Old Oct 12, 2009, 05:08 PM
Bigrcfan is offline
Find More Posts by Bigrcfan
Joined Apr 2009
Thinking of getting the Trex 600 ESP but...
I am leaning towards getting the Trex 600 ESP but was told by someone at my local LHS to instead get the Trex 500 ESP. according to this individual not only is teh overall operating cost much cheaper, but that the 500 flys just as stable as the the 600. I am not interested in any 3D flying just sport flying. With that being said is teh 500 just as stable as the 600. I'l wait on feedback before I make up my mind. Thanks in advance.
Bigrcfan is offline Find More Posts by Bigrcfan
Old Oct 12, 2009, 05:26 PM
CatchmyCorsair is offline
Find More Posts by CatchmyCorsair
Ohh Snapp!
CatchmyCorsair's Avatar
Joined Sep 2005
I wouldn't say operating costs are that much different. 600 main shafts are only $1 more than the 500's. Initial setup cost will be greater on the 600, mainly the batteries.
The 500 can be stable, but the 600 can be setup to be MORE stable. The main thing is the visual footprint. The 500 is a great size but the 600 is much bigger and easier to see at far distances. It's also much more intimidating!
CatchmyCorsair is offline Find More Posts by CatchmyCorsair
Old Oct 12, 2009, 06:12 PM
RC Man is online now
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
Since the cost of LiPo batteries have come way down the T600 is very affordable. Unless you are a real 3D expert you would be better off getting the standard T600 instead of the ESP. The standard version is actually more durable and has fewer bling parts to break.
RC Man is online now Find More Posts by RC Man
Old Oct 12, 2009, 06:29 PM
Bigrcfan is offline
Joined Apr 2009
I didn't know there were different models of the 600 and thought ESP was just a name assigned by Align lol.
So you think I will be better off with the 600 over the 500? Would it be ok to just sport fly the 600 with a 6S lipo?
Old Oct 12, 2009, 09:21 PM
AMA Outlaw is offline
Find More Posts by AMA Outlaw
Killeen, TX
Joined Jul 2006
I would get the 600 over the 500 unless I just was on a really tight budget and then I probably would look for a nice, used 600 anyway. You will always wonder "what if..." if you get the 500. The 6S lipo will fly the 600 well if you stay with sport flying, and better if you run 570 blades. A better option might be a couple of 4000-4500 4S batteries in series for 8S (the stock ESC has been reported to arm on 8S with no problems).
AMA Outlaw is offline Find More Posts by AMA Outlaw
Old Oct 13, 2009, 09:36 AM
Flyextreme is offline
Find More Posts by Flyextreme
Sure it'll work
Flyextreme's Avatar
United States, CA, Redondo Beach
Joined Nov 2005
The stock 6S system should be fine for sport flying. If you go to 8-10S for performance, you'll be changing more than just the batts.
Someone else trying to make the same decision http://www.rcgroups.com/forums/showthread.php?t=1123013
I too was considering the 500 & 600. I ended-up with a Gaui 550 (30 size) in between 500-600......then I just got the T500 recently. The T600 is just enough harder on the wallet for me not to get one.
Take your time, and keep doing your research to figure out what is best for YOU.
Bill
Flyextreme is offline Find More Posts by Flyextreme
Old Oct 13, 2009, 12:09 PM
OICU812 is offline
Find More Posts by OICU812
Joined May 2005
If you're going to look at using 6S 5000mah packs then look at a Logo 500. Far more agile, lighter and easier on packs by far.
OICU812 is offline Find More Posts by OICU812
Old Oct 13, 2009, 04:09 PM
LabradorONT is offline
Find More Posts by LabradorONT
Joined Aug 2009
I would stay away from Align products when there are 500's like the Protos around and the Logo for a 600 size. Align has serious parts quality issues that they have never addressed let alone fixed. The bearings are of such low quality you will be replacing many of them on regular intervals. You'll need to replace the buttery soft screws on the T500 right away adding to the cost.... don't fool yourself... Align cost more than the sticker price. There are a lot of Align fan boys, especially on helifreak, and they seem to like to fight till the death to honor all the money they have sunk into Align but anyone with a walnut shell sized brain can figure out that Align is sub when compared to stuff from Protos and other companies. They like to say thins like "the t500 loves head speed"... but what that really means is the t500 NEEDS high head speed to be stable enough otherwise it's a wobbly pig.
As for size, I would go for a 600... especially if you are only interested in sport flying. but like others have said... a 500 is pretty stable as well but the 600 really has a lot more presence in the air.
LabradorONT is offline Find More Posts by LabradorONT
Old Oct 13, 2009, 05:05 PM
norcalheli is offline
Find More Posts by norcalheli
My other addiction!
norcalheli's Avatar
Marysville, Ca., US
Joined Jan 2007
Bear in mind, also, that a Rex 500 uses 425mm blades while the 600 uses 600mm blades. That's quite a jump in size. Flyextreme mentions the Gaui Hurricane 550, and I have the Swift 16, which is also a 550. Both are good in-between choices. The Swift uses 520- 550 mm blades. I run 530 mm blades on a 4S Lipo setup.
norcalheli is offline Find More Posts by norcalheli
Old Oct 13, 2009, 10:42 PM
Cyclick is offline
Find More Posts by Cyclick
Joined Dec 2007
I agree, the Swift 16 is a great in between size heli that does great on 5S and 6S. It is easy to set-up for mild traing or for some pretty good 3D. It also uses standard size servos, so with the current relatively low price of 5S and 6S packs, you may ultimately find that the cost of getting one in the air is about the same as a smaller 500 or 450.
If you want C/F frame and more bling, you can go with the 550SE version.
Cyclick is offline Find More Posts by Cyclick
Wanted 3 Align DS610's for Trex 600 ESP Camel Tow Aircraft - General - Radio Equipment (FS/W) 0 Jun 09, 2009 11:32 PM
Discussion Trex 600 Esp Owners Check Yours ninja-rhyno Large Electric Helis 1 Mar 26, 2009 04:22 AM
Sold NIP Trex 600 ESP chadtyro Aircraft - Electric - Helis (FS/W) 0 Mar 25, 2009 07:30 PM
Discussion New Trex 600 ESP Information Thread RC Man Electric Heli Talk 3 Feb 27, 2009 04:52 PM
Discussion Servo recomendations for e-trex 600 esp.. djdaveq Electric Heli Talk 11 Jan 29, 2009 07:58 PM
