Old Jul 22, 2011, 02:39 PM
MSlater is offline
Find More Posts by MSlater
Joined Apr 2011
Problem with KK multi Black
Since I put the KK Blackboard on the quad it's been horrible.
I started with V4.7 in X config
Tonight I've re-configured and loaded V2
The same problem exists in both versions.
From power on, gentle acceleration produces a stable hover, all gyros working correctly and very stable.
Any increase in throttle and it veers off left. The more throttle the more violent it veers off.
Now this is the bit I really don't understand...
After its had a jump left the stick centres are way off - I have to hold in 80% right stick with 40% back stick and a load of rudder to get back into a hover.
It stays like that until power off - power back up and really stable again sticks at centre.
The problem is consistent and happens every time any amount of power is applied.
Suggestions would be welcome - I've been fighting this for a few weeks.
I've been through the TX and checked the output monitor for mixing etc.
MSlater is offline Find More Posts by MSlater
Old Jul 22, 2011, 09:19 PM
OLDTOM is offline
Find More Posts by OLDTOM
OLDTOM's Avatar
United States, TX, Waxahachie
Joined Jun 2011
Sounds like posible loss of left motor power. Try swap out of left and right motor's and esc's, see if this changes direction of (jump left) if it does then narrow it down by only changing one item at a time. Good luck and keep smilin.
OLDTOM is offline Find More Posts by OLDTOM
Old Jul 23, 2011, 06:29 AM
MSlater is offline
Joined Apr 2011
Shouldn't the gyro compensate for this ?
I suspect a faulty gyro - just can't work out why it only shows after a climb
Old Jul 23, 2011, 07:03 AM
OLDTOM is offline
OLDTOM's Avatar
Joined Jun 2011
I have not a gyro fail like that myself. but have had both motor and esc lose power after I give it a short burst, with motor it is usualy a damaged winding and with esc, I have not been able to repair but I understand that it can be a fet.
This might not be your problem, but cost nothing but a little time to check.
keep smillin
Old Jul 23, 2011, 01:15 PM
SeismicCWave is offline
Find More Posts by SeismicCWave
Hawaii
Joined Feb 2003
Stop assuming so much and start trouble shooting. All you have to do is to swap the hardware (motors and ESCs) from left to right and do another test. Very simple and will answer a lot of your question.
SeismicCWave is offline Find More Posts by SeismicCWave
For Sale New kk black board michaelsvrc Aircraft - Electric - Multirotor (FS/W) 6 Aug 26, 2011 08:20 PM
For Sale PRICE WAR START !!!Multi Rotor Helis -KK V5.5 Multicopter controller terriwang Aircraft - Electric - Multirotor (FS/W) 8 Jul 22, 2011 01:03 AM
Sold New 5.5 Black KK board G-unit Aircraft - Electric - Multirotor (FS/W) 3 Jul 18, 2011 05:44 PM
Help! PRICE WAR START !!!Multi Rotor Helis -KK V5.5 Multicopter controller terriwang Multirotor Talk 28 Jul 03, 2011 05:38 PM
Sold NEW Black KK Board V. 5.5 with xx "X" mode firmware $75 RChelisrule Aircraft - Electric - Multirotor (FS/W) 3 Jun 28, 2011 09:39 PM
