Old Feb 28, 2003, 12:37 PM
Green Member
FX1SUB's Avatar
NJ
Joined Mar 2002
How to prop my Mega powered SB?
I have a Mega 16/15/7 on the way for my Switchback. What prop would be my best choice for this setup? Probably will be using HECELLs for batteries.
FX1SUB is offline Find More Posts by FX1SUB
Old Feb 28, 2003, 12:59 PM
Mountain Models Wannabe
CoClimber's Avatar
Ithaca, NY USA
Joined Mar 2001
Do you have a Wattmeter? I think you'll want around a 9x4.7 but you'll want to base your choice on current draw. I'd try to limit your static current draw to less than 15 amps.
I can't help you much because all my testing with the Mega has been in the thin air of 6500'.
Doug
CoClimber is offline Find More Posts by CoClimber
Old Feb 28, 2003, 02:53 PM
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
I think Doug's choice is spot on. JUST under 15 amps according to P-Calc and should fly great at partial throttle. That's a Slowflyer prop, btw.
Mark Wood is offline Find More Posts by Mark Wood
Old Mar 10, 2003, 11:07 AM
Green Member
FX1SUB's Avatar
NJ
Joined Mar 2002
Thanks for the help.....I'll give the 9x4.7 a try. I have a Craftsman digital multi meter but I haven't a clue on how to hook it up to get a reading. How is this usually done? I assume some sort of test stand has to be constructed, then hook up the motor (with prop), battery, and ESC through a wattmeter (multimeter) to measure amps. Is that correct? Maybe I should start a new thread in the "Open Discussion" forum to benefit others who would like to learn how this is done. I've been meaning to learn how, but my laziness has gotten the better part of me lately
Joe
Old Mar 10, 2003, 11:20 AM
CoClimber's Avatar
Ithaca, NY USA
Joined Mar 2001
Joe,
Most multimeters only read current up to 10 amps. You don't need a special stand, you just read the battery current while holding on to the plane.
Understand that you are measuring static current. In flight, the current will be lower. It is a good place to start though.
Doug
Which Prop Adapter For my Mega Powered XE2? Joe Elston Foamies (Kits) 11 Jul 01, 2003 10:09 AM
How to wire my Mega? JCastle Power Systems 2 Jan 15, 2003 11:23 PM
Say Hello to my New Mega Powered Python! azflyer Sport Planes 28 Oct 08, 2002 02:32 PM
Nosed in my Mega powered T-44 Flying Low Foamies (Kits) 5 Sep 20, 2002 07:07 PM
How to keep my prop on ? Red Baron 47 Power Systems 5 Jul 11, 2001 11:52 PM
