Old Aug 17, 2012, 07:30 PM
jdre is offline
Find More Posts by jdre
Joined Mar 2010
Help!
Sbach electronics into Sukhoi?
I have an SU26XP Sukhoi. I replaced the motor on Sunday, it's on the way out again. about 2 1/2 hours on it, flying at work breaks, babied it for 3 days first. Will Sbach esc/receiver and 2 servos fit in there?
jdre is offline Find More Posts by jdre
Old Aug 17, 2012, 09:06 PM
alset is offline
Find More Posts by alset
Gunbarrel, CO
Joined Dec 2006
I was just playing around with a Sukhoi (doing other things than you propose), but I'd guess that the equipment can be made to fit, but that you will have a plane that will be so hot you'd better be one good pilot to keep it in control.
alset is offline Find More Posts by alset
Old Aug 18, 2012, 01:48 AM
jdre is offline
Joined Mar 2010
What did you do to your Sukhoi? I have an Sbach now and can fly it safely, and still want to fly the Sukhoi as it is lighter if landed firmly.
Old Aug 18, 2012, 10:42 AM
alset is offline
Gunbarrel, CO
Joined Dec 2006
I have an original version Sukhoi. The elevator was smashed up so I made a new one from foam sheet. Then I replaced the motor with a P-51, the prop with a 5030. I made the hatch to be attached magnetically and added washout to the wings. Also did a cosmetic makeover and plan to mount the battery internally. I also made a balancing jig.
Old Aug 18, 2012, 04:23 PM
RCAddict16 is offline
Find More Posts by RCAddict16
United States, VA, Ashburn
Joined Apr 2012
Its quite a lot of work, but it could be done. Its not recommended because the sukhoi is not stiff enough to withstand the forces that the brushless power puts on the airframe. Plus the wing loading will be much higher, to the point that it will not slow down anymore. Every crash breaks something as well. If you do it add CF to the wing.
RCAddict16 is offline Find More Posts by RCAddict16
Reply With Quote  (Disabled)
Sold UM Sbach Electronics. Motor, servos, Brick. Excellent condition. John S. Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 3 Jul 23, 2012 08:52 PM
Discussion 130X modified into an external electronic speed controller glybytony Electric Heli Talk 1 Jul 20, 2012 02:34 AM
Discussion Sukhoi, Beast or Sbach? paulbram Micro Ready-to-Fly 9 Aug 18, 2011 09:49 PM
Discussion Sukhoi XP V Beast V Pole Cat V Sbach Protocrash Scratchbuilt Indoor and Micro Models 9 Jul 29, 2011 03:49 PM
Discussion Parkzone Sukhoi Battery won't go into charger ah19 Micro Ready-to-Fly 9 Dec 17, 2009 07:46 PM
