Old Jul 25, 2011, 12:53 PM
padcom is offline
Find More Posts by padcom
United Kingdom, England, Northamptonshire
Joined May 2007
Build Log
ART-Tech diamond 600 conversion
.Just flown my Diamond 600 after converting it to electrics. 9 gram motor, 2 3.7 gram servos, 6 amp esc with bec and a 300mah li-po. Flies great. Not as fast as the little Mulitplex Fox but more sedately. I have uploaded photos to show how I did it. No doubt there are many other ways but I just liked this way. All thats needed is a sharp knife, a router/sander tip on your Dremel and some epoxy. Oh, It has 4.1 * 4.1 prop but a 4.5*4.5 might produce a better rate of climb. Which right now is good but not a rocket. I rewound the motor in my Fox so I'll probably do the same here. Weight without Li-po after modifications 98 grams. Really.
padcom is offline Find More Posts by padcom
Old Sep 01, 2011, 11:02 AM
dpf is offline
dpf
Find More Posts by dpf
dpf
Cambridge UK
Joined Feb 2006
Looks great, which do you prefer the fox or this ?
Adam
dpf is offline Find More Posts by dpf
Old Sep 14, 2011, 10:02 AM
scousethief is online now
Find More Posts by scousethief
United Kingdom, England, Redcar
Joined Jan 2006
Looks awesome m8 , just got one myself to go with my fox.
scousethief is online now Find More Posts by scousethief
Old Jan 03, 2012, 02:10 AM
FrancoisStevens is offline
Find More Posts by FrancoisStevens
South Africa, FS, Northern Free State
Joined Mar 2011
Where does the CG lie?
FrancoisStevens is offline Find More Posts by FrancoisStevens
Old Jul 16, 2012, 07:27 AM
ccatalin is offline
Find More Posts by ccatalin
Romania, IS, Iași
Joined May 2011
yeah where the CG is ?h
ttps://vimeo.com/45495788
I am having troubble making this baby go
ccatalin is offline Find More Posts by ccatalin
Old Aug 10, 2012, 04:12 PM
Click59 is offline
Find More Posts by Click59
United Kingdom, England, Norwich
Joined Jun 2012
Hi all, I recently joined RCGroups and have just noticed this 'old' forum thread. I previously posted in the thread called 'Art tech diamond 600 EPO glider' without response maybe this is the correct thread?
I have performed a rc conversion of this wonderful airframe, I used 3 servos, 1 in each wing and one in the fin, a 10 gram motor with a GWS5030 prop, 10amp ESC, an orange 2.4GHz RX, and Rhino 360mah Lipo.
The all up weight is just over the 100gram, although I did replace all of the servo wires with enamelled copper wire and soldered these onto the RX to save weight and the space required for the connectors, and I have to say it flies great.
As for the COG, I simply checked where it was before I started the mod and made sure it was in the same place when I had finished.
It does fly very well, 10 minutes duration, quite a sensitive elevator but the roll is not brilliant. Keep it in the car for those opportune moments.
I am away on hols for the next week but when I get back I will post some pics and maybe post a build blog.
Click
Click59 is offline Find More Posts by Click59
Discussion diamond 2500 from art tech emory wright Electric Sailplanes 1772 Apr 15, 2015 05:56 PM
New Product Art tech diamond 600 epo glider richos Scratchbuilt Indoor and Micro Models 25 Mar 16, 2015 07:58 PM
Discussion Art Tech 1-Diamond 2500 PhilJacks Electric Sailplanes 2 Aug 20, 2010 07:51 AM
Discussion Art-Tech Diamond 2500 ARTF Glider bignose13 Foamies (Kits) 1 Aug 16, 2010 07:26 PM
Discussion Art Tech Diamond 2500 full house new2heli Electric Sailplanes 31 May 07, 2010 10:13 AM
