse so it's out of sight.
My recently purchased (#2) V1 Habu arrived a bit nose heavy as well.
Roger
Old Apr 08, 2015, 10:41 AM
bhoov128 is offline
John 20:1-18
bhoov128's Avatar
Joined May 2012
Yes.
Roger
Thanks. I may yet give 3S a try in the little beastie. Can't wait to hear how she screams!
Old Apr 08, 2015, 12:07 PM
**I'm Battman**
RCBABBEL's Avatar
Twin Falls, Idaho
Joined Jan 2005
Ben,
As you may already know...
3S crack is REAL. (Consider yourself officially warned!)
The sound of a 28mm EDF unit on 3S power is hard to describe.
The vertical performance is also very impressive.
Speed, power, performance and low cost UMX convenience.
All flown at my local soccer complex, one mile from my home.
I love these UMX planes!!
Roger
Old Apr 09, 2015, 01:22 AM
corsair nut is online now
Find More Posts by corsair nut
DELTAS RULE
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
so im sure its been said before but im late to the party...but can you run 3s with 0 mods so long as you practice throttle management? i know you can run 3s on some of the eflight 2s micro stuff just wasnt sure about the habu guts
corsair nut is online now Find More Posts by corsair nut
Old Apr 09, 2015, 05:22 AM
LowlyElevated is offline
Find More Posts by LowlyElevated
My plane is 5ft BGL!
LowlyElevated's Avatar
United States, FL, DeLand
Joined Sep 2012
Yeah. Its a good practice to limit throttle curve to 80%, and the motor bearings can wear out quicker, but no mods are required.
LowlyElevated is offline Find More Posts by LowlyElevated
Old Apr 15, 2015, 08:02 PM
rccraze's Avatar
Joined Jul 2012
1. Removed 14mm of foam from the back of the battery compartment.
2. Added CF rods under the elevator stabs.
3. Added couple of thick rubber bands around the exhaust.
Pushed the TP 325 70C stock battery all the way back in the battery compartment. Got the CG spot on! This time my launch was uneventful! The battery has got a good punch even at the end of the flight, but sure is heavy! Yes, TP is a little better than my Nano-tech 300 35-70C, but I did not feel it was a big difference. May be I need to try Roger's lighter version to notice a significant difference.
Thanks Roger for your help!
Old Yesterday, 05:17 PM
Peter Phillipps is offline
Find More Posts by Peter Phillipps
Peter Phillipps's Avatar
Australia
Joined Dec 2004
Which Habu? (there are tw
#@*% that's sposed to say two up there/|\
Haven't read all of this tread so sorry if this has been answered already!
Have a UMX Mig which I love and would buy another if they existed.
So my option the Habu but which one a LHS has two advertised, see
links below, is the S version just mean you get the "Safe technology"
stuff? As in no more powerful the S is just the basic with the safe stuff
added is this correct? Another question as well will the Habu fan fit
in the the Mig, if I crash my Mig it seams the habu spares would be a
logical replacement?
Hey thanks folks!
Basic Habu.
http://www.modelflight.com.au/planes...bnf-basic.html
Habu S.
http://www.modelflight.com.au/planes...df180-bnf.html
Peter Phillipps is offline Find More Posts by Peter Phillipps
Old Yesterday, 06:00 PM
kalmon is offline
Parkzone junkie
kalmon's Avatar
Joined Oct 2008
They are the same except the Habu S has safe and a different livery (paint). Other than that identical. Personally if you're a beginner then get the S if not get the cheaper one.
-Brian
Hay thanks folks!
Basic Habu.
Habu S.
For Sale UMX BEAST 3D with AS3X with 3 batts tsecrist Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 5 Sep 28, 2013 09:44 PM
As3x umx gee bee for a As3x umx beast 3d Tyler83 Non R/C Items (FS/W) 2 Jun 05, 2013 11:44 AM
Sold LOWERED PRICE UMX Sbach with custom as3x w/ 3 batts and charger Drewkc Aircraft - Electric - Airplanes (FS/W) 0 Mar 08, 2013 09:46 PM
For Sale UMX Sbach with custom as3x w/ 3 batts and charger Drewkc Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Mar 06, 2013 10:32 PM
Sold E-Flite UMX Sbach 342 3D (AS3X) with spares kellymacdaddio Aircraft - Electric - Airplanes (FS/W) 2 Feb 26, 2013 10:36 PM
