Old Jan 27, 2012, 07:34 PM
alexhaben is offline
Find More Posts by alexhaben
alexhaben's Avatar
Eureka, CA
Joined Nov 2008
Small guns for clearing
What type of guns do you use to shoot clear on your models? I've been using my harbor freight 1.4 tip for clearing with automotive polyurethane but it seems like a waste of material and a mini gun would suit me better. For the base coats I use a .6 tipped airbrush to apply water based auto air wicked colors.
If you do use mini guns do you reduce the clear much to shoot through a smaller tip? I've been thinking of getting a gun like the iwata LPH80 with a 1.2 tip. Whataya think?
alexhaben is offline Find More Posts by alexhaben
Old Jan 28, 2012, 06:34 AM
TomCrump is offline
Find More Posts by TomCrump
ARFs Are Me
TomCrump's Avatar
Traverse City, Michigan
Joined Dec 2005
I choose which gun to use by the size of the project. If it's something small, like a cowl, I'd use my touchup gun. For a complete airframe, I use my full size, HVLP production gun.
TomCrump is offline Find More Posts by TomCrump
Old Jan 30, 2012, 10:23 PM
Leroy Gardner is offline
Find More Posts by Leroy Gardner
Leroy Gardner's Avatar
Coeur d' alene, Id.
Joined Jan 2010
If your looking for quality paint jobs plan to spend some money. I use a two stage air brush suction gun and can paint planes with 84" wings or tiny details. Some automotive touch up - detail HVLP's will do a nice job also. You'll need tips rainging from 1.2 to 1.6 and they are for automotive paints, you cant paint latex with them. Leroy
Leroy Gardner is offline Find More Posts by Leroy Gardner
Old Jan 31, 2012, 04:23 PM
alexhaben's Avatar
Eureka, CA
Joined Nov 2008
Thanks for the advice guys. I'm slowly starting to get my quiver together for model painting. So far I have a cheapo Harbor freight airbrush which I haven't used yet with a .3 tip, should be good for detail if I every need to go that small? My painting workhorse is my iwata G6 .6 tip which does pretty well with the reduced waterborne paint. I have been shooting primer with a HF 1.4 and clear with another HF 1.4. It works alright but I could use a smaller tip like a 1.2 next to help minimize clearcoat over spray and be more precise.
Old Feb 19, 2012, 05:40 PM
Raften is offline
Find More Posts by Raften
NorCal
Joined Dec 2009
Anyone want to educate me a bit about spray guns. I paint models with a air brush but recently found myself sand blasting a utility trail and then painting it with a brush. Didn't want to jump into a spray gun without some knowledge and I was in a bit of a rush to get the trailer done. Need the trailer to carry a bunch of gliders down to the desert. About all I know is what HVLP stands for. I have a big compressor and storage tank. I'm thinking one from HF will be cheap but do what I need.
Raften is offline Find More Posts by Raften
Old Feb 20, 2012, 06:31 PM
countilaw is offline
Find More Posts by countilaw
Joined Jan 2012
HVLP = High Volumn Low Pressure
countilaw is offline Find More Posts by countilaw
Reply With Quote  (Disabled)
Old Feb 20, 2012, 11:20 PM
Raften is offline
NorCal
Joined Dec 2009
Yep, knew that but what I don't know is why is that good, less over spray I suppose.
I guess I'll try another way, someone please steer me toward a good but not too expensive gun.
Old Feb 21, 2012, 06:56 AM
TomCrump is offline
ARFs Are Me
TomCrump's Avatar
Joined Dec 2005
I use an HVLP gun that my auto paint store calls a "production quality" gun. It has no visable brand label, either in the instructions, or on the gun.
Cost was around $150.00. It's done an excellent job using a variety of paints.
Old Feb 21, 2012, 07:44 AM
edwin1 is offline
Find More Posts by edwin1
United States, TX, Leander
Joined Sep 2003
I use a harbor freight touch up gun. It works, but you have to stay on top of it. It goes out of adjustment frequently and will sometimes fall apart in your hands. Then you get a bad squirt on the finish that has to be cleaned up. As long as you check it, you'll do ok. If you can afford it, I would go for a better quality gun like the others use. I'm on the cheap right now but will eventually get a good gun. One less thing to think about while painting. I use a paashe airbrush for spot clear coats like on vinyl decals.
Edwin
edwin1 is offline Find More Posts by edwin1
Old May 18, 2012, 03:41 PM
bugdude is offline
Find More Posts by bugdude
bugdude's Avatar
United States, NV, Las Vegas
Joined Mar 2012
I determine the type of gun to use based on the size of the model that I'm going to paint. I like using automotive touch-up guns. For suction feed, I still have a couple of Badger 400's and the Binks model 115, both of these are great guns. I use the older 400 for primer, the other for base coats and the 115 for clear coats. These guns hold twice as much paint than my gravity feed guns but are a bit awkward to use with the trigger on the top of the gun. For gravity feed guns I use the old Sata Mini-jets: 1.0mm tip for base coats and 0.8mm tip for clear coats (I find the smaller tip atomizes the clear better).
Henry
bugdude is offline Find More Posts by bugdude
Cool Guns for Christmas FL Knifemaker Life, The Universe, and Politics 37 Jan 04, 2012 08:26 AM
Discussion A look back for the Euros that can't understand why America loves her guns. BRETT65 Life, The Universe, and Politics 149 Aug 28, 2011 12:29 AM
For Sale fs/t:2 good condition mech paintball guns $100 FOR 2 GUNS AND EVERYTHING ELSE rcpilotjr Non R/C Items (FS/W) 5 Mar 22, 2010 05:53 AM
For Sale Lipos and Balancer for sale... clearing out the small stuf... chirogid Aircraft - Electric - Batteries & Chargers (FS/W) 1 Aug 06, 2008 05:19 PM
For Sale Clearing out a few small items DeCamara Aircraft - Electric - Batteries & Chargers (FS/W) 2 Feb 19, 2007 01:31 PM
