Old Apr 17, 2008, 12:13 PM
The Predator
The Predator's Avatar
Golden, Colorado
Joined Dec 2004
Hobbico CS-12MG Servo Hi-Speed Metal Gear Micro
Anyone tested these servos, Hobbico CS-12MG Servo Hi-Speed Metal Gear Micro U. For the price they sound too good to be true. Do miricles still happen?
The Predator is offline Find More Posts by The Predator
Old Apr 17, 2008, 12:30 PM
Human Like You
NewbieX's Avatar
Colorado
Joined Feb 2001
It's a rebranded Hitec HS81MG. Not horrible, but not very good for applications where centering and accuracy are important.
Graham
NewbieX is offline Find More Posts by NewbieX
Old Apr 17, 2008, 04:40 PM
The Predator
Golden, Colorado
Joined Dec 2004
Thanks man! I'm hunting for a tough micro servo for planks that will not break the bank! I believe that means it must be fairly accurate and reliable, huh?
get what you pay for? Must be some little exception????
Old Apr 17, 2008, 04:52 PM
F3B
satinet's Avatar
Warwickshire, England
Joined Sep 2006
I actually had good luck with the "SuperTec Micro 2BB MG Servo" (aka GWS?. I had a couple of those on the v-tail of an old tragi. There was no slop in the gears at all and they centred a lot better than the hitec servos that were in the wing. (i.e perfectly).
They were also pretty fast and rather powerful. I had a natural suspicion of them, being cheapos (not sure on the servos reputation either), but i have to be honest and say they couldn't be faulted. Maybe i was lucky (for a change!).
EDIT:- they also survived a crash which snapped one of the v-tail pushrods and caused the other ruddervator to bind on the tail while i ran to pick it up for probably over a minute.
DOUBLE EDIT: i believe they also recently survived the plane being nose dived into the ground from 300ft.... but that is just luck i fear!
These things happen if you try and fly f3f underground.
satinet is online now Find More Posts by satinet
Old Apr 17, 2008, 05:26 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Nice specs, but it looks like they're a little thicker than even the HS-85MG.
That's why the HS-81MG is so attractive, because it's basically Hitec's
only truly thin (less than .5" thick), durable servo with decent torque. The
double centering problem and random electrical failures turned me off to
them years ago though. HS-65MG is the right size, has smooth/solid
movement, but has relatively low torque. How much that matters depends
on the application.
ian
Daemon is offline Find More Posts by Daemon
Old Apr 17, 2008, 05:56 PM
AKA Cactus
Phillybaby's Avatar
Cornwall UK
Joined Aug 2002
got a couple of those supertecs in my Zipper, doing the job fine, very important when you'd got that little movement for elevator
Phillybaby is offline Find More Posts by Phillybaby
Old Apr 17, 2008, 06:20 PM
Long to be flyin'
Antonsoarer's Avatar
Wirral, (UK)
Joined Dec 2003
Try the Hitec HS65HB, no slop, great centering, not expensive and small. Resin gears seem very strong. I also find supertecs very strong.
Antonsoarer is offline Find More Posts by Antonsoarer
Old Apr 17, 2008, 06:54 PM
United Kingdom
Joined Feb 2005
HS82MG's seem 'nice'
ENGINETORQUE is online now Find More Posts by ENGINETORQUE
Old Apr 17, 2008, 07:09 PM
Twisted and Confused
flyonline's Avatar
Joined May 2003
Have you looked at the Hyperion digitals???
flyonline is offline Find More Posts by flyonline
Old Apr 17, 2008, 07:19 PM
find me @samotage
samotage's Avatar
Melbourne Australia
Joined Jul 2005
I know R/C Junkie has been raving about the corona digitals in various sizes for good budget servos. Maybe worth an investigation?
Sam.
samotage is offline Find More Posts by samotage
Old Apr 17, 2008, 07:33 PM
Si Vis Pacem Para Bellum!
Doubletap's Avatar
PRC (People's Republic of Commiefornia)
Joined Jul 2005
I use these:
http://www.hobbycity.com/hobbycity/s...idProduct=3609
Same size as HS-85MG; they are fast, center perfectly, metal gears, less than $15 each. They are often incorrectly compared to the HS-81MG however they are actually the equivalent of the HS-85MG but have much more torque. I put these in for both flaps and ailerons for my molded planes and they work flawlessly.
Doubletap
Doubletap is offline Find More Posts by Doubletap
Old Apr 18, 2008, 04:42 AM
Long to be flyin'
Wirral, (UK)
Joined Dec 2003
Originally Posted by Doubletap
I use these:
Doubletap
Hmmm, impressive looking servo, smaller than an 85 but more powerful. Found a UK supplier and only 14!
Old Apr 18, 2008, 09:20 AM
Long to be flyin'
Wirral, (UK)
Joined Dec 2003
Doubletap, what are they like on Slop? Tony.
Old Apr 18, 2008, 09:27 AM
Long to be flyin'
Wirral, (UK)
Joined Dec 2003
on the application.
ian
I like the 65, the HB version seems to have the lowest slop of any of my servos and can be boosted with 6 volts.
Old Apr 18, 2008, 09:52 AM
Doubletap's Avatar
Joined Jul 2005
Tony, there's virtually no perceptible slop in the gear train when you mount an arm and try to twist it. Any tighter and I'd be concerned about premature gear train wear. Nice thing about these is that they are so inexpensive, if you do break/wear out the gears, just replace the whole servo as they cost the same as replacement HS-85MG gear sets.
Doubletap
Sold Hitec HS-85MG Metal Gear Micro BB SERVO papamac Aircraft - General - Radio Equipment (FS/W) 3 Jan 14, 2007 04:30 PM
For Sale FS: 3 X Futaba S9255 Digital Hi Torque Metal Gear Servo Jason WAI Aircraft - General - Radio Equipment (FS/W) 3 Jun 06, 2005 02:47 AM
WTD: Gear set for Hobbico CS-15 servo Jonathan Ott Aircraft - General - Radio Equipment (FS/W) 0 May 09, 2005 12:57 PM
FS: Futaba S9206 Servo Heli Hi Torque Metal Gear Jason WAI Aircraft - General - Radio Equipment (FS/W) 5 Sep 12, 2004 10:37 PM
hobbico cs-12mg gear set ? geng Radios 0 Mar 02, 2004 01:08 AM
