Old Dec 05, 2010, 11:42 PM
NeryFilth is offline
Find More Posts by NeryFilth
Joined Dec 2010
Props and motor help!!!
Hi everyone, my name is Nery.
i'm designing an aquatic robot and i need to calculate the prop and the motor for my project.
I've read sth about drag and thrust but I need to justify the calculations of every part of the structure.
I've done the calculations for the stability and flotation but i don't know how can i start with the propulsion system.
So, can anyone help me with the propeller and motor?
I just need the equations or formulas you use in this cases.
For example i have a ship of "x" mass and volume, and i want to move it at certain speed.
How can i determinate the diameter or pitch of the propeller and the power and rpm of the motor?
Just in variables. It will help me a lot.
Thanks in advance
NeryFilth is offline Find More Posts by NeryFilth
Old Dec 06, 2010, 12:30 AM
CornelP is offline
Find More Posts by CornelP
CornelP's Avatar
Bucharest, RO
Joined May 2009
The problem is that the formulae we use (in a software called FE calc) will only give data on ESC, battery, motor and given prop from an electrical point of view. These calcs are based on the assumption that you already have the right hull for those components. Most of us will use a prop based on our or others experience...
I am sure there are some calcs out there involving mass, drag, etc, but I doubt these are used around here
In theory, for a given mass and physical size you need a certain amount of power to move it. If you could get to this stage, then it's easy: power gives the motor. Based on the speed you want, you need to find a balance of prop/rpm that will suit your application: you can have a bigger prop at lower rpm doing the same thing as a smaller one at a higher rpm (but with a different load on the motor).
Best thing is give some examples, this way some of the guys around can also give their 2c...
CornelP is offline Find More Posts by CornelP
Sold BF-109G motor, 2bld props and spinner - new. sgomes Aircraft - Electric - Airplanes (FS/W) 3 Dec 04, 2010 06:09 PM
Sold Brushless Motor, ESC, Batts and props rayrcman Aircraft - Electric - Power Systems (FS/W) 7 Nov 23, 2010 12:36 PM
For Sale Multiplex twinstar II motor and props xjwrench1969 Aircraft - Electric - Power Systems (FS/W) 2 Oct 28, 2010 10:36 AM
Discussion Help with Aeronaut folding props kyle7119 Electric Sailplanes 7 Oct 26, 2010 06:02 PM
Sold NIB AR6400, AS2000, Motor, Batteries, and Props MTDV Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 3 Sep 17, 2010 03:05 PM
